Question about Tire Extreme Sealant kit 50ml- Repairs Only
My treadmill stopped working as I was busy walking on it. I had already oiled it
I had it on summit for the first time.
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 65 Answers
Check the power cord has not got a short or loose connection in the wall socket, if its ok it will be the power to the motor, loose connection or motor requires new brushes inside
Posted on Apr 23, 2014
My weslo treadmill slips when walking on it and has a bad clicking noise. When looking under the walking mat it looks like there is oil on the surface.
treadmill slips when walking Peggy, Try wiping the under side of belt of oil residue with a mixture water and little dish liquid(Dawn), to help the slipping belt. You may have to turn up the tension of belt to stop slipping if this cleaning does not do the trick.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Mar 25, 2016 | Weslo Exercise & Fitness
How do you get the track to stop squeeking?
when was the last time you lube the walking belt
Jan 28, 2015 | Proform Walking Belt For The 520x...
Belt stops while using nordic track c2255
this happen to due the lack of maintenance according the schedule manintenance. see the video and proceed.However if after you did, the problem remain,is TIME to replace the old board deck. God bless you
Mar 26, 2013 | Nordic Track NordicTrack A2350 Pro...
Belt is slipping and I need to know what maintenance I should be doing on this model as I have no manual for it.
Hello, There is no maintenace required. Some people like to oil the walk belt, The manual say to do this annually. To do this you loosen the walk belt and applty some synthetic oil to the walk board under the walk belt, then tighten the belt and the belt will distribute the oil where it needs to go. As far as the walk belt, just make sure that is stays in the center of the walk board. Now your front roller and drive belt. The roller does not get serviced, it has perminently sealed bearings. The drive belt usually lasts for many years, if you remove the motor hood and see alot of black dust, it will be the belt. At that point you need to see why it is comming apart/rubbing. After you determine that, you would want to replace it.
The slipping you are describing could be the drive belt slipping on the front roller or the drive pully on the front roller. To find out you need to remove the motor hood nad get on it and look. What you will be watching is the drive belt as it goes from the drive motor to the drive pully. When you try to stop the walk belt you will either stop the drive belt or stop the walk belt. If you stop both, the drive belt is at fault, if the motor keeps turning. If you stop the motor, the motor or the controller is bad. If you stop the walkbelt and not the drivebelt you have a bad drive pully on the front roller, and need to replace the front roller. When you do this you need to remove the drive belt, this is a ggod time to replace it.
Hope this helps, rate my solution if it helped you. Thanks, Matt
Jan 09, 2011 | Proform 495pi Treadmill Frontdrive Roller...
I just bought this treadmill used from my sister. She did not have any trouble with it but when we turned it on and tried to use it, it feels choppy.... when i was walking on it at 3.0 it felt like it...
HI, its sounds like the running belt is too loose. i have had the same problem, when my wife uses our treadmill its works fine but when i step on it jurks and struggles to move propley, so i tightened the belt a fraction and works perfectly. also try not to put any oil or greese on the belt rollers. that just makes the belt slip.
Nov 18, 2010 | Proform 730 Folding Treadmill Model...
Belt slips and somtimes stops on me while walking.
hi. if the belt slips and stops when your walking its a sign the you may need a replacement belt. and if you smell motor burning after you have been on for a while that is a sign that a/ you have no oil left and b/ your motor is slowley packing up.hope i have helped.
Nov 11, 2010 | Proform 695 LT Treadmill
Treadmill stopped. panel still working - showing info.
The motor controller weakens over time because of the excessive amperage draw of the motor do to lack of lubrication (which wears the walk belt and walking deck).
Take an amperage reading of the motor it should be 2-3 amps with no one on it, with someone walking on it it should be around 6-12 amps. I would bet yours is elevated above 6-12 amps.The controller is dropping output because of the friction problem.
The first thing to try after testing the amperage is to lubricate the walking platform. Then retest and see if the amperage comes down and it doesn't shut off.
If it does then the next step would be to replace the walking deck. If the amperage still is up you may need to replace the walk belt second and finally if after replacing the deck and belt, if the unit is still shutting down replace the motor controller.
Jul 31, 2010 | Treadmill Doctor Proform 675Q Treadmill...
Reebok 8050es treadmill walking belt has started slipping/skipping. It has been oiled and it is 2 years old.
If the walking belt slips when walked on, first remove the key and UNPLUG THE POWER CORD. Using the hex key, turn both rear roller bolts clockwise, 1/4 of a turn. When the walking belt is correctly tightened, you should be able to lift each edge of the walking belt 2 to 3 in. (5 to 7 cm) above the walking platform. Be careful to keep the walking belt centered. Then, plug in the power cord, insert the key, and carefully walk on the treadmill for a few minutes. Repeat until the walking belt is properly tightened.If you still have slipping then the drive belt under the motor shroud can also cause this problem unplug unit remove shroud then plug unit in start it up observe the front roller to see if it stops if it does locate the tension adjusting bolt by the motor loosen motor mount and proceed adjusting until slipping has been eliminated
May 05, 2010 | Reebok 8050 ES Treadmill
Tredmill not moving
That's an embarrasing admission. A treadmill works like a conveyor belt or a car's fan belt. If it is too loose it will slip under load. There will be an ajuster on your treadmill. All you have to do is tighten the belt. Do not overtighten it though. an
Feb 17, 2010 | Cadence Weslo 825 Treadmill Walking Belt
Pro-Form 360P, when I step on the belt, it stops moving.
when the belt is stopped you should be check the deck if this it´s worm or the walking belt, because a probable cause is lack of lubrication, In addition should send the engine to revision, because according to what your gross probably already there are some Diode Rectifier damaged, You must know that the cause that generates this problem stems from the walking belt and the table or deck
Jul 16, 2009 | Proform XP Weight Loss 620 Treadmill
Tire Extreme Sealant kit 50ml- Repairs Only Logo
Top Tufo Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Tufo Vehicle Part and Accessory Expert? Answer questions, earn points and help others
