Question about Canon PowerShot SD750 / IXUS 75 Digital Camera
Check battery pack,lens does not stay out when turned on
DS-W370 lens the lens of the camera are out and i get a message to turn off the camera and try again but never worked
The Turn off and on again error message displays when there is an internal malfunction or a malfunction with the Lens. The error message normally displays with the issue with the Lens. Try the following steps to check if the issue can be resolved.
Try power resetting the Camera.
Turn off the Camera.
Remove the battery pack.
Press and hold the power button for 15 seconds.
Then, allow the Camera to remain without power for 60 seconds.
Re-insert the battery pack and check if the Lens retracts.
You can also try resetting the Camera back to factory default. To reset the Camera back to factory default, select the INITIALIZE option from the Main Settings Menu of the Camera to OK. (Menu-->Settings-->Main Settings-->Initialize-->OK.)
This should resolve the issue. If the issue persists, service may be required.
Thanks for using FixYa.
Jan 10, 2011 | Sony Cybershot DSCW370 Digital Camera
Canon SD1000 lens error
Turn off the Camera, remove the Battery pack, then press and hold the power button for 30 seconds.
Reinsert the Battery, then buzz around the lens for a few times then check if it works. Make sure that the Battery is fully charged.
The error message indicates that the lens is not able to adjust itself.
Oct 23, 2009 | Canon Cameras
Kodak EazyShare C533
You didn't mention the type of battery used but if they are rechargeable, one bad cell of three or four can cause this. If a proprietary battery pack, have it checked if you don't own a multimeter. I've seen this behavior on each camera we have owned.
Sep 12, 2009 | Kodak EasyShare C533 Digital Camera
My camera says "read error" when trying to view pics
You might as well replace the camera, they do not fix these. If you send it in to Fuji you get an exchange camera from Fuji, the cost is fairly high
Apr 14, 2017 | Canon PowerShot A85 Digital Camera
Cameera lens will not open (expand) when turned on.
Please check whether you're using a fully charged battery.
After fully charging the battery if the issue still persists, please try Power Resetting the Camera.
To Power Reset the Camera.
First, please turn OFF the Camera.
Then, remove the battery pack from the Camera.
Then, press and hold the POWER button on the Camera for 30 seconds.
Then, reinsert the battery pack and check whether the issue is resolved.
Jun 15, 2009 | Sony Cameras
Lens wont come out
Try Power Resetting the Camera which should resolve the issue.
To Power Reset the Camera, First, please turn OFF the Camera.
If the issue still persits after Power Resetting the Camera service of the Camera is recommended.
Jun 15, 2009 | Sony Cyber-shot DSC-S750 Digital Camera
When the camera is turned on with the power button the lens comes out and stays out but the camera immediately shuts off and the lens stays open. The only time the camera remains on is when the dial at the...
Please try Power Resetting the Camera.
Jun 13, 2009 | Sony Cameras
Lens not going in
Hi , test the battery pack if not read in multi tester volt meter , change battery pack.
Jan 21, 2008 | Samsung S1030 Digital Camera
"00" Apparture
If an aperture of "00" is displayed on the camera's LCD panel, perform the following steps in order. Check after each step to see if the problem remains, and proceed to the next step if it does. (In some cases, you may see "Err 01" displayed on the LCD panel.) 1. Check if the lens is correctly mounted on the camera. If no lens is attached to the camera, "00" will be displayed for the aperture value. 2. Clean the lens contacts. Turn the camera's power switch to OFF, and then detach the lens from the camera to clean the contacts. Use a blower to blow away dust on the lens. Do not touch both the camera's or lens' electrical contacts with your fingers while cleaning the lens. Turn the power switch to ON again and check the aperture value displayed on the LCD panel. Refer to the Instruction Manual provided with your camera for instructions for detaching or mounting the lens. Also, prevent any foreign materials or dust from getting into the camera through the lens mount, and be sure not to damage the contacts. 3. Remove the battery pack. Turn the camera's power switch to OFF and remove the battery pack. Then reinsert the battery pack, and then turn the power switch to ON again.
Aug 29, 2005 | Canon EOS-1D Mark II Digital Camera
Canon PowerShot SD750 / IXUS 75 Digital Camera Logo
19 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
