Question about AGA Legacy 36" Dual Fuel Kitchen Range
Conversion kit for 4 oven aga propane cooker to natural gas
We have a aga propane 4 oven cooker we need to convert to natural gas The valve installed is a eurosit 630 More numbers on the aga to try to help No A051030 CE 0086 37 mbar en 437 Aga 119 AP 19 Aga GE or GF or CF ( can't see the letters properly) GC GCB & GE 5KW 357/G/H GEB 5.8 KW 414 G/H Eurosit details Eurosit 630 0085AP0012 Code 0630205 Lot 4090909 Inlet MAX 50 BAR Outlet 3.18 mbar Date says 9911 Hope you can help My tel 01286880168 Kind regards Maurice
I have propane. Is my range set up fpr natural gas or propane and do i need to change. I'm having issues with my oven
without knowing your model number or mfg it's tough to say 4 sure but i can say that most common mfg do offer a propane conversion kit to use there gas stoves on bottle gas , most often it's a new regulator to install
Jan 08, 2015 | Kitchen Ranges
Conversion from natural to propane
Due to differences between natural gas and propane, they require differing amounts of gas supplied to the burner. This is controlled by the size of the opening where the gas goes into the burner. The mechanism for control is called an "ORIFICE," which usually is made of brass, and looks like a short, fat bolt, with a tiny hole at the center of the bolt head. The difference between the orifices for each gas is accomplished simply by varying the size of that hole. There is a conversion kit that you can buy at the hardware store. It is fairly simple to do. Typically it involves switching out orifices, which look like a short bolt with a hole in the middle. Take out the old, put in the new.
Hope that helps.........
Jun 27, 2008 | Rinnai RER-55AS 55-Cup Rice Cooker
I like to know how to change from natural gas to propipe
You must buy first the appropriate conversion kit for your fryer, you can check and order only with the authorized parts dealer. Conversion kit consists of burner and pilot orifice and gas valve spring and stickers (propane) and installation manual. Propane orifice has smaller bore than natural and gas valve spring is for propane is thicker than natural gas valve spring.
Jun 03, 2011 | Welbilt Kitchen Appliances - Others
Can the natural gas valve be converted to propane gas?
Yes, most can be converted. You will have to contact the manufacturer or dealer directly to buy a conversion kit.
heatman101
Apr 15, 2011 | Blodgett DFG-200 Gas Single Oven
I have a small counter top fryer set up for lp gas how do i change to nat
check the supplier for the conversion kit.the kit contains burner orifice, pilot orifice and gas valve spring which are commonly needed for conversion from propane to natural gas or from natural gas to propane.
****natural gas orifice has larger bore than propane, gas valve spring for propane is thicker than for natural gas.
Mar 29, 2011 | Cecilware FMS-40 Deep Fryer
Where do i find propane to natural gas conversion kit for weber spirit e310 gril
Apparently, Weber does not make a conversion kit to convert the grill from propane or from natural gas to propane. According to the Owners Manual - "Liquid propane gas is not natural gas. The conversion or attempted use of natural gas in a liquid propane unit or liquid propane
gas in a natural gas unit is dangerous and will void your warranty." (From Page # 3 of the Owners Manual)
See below link.
http://www.weber.com/help/manuals/pdf_files/2008_updated/89525_030308_2008.pdf
Feb 23, 2011 | Weber Spirit? E-310 Propane Grill
I got a GE gas range (model JGBS22) from a co-worker. She had converted it from gas to propane. I just had a plumber hook it up to natural gas but, even with the conversion manual, he couldn't change the...
There should be a set of orifices for each burner as well as the oven and broiler. When the unit was converted to propane, these orifices should have been replaced and the ones for gas put in with the conversion kit installation information. The kit should have been reattached near the pressure regulator.
If the kit was missing the orifices, then, yes, you are missing pieces. Check with your coworker if the conversion kit was missing. If you have the kit, it can be easily done by any appliance installer (or repair person) licensed for handling NG. (At least on our range, the conversion kit installation was straight forward. Every orifice was clearly labeled with the labels different for each burner and for the gas/LP kits (ABCD (NG) vs MNOP (LP)) .) The regulator is the only part that switched for LP or NG without the kit.
As I recall, the only tools we needed for the top burners were a small wrench (10 mm) and a small flat blade screwdriver. Remove one orifice and put in the appropriate replacement. Then adjust the burners so that they didn't blow out when the oven was opened or quickly turned from high to low (for the simmer burner). The oven and broiler took a bit longer. Several screws had to be removed to get at the orifices. Then the air flow had to be adjusted for the incoming gas.
I hope this helps.
(the conversion installation manual was on the counter during installation; I read it while it was open.)
Jan 14, 2011 | GE JGBS22 Gas Kitchen Range
I have an empire wall heater that was converted to natural gas how do i convert it back to propane?
you will need a propane conversion kit designed for that particular model heater.
which would most likely consist of a heavier spring for the gas valve and orifices for the burners depending on how many burners you have.
Most all gas heaters come thru the factory set up for natural gas and most have a kit available for conversion to LP (Propane) You will also need a manometer or a gas pressure tester to check the incoming and outgoing pressures from the green (2ndary )regulator outside your house to the gas valve inlet side,usually 11 to 14" WC( water column) pressure( static) 14" being MAX!!
Outlet pressure with burners running 10-11" WC approx. This info should come with the conversion kit if available. If you are not comfortable working with gas then find someone who is, for safety reasons.
Jan 31, 2010 | Reddy Heater RLP100 Portable Forced Air...
Converting Thermos Stainless Grill to natural gas
You have to install a conversion kit for it to work the way you want. The reason is because the orifice in either the valves or the main "jet" that feeds the burner tube has to be changed. Natural gas is really not as efficient as lp gas (propane) because it takes more natural gas to create the same btu output as propane.
In short, your grill will not work if you do not do the conversion. I am including a link that lists the conversion kit for your grill, you can order it there and you can download the assembly manual as well.
Here is the link: http://www.charbroil.com/Consumer/product_detail_e.aspx?ProductID=1723&CategoryID=25
Nov 20, 2009 | Thermos Stainless Steel Gas Grill
Dryer has been converted to propane using conversion kit #131776600 and I need the info needed to get it back to run on NG The dryer is a Fidgaire Gallery series model #FDGC648GHS0 any help greatly a
Hello there. If the parts were saved, they can be reused. If not, contact your propane provider and tell them that you plan to convert back to natural gas. They will be able to get you the kit you need, and will possibly have a technician come out and install it for a fee.
May 27, 2009 | Maytag Neptune MDG5500AW Gas Dryer
AGA Legacy 36" Dual Fuel Kitchen Range Logo
250 people viewed this question
Top AGA Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Tom Chichester
Brett Duxbury
Brett Duxbury
Are you an AGA Kitchen Range Expert? Answer questions, earn points and help others
