Question about Dorcy International p6V Floating Luminator Lantern with 6V HD Battery
Replacing batteries in dorcy lantern - Dorcy International p6V Floating Luminator Lantern with 6V HD Battery
I am trying to find battery location for Coleman Model 5327A750
William, went to Coleman site, looks like you remove screws on bottom of lantern to access and change battery.
Check the attached links to your manual,
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://r1.coleman.com/Manuals/5327.pdf
Rugged Rechargeable Family Size Lantern
Coleman Rugged Rechargeable Lantern Replacement Parts Flashlights...
Battery Buyer Batterybuyer com
Mar 06, 2016 | Coleman Camping, Backpacking & Hiking
How to change the battery for my 4345 coleman lanterne
There are two adapters for that lantern; one for the house and one for 12volt. You simply connect one of the adapters and it will power the lamp and also charge it. Those two adapters came with the lamp; if you don't have them you can contact Coleman to purchase replacements.
Jul 29, 2014 | Coleman 8D Family Size LED Lantern -...
Replacing a 6 volt battery
Check that the contacts where the springs on the battery make contact in the light to see if they are corroded. If so scrape or sand them off.
Jan 09, 2013 | Energizer Eveready Utility Lantern Uses 6V...
Rayovac 360 sportsman lantern wont work
Since batteries and bulbs are new/ok, check for a bad connection. In older version using 4 lantern batteries, open the battery compartment by unscrewing the knob on top of lantern. The lantern bottom comes off once unscrewed (of course you did this to change batteries). There is a "C" clip on the lantern center shaft; remove this by prying with screwdriver or with pliers. Carefully raise the battery contact plate and check slip-on wire connections. Clean as needed (Scotch-Brite works well) and reconnect. Squirt some contact cleaner in exposed switches, work switches back and forth. Inspect circuit board for obvious corrosion or damaged parts (this damage may "total" the lantern). Re-install plate aligning grooves with ribs. Install batteries and test.
Nov 01, 2012 | Camping, Backpacking & Hiking
How do you install 6V battery into Dorcy luminator
I was just having the same problem - I didn't realize that I had to take the black caps off the two springs at one end of the battery! Once I pulled those off, and put the battery in with the springs facing up, I was able to screw the top of the flashlight back on, and it worked. I hope this helps.
Oct 28, 2012 | Dorcy International p6V Floating Luminator...
User's manual for coleman rechargeable lantern model # 5348-700
There are several options to buy replacement batteries for a Coleman rechargeable lantern, model 5348-700. I just picked up two new batteries from www.1000bulbs.com for $4.87 each plus shipping. ($20.99 for 2 with shipping!) Do a Google search for: ub645f1 6 volt - 4.5 ah - f1 terminal battery for other options
Jan 22, 2012 | Coleman Rugged Battery Powered Lantern...
How to replace a bolb in a dorcy 41-1088 spotlight
I charged the battery overnight, and it was working before I charged it, and now it will not work. What could be wrong with it. The bulb doesn't look blowed.
Tommy or Kathy Ingram 304-425-1120
Nov 03, 2010 | Dorcy International Dorcy 5 Million Candle...
My lantern/fan/radio doesn't work when its not plugged in?
The battery probably isn't taking a charge anymore because it needs to be replaced. These batteries will sometimes last a few years but then a replacement is needed and they will likely run like new. You can check out http://www.batteryinternational.com/lantern-battery.html to find a replacement battery, or you can call 1-877-28-BATTERY if you are having difficulting finding the battery you need.
Jun 18, 2009 | Coleman Lantern Fan Radio (841.321) AM/FM
Dorcy International p6V Floating Luminator Lantern with 6V HD Battery Logo
87 people viewed this question
Top Dorcy International Camping, Backpacking & Hiking Experts
Tom Chichester
ray gallant
Are you a Dorcy International Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
