Question about Sharp AL 1631 Copier
Shema sensor TS0524LB-86E FK2-0358 de la canon ir 3025
The copier Ir 2570 its Opc drum in which copier is Equiverant to
The drum for Canon Ir 2570 is also equivalent to this machines: Like Canon IR 2230
Like Canon IR 2270
Like Canon IR 2530
Like Canon IR 2570
L ike Canon IR 3530
Like Canon IR 3570
Like Canon IR 2830
Like Canon IR 2870
Like Canon IR 4530
Like Canon IR 4570
Like Canon IR 3030
Like Canon IR 3025
Like Canon IR 3035
Like Canon IR 4035
Like Canon NPG 25
Like Canon NPG 26
Jul 30, 2017 | The Office Equipment & Supplies
IR 7095. Como puedo reparar marca el error E00020?
Lo que indica es que a pesar que tiene toner la tolva sigue indicando que no hay toner. Posible obstrucci?n en el paso del toner o sensor de toner de la tolva defectuoso
Jun 19, 2015 | Canon Office Equipment & Supplies
All the wires in TS0524LB-86E is cut off from inside the sensor. how to solder the wires. it is having red, white, blue and green wires
Depends on where they were cut. How much wire you have to work with on both cut ends will determine how to best repair them.
Aug 16, 2014 | Cars & Trucks
Paper jammed in canon ir 3025
adjustment in the right side on casset just turn the nobe
Jan 22, 2014 | Canon ImageRunner 3025 Black and White...
Scanning using canon image runner 3025N
Hi Swandi,
Have you installed the scanner utility software before?. If yes, you can use the software or uses other application such as photoshop :)
Have a nice day!
Printer Clinic
Jan 13, 2014 | Canon ImageRunner 3025 Black and White...
Canon ir 2525 service manual & parts catalog
Please refer your request directly to Canon
Apr 18, 2013 | Canon IR 2525 Digital Copier
Canon ir 3025 service error
Pls. tell wich sevice error, eg. E019, E007,...
Jan 28, 2010 | Canon ImageRunner 3025 Black and White...
No tengo el manual de la iR 1600-2000
http://software.canon-europe.com/products/0000705.asp
May 05, 2009 | Canon ImageRunner 1600 Copier
Como configuro la copiadora impresora canon ir 1023
tiene que ser una 1023 con habilidad para imprimir. aunque no lo creas no todas las 1023 imprimen. si la tuya si imprime no debes tener mayor problema al conectarla via usb debe detectarla windows y se instala como una impresora cualquiera. ojo, el hecho que tenga puerto usb no quiere decir que sea impresora.
Sep 10, 2008 | Office Equipment & Supplies
Sharp AL 1631 Copier Logo
252 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
