Question about Garden
Kubota kx36 2 wiring diagram
Need a new battery for kx36-2,based in spain so the part number unhelpful(104E),alsoAh=28,seems too small!
SOURCE: Ignition switch
A kubota dealer should be able to print one for you or go on line with model # etc and you should be able to bring one up yourself. I hope this helps. donnyb60
Posted on Mar 19, 2009
  • 5 Answers
SOURCE: i just need a small 7 pin wiring diagram to wire a...
facebook
Posted on May 22, 2010
wentlanv
  • 710 Answers
SOURCE: i have a kubota T1670
Give a few minutes and I will find a diagram for you.
Handie Andie
Posted on Mar 26, 2011
hmerchant110
  • 7191 Answers
SOURCE: Kubota 1553164017 Dynamo hub and
You have posted the problem under "Websites" section.
Kindly submit the question under Auto Parts and Accessories category on the website by clicking this link so that the best experts in that category can view and post a solution to the problem.
On the page which opens, type the question in the "Ask an Expert" box on the right hand side of the page and click on "Ask a Question" button.
Thanks for using FixYa.
Posted on Jul 05, 2011
  • 6468 Answers
SOURCE: Cub Cadet 2150 ignition problems. Need a wiring diagram to source problem.
don't have a diagram but i would check the safety switches jump them while looking for the bad one with a paper clip
Posted on Apr 13, 2012
I need a wiring diagram for the fuel shut off solenoid for a kubota m6800
Contact Kubota directly to request the wiring diagram.
Jun 07, 2017 | Kubota Garden
Need wiring diagram for Kubota t1770
check grounds first & then have starter & battery tested
Oct 27, 2014 | Cars & Trucks
Where does one get the wiring diagram
http://www.icare-jmb.com/Documents%20partages/eclates/pride/scooters/BASE-GOGO.pdf
This illustrated parts breakdown will allow you to follow the wiring harnesses and check and test all the interconnects. This manual will allow you to remove covers and locate parts. Some basic problems can be solved by checking for loose, disconnected, burnt or damaged wiring and connectors. This manual will also give you part numbers. It is best to check with customer service before ordering parts since there are parts changes based on Model and serial number.
Just as a point of reference, most issues for this model can be found in the electronics assembly console, the plugs at the controller and the battery box connections and HIDDEN fuses. B7 page 30 is a good example of a hidden fuse on the battery box that is sometimes burnt out. E3 page 28 is another hidden fuse. Hope this helps.
Mar 26, 2014 | Pride Go-Go Ultra X 3-Wheel Travel Scooter
Kubota 9540 starter diagram
check battery check to make syre you are getting power to small starter wire when key is turned
Oct 18, 2012 | Cars & Trucks
I have a kubota bx25 that won't start. it has power to the starter on battery side
you need to have power to the small wire on the starter for it to crank over
Sep 03, 2012 | Woods Kubota Bx 24 Bx 23 Bt610 Bh75 And...
Kubota L2250 DT wiring diagram
You can download:Kubota Tractor L2250, L2550,L2850,L3250 2WD 4WD Operator Manual
This Manual Covers
1. Servicing of Tractor
2. Specifications
3. Operating New Front Mower
4. Instrument Panel and Controls
5. Lift Link and Hydraulic Control
6. Wheels, Tires and Tread
7. Operating
8. Maintenance
9.Check and Maintenance
10. Adjustments
11. Troubleshooting
12. Long-Term Storage
13. Lubricant Specifications
14.Wiring Diagram
Jul 03, 2012 | Motorcycles
I need to know what the 6 wires from Kubota regulator RP20153700 connect to. Dybnamo hub is Kubota 15531-64016. Wires from regulator are 2X blue, 1 each red, green, black, yellow
You passed all the pertinet information except the model number of the unit your working on. The information you need will be in the service manual and I can not locate a service manual without the unit model number. I apologize for not being able to attempt an answer at this time but without the unit model number I can not help.
This is just a typical diagram and does not list wire colors:
http://www.thevincent.com/WiringDiagram-B-C2.jpg
The wiring diagram may also be in the owners manual... but again I need the model number.
Kelly
Jul 05, 2011 | Vehicle Parts & Accessories
Garden Logo
80 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
