Question about CTX UltraVision PS-6180 Multimedia Projector
Ctx 6180 I'm trying to hook the projector up to my tv so I can watch a football game very large on the wall! Can this projector take the signal from the tv?
    Brigadier General:
  • 6,966 Answers
It will work only if your TV has a Video OUT either in Composite RCA, S-video or in some other form although not all TV models have this feature.
Alternately, you can hook up your projector to an old VCR which definitely will have a Video OUT and use its built-in TV tuner. Of course you have likewise to connect a cable/aerial to the RF IN of the VCR.
Hope this be of some help/idea. Good luck and kind regards.
Posted on Oct 27, 2007
  • Louie  Role
    Louie Role Nov 26, 2007
    Hi again,
    Appreciate the rating and glad to be of assistance.
    Cheers.
SOURCE:
How do I hook my data projector up to my cable TV?
If the TV offers video and audio outputs, you can connect those to the projector. Otherwise you'll need to use a VCR or DVR as the source. In fact, you don't need a TV set at all if the VCR/DVR you use has TV tuning. Hook the video to the projector, run the audio through your stereo system and you're set.
Jan 28, 2009 | Sanyo DS25390 TV
My TV makes a loud buzzing noise whenever there is a bright picture on
This is usually caused by video signals overdriving circuits. Too much video causes what you are describing. This is sometimes caused by a bad cable or connection, either a TV cable or a video cable. Hopefully it's not a projector problem. If you can check the connections from your receivers and VCR with the projector on you might be able to pin point the problem. Be gentle and if there is adoubt about a cable, just replace it.
Sep 22, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
LG 42 inch Plasma Picture in Picture with SKY satellite service
PIP only works off two seperate signals, eg you cannot watch 2 sky channels at a time, you can watch sky tv and then your analogue channel using PIP or freeview, you can then swap which is to be viewed as a large picture and which is to be viewed as the smaller picture or half and half.
Sep 07, 2008 | LG MZ-42PZ14 42 in. Plasma Television
EZPRO CTX
TRY IT AGAIN ON YOUR CURTAIN. IF THIS DOESN'T WORK YOU MAY HAVE BLOWN THE BULB. GOOD LUCk
Aug 03, 2008 | CTX Optoma EzPro 600 Multimedia Projector
CTX EzPro610 - No Signal
unfortunately, you may need one. if you cannot even access the menu, you have a main board issue.
Oct 05, 2007 | CTX Optoma EzPro 585 Multimedia Projector
Projector Image Problem
Hi There
Your Projector switches to a 16:9 ratio when hooked up to a Video signal and to a 4:3 Ration when hooked up to a PC signal.
You can manually change this in the Menu functions if this bothers you.
Simply go to Aspect Ratio in your Menu's subfolders and press left or right once you scrolled down to it.
Sep 21, 2007 | BenQ MP610 Multimedia Projector
CTX Optoma EzPro 580
Hi, Optoma USA recommend that you set the PC resolution to SVGA (800 x 600) or XGA (1024 x 768). Your HP Pavilion ze 4900 default resolution is S = SXGA (1400 × 1050) or X = XGA (1024 × 768). I would assume that your cable(s) are properly mated/attached from the laptop to the projector. If on pressing TV Now! One-Touch button with a TV icon at the top of your keyboard to switch the display to the TV-Out mode, there is no picture projected, you can try to manually lower the screen resolution of your PC. Try lowering it to the 800 X 600 setting in your Display Properties. Also, you may want to check if the Dual Display Mode is enabled/activated. You can try different resolution setting as long as the projector can handle it. Hopes this works and give you an idea. Should you need more assistance, pls post/comment. Good luck and kind regards.
Aug 11, 2007 | CTX Optoma EzPro 580 Multimedia Projector
No user guide or manual
Hi, I have a user manual for this projector in PDF format, if you email me at chris@bse1.co.uk I will send you a copy.
Regards
Chris Woodward
May 09, 2007 | CTX Optoma EzPro 600 Multimedia Projector
CTX UltraVision PS-6180 Multimedia Projector Logo
164 people viewed this question
Top CTX Office Equipment & Supplies Experts
k24674
Marvin
Marvin
Are you a CTX Office Equipment and Supply Expert? Answer questions, earn points and help others
