Question about Senco 980001N AF41 Air Free 1-1/4-Inch to 2-1/2-Inch 15-Gauge Brad Nailer
Air free 41 wont fire
When the gun builds up to fire it cuts out and wont fire
Senco air free wont fire
Maybe A cilinderseal exacly on top of the cilinder is insecure loose on the top instead of tight , it look likes he is blowing air out by the trigger instead to drive the piston . the most types airnalers have a valve insite the top of the top cover this may also be cleaned (solvent) and so that the parts can move free inside.
Feb 11, 2014 | Senco Air Tools & Compressors
I have a Bostitch N80S stick framing nailer that leaks air from the trigger area. I replaced the entire trigger valve with a new single fire trigger to see if the old bump fire trigger was the problem
Remove the nails and take off the trigger to expose the trigger valve (usually part # tva6). Connect air and spray soapy water on the valve to determine if the air is leaking from the center of the valve or around the outer edge between the body and valve. If leaking from the center, could be defective valve or debris under oring. Pop out the valve and examine internal parts for cut oring or defect. If leaking from between body, you could have cut orings installing the valve. Make sure that there are no rough edges in the body of the gun. Bump fire or single fire happens with the trigger type not the valve. Bump fire trigger is usually black metal and single fire trigger is light color plastic. Good luck
Apr 10, 2013 | Stanley Bostitch Nail Gun
Dewalt dc618 wont fire
firstly its always better to change both of the bands even if one is broken this always keeps the drive trim.all seems well clean all the contacts ie battery and gun (do not use any cleaning products this will cause grease)just wipe clean with paper towel.
Nov 11, 2012 | Dewalt DC616kn 18 - volt 16 - gauge...
The problem i'm having is with a senco sn 41 stapler the driver wont fully return to the top
Hello try to put some oil in the connection of top and bottom may be this might help. please rate my comment
Nov 21, 2011 | Tools & Hardware - Others
Sns 41 as soon as i connect air hose, driver goes down and air comes out exhaust
May need cylinder seal # bc0438. When this seal fits loose or is cracked, air will leak past and push piston down to bottom of the cylinder. If the seal fits snuggly and looks in good order, suspect headvalve orings and cylinder spacer orings leaking. Order oring kit and seal. Use silicone paste lube on all the orings. Look carefully at the surfaces where orings make contact and remove scratches with 300 grit sandpaper(fine scratches will allow air to leak past new orings). To make the gun work with poor fitting orings. Clean inside of gun with diesel and apply plenty of silicone paste to orings (using same orings if not cut or broken). If gun works as normal, the silicone paste is temporarly sealing the orings. It may continue to work for a while untill you get new parts. Good luck with repair.
Aug 13, 2011 | Senco SNS41 16Ga Stapler 1" 2"
The driver doesn't return after firing. it is a porter cable brad nailer BN200
This is pretty common with brad nailers
Remove the brads from your gun - disconnect from the air supply
On the front of your gun is a latch - open it
Check the sliding surface for build up of dirt or small pieces of metal from the brads.
Once clean polish the surface with a fine steel wool or a small brass brush
Reassemble with a drop of machine oil on the sliding surface
Oil your gun as you normally would
Using a piece of soft wood dry fire the gun 10 or so times to ensure that the dents it is making in the wood are all pretty even
Reload and nail something
Mar 08, 2010 | Porter Cable-Cable BN200B 5/8-inch to...
Paslode air framer not sinking some nails
Your air pressure is dropping everytime you fire. It sound like your compressor is not cutting back in untill it to low. Not giving your tool enough continuess pressure. Your compressor cut in pressure should be around 90-100psi no less. and your max. pressure no more then 120psi. (Make sure your regulator is set at 110psi)
good luck...!
Aug 11, 2009 | RTO Paslode #650027 2500CT Placement Nail
I have a stenco sns 41 stapler that double fires and then jams.
Make sure your air is regulated down to the right pressure ( usually 80lbs. ) also there is a way to staple without double firing and that is to hold finger on trigger and tap gun like a hammer but a lot lighter.You can also adjust the safety on the nose of the gun. I believe there is a screw on the front side to loosen and adjust the safety. As far as the manual, just go on their website and get on to download, because they are free always.
May 26, 2009 | Senco SNS41 16Ga Stapler 1" 2"
Paslode im350
Stuart - this sounds like an air problem - you should perform the following test. With the air nailer close to the compressor you must monitor the airpressure after the gun fires. it sounds like the air is not gettting through diapram fast enough or there is a blockage in line. Blockage in line is not suspected for the following reason . It sounds like the air hose is holding enough air to fire 2-4 nails and then you must wait for the line to fill up again and then it fires ok. The pressure regulator out to the line controls this and they do fail. try this test and report back to me - I know I can solve this for you as I have extensive background in compressor and the like.
Oct 22, 2008 | Itw Devilbiss Itw Paslode Cnp 65Y Coil...
Senco 980001N AF41 Air Free 1-1/4-Inch to 2-1/2-Inch 15-Gauge Brad Nailer Logo
137 people viewed this question
Top Senco Air Tools & Compressors Experts
John Trevino
yoopertech
Mike
Are you a Senco Air Tool and Compressor Expert? Answer questions, earn points and help others
