Question about Canon Office Equipment & Supplies
Error code e000050-0000 in ir 3300 means - Canon Office Equipment & Supplies
spinal
  • 287 Answers
SOURCE: CANON IR C6800
Hello Jc.Let me start by saying that despite the fact that you have properly been specific with the error code you have submitted, Canon is "fairly" specific in regards to the amount on detail in provides. I say fairly in really loose terms. The error 602 means that for any number of reasons when the copier went to boot" (begin to start up and read its directions as to what it is, who it is, and what it is capable of, it failed to get the instruction set (or failed to recognize the instructions) and therefore said "what"?!) as the copier sought to retrieve this info from the hard drive.That can mean that the partition of the hard drive that is was looking at contained corrupt information, or there was a communication interruption, or that the hard drive is going or gone bad. I know this sounds like a bunch of technical goblidy gook but you don't want to know what the 0101 means after the 602. It may not be too bad but brace yourself for the worst. That is that the hard drive may have went wheels up, or at a minimum all stored custom information is gone. The latter may be the best you can hope for. I am afraid that a "hail Mary" might be to power the copier of by way of the rear switch (or unplug if you are not familliar) and wait a few minutes.Restart and hope for he best. Otherwise you WILL need a technician to replace the hard drive and then they will have to reload the system software. I was reluctant to respond to your request for help as I cannot "fixya" and I will get a bad grade from the guys that run this site since I left ya hangin. But I could not resist trying to help you and to at least make sure you did not get raped by some "hungry for money" company. Please at least give a decent rating and I will keep my fingers crossed for you..................SPINAL
Posted on Jan 25, 2008
  • 5 Answers
SOURCE: error code E000051-000
E000051-000 is not a waste toner full error code thats E000015. This error code refers to the horizontal registration sensor not reaching home position or is not detected when the assembly is commanded to move. The sensors function is to determine the edge of the sheet of paper in the front to rear direction to determine the write position on the drum. It is not somthing you can fix and would require a tech. Possible sources of the error are, DC controller, horizontal registration sensor or actuator, or the horizontal registration motor. Based on experiance the motor is either stuck or burned out so the sensor does not move at start up
Posted on Jun 07, 2008
Cogz
  • 1326 Answers
SOURCE: E000225 & e000019 error code
The error code E0019 is the waste toner bottle is full you need to empity out the waste toner bottle and make sure the neck of the bottle is totaly clean and clear, a sensor reads dirt on the neck that the bottle is full. To clear that code after cleaning the waste toner, turn the main power switch off on the right side of the copier. The waste toner bottle is on the left hand side toward the rear of the copier and is held in with one screw. The E00225 deals with the scanning lamp. you will have to replace the lamp and the lamp PCB as a set to solve that problem. Good Luck...
Posted on Nov 10, 2008
  • 199 Answers
SOURCE: Canon IR 3300 switchs on it displays the Erro E000602-0003
replace hard disk drive
Posted on Feb 15, 2009
SOURCE: Error code for IR 3300 E000100-003
3300 shows me this error E000100-002
Posted on Jul 31, 2009
How to remove error code of ir 3300 e000732-0001 code
If you wish to get some details; check the site linked here. Pull up older posts......
http://electro-medical.blogspot.com/
May 31, 2016 | Canon Ir 3300 Black & White Copier
E000007-0000 error in diplay
The Canon imageRUNNER 3300 System error e007 code means that the fusing film is out of Home Position or the film is ripped. You will need to most likely have the fixing film replaced. You are probably going to have to get a service to repair it.
fixya.com/support/t6195187-cannon_ir2018_system_error_e007
November 7, 2002 Product : IR 2200 / 2800 / 3300 Title : E007 code for the IR 2200 / 2800 / 3300 Problem :
E007 code is occurring for the IR 2200 / 2800 / 3300
Solution :
In Service mode / Copier / Function / Part Check, energize M4 (the Fixing Drive motor). If the Fixing Drive motor does not come on, replace M4 (part number FH6-1848-000). Canon USA, Inc. Systems & Technical Support Division
you access service mode by pressing ADDITIONAL FUNCTIONS-2-8-ADDITIONAL FUNCTIONS...
Nov 02, 2010 | Office Equipment & Supplies
Canon ir 3300 error code display e000019-0000
It means that your waste toner box is full.
You can do the next:
On left side of copier, on lower left side you have small cover with screw.With screw driver unscrew it and remove cover. Remowe the waste toner box/container, and clean it, after you removed toner wash it with water and clean the inside and outside of box neck with alcohol to remove the antistatics. Place it back and restart the copier.
Mar 31, 2010 | Canon (6981A002AA) for imagerunner 2200,...
Error code e000007-0000 in caonon ir 3300
my canon ir 3300 shows error e-000007-0000 how can i solve this problem
Jan 16, 2010 | Canon imageRUNNER 3300 All-In-One Laser...
CANON IR 3300 HAS ERROR CODE: E000002-0000
OK, but first try to clear the error under service mode, then replace fixing film assy, for EU 240V is FG6-6041.
To clear the error:
* 2 8 *
COPIER
FUNCTION
CLEAR
ERR
OK
Turn off and on ( main switch )
If this dont help - replace fixing film assy.
Dec 02, 2009 | Canon (6981A002AA) for imagerunner 2200,...
Code error of Cannon IR3300 E000006-0000
getfile.asp?rid=1258 November 7, 2002 getfile.asp?rid=3215 Product : IR 2200 / 2800 / 3300 Title : E007 code for the IR 2200 / 2800 / 3300 Problem :
Solution :
Apr 29, 2009 | Office Equipment & Supplies
26 people viewed this question
old marine
old marine
