Question about Fujitsu Siemens Computers & Internet
Wireless receiver My laptop is failing to get DNS, Noting to do with my internet suplier because everything esle works fine. any help?
    Prodigy:
    An expert who has answered 500 questions.
  • Fujitsu Siemens Expert
  • 510 Answers
This could be one of a few reasons, but most likely is because the unit needs a factory default recovery, try that first, otherwise it could be a hard drive fault.
Posted on Feb 11, 2014
Testimonial: "So do i need to restore my Laptop to Factory Setting?"
BLAZZ81
  • 281 Answers
SOURCE: Laptop wireless internet cannot find connections?? Doesn't try??
The drivers you installed may have started a driver conflict, uninstall the web cam drivers,, if that dont work reinstall the wireless drivers
Posted on Dec 01, 2009
paul7of9
  • 1189 Answers
SOURCE: I had to replace my harddrive on a toshiba laptop.
A "Diagnostics" can identify the cause of the problem, or (errors) and try to correct, the "Internet" connection. Go, to: Control Panel, select "Network and Internet." Select, (“view network and task status”),choose a task”, to performed, from the (left) pane. You can start a quick diagnostic by clicking on the connection "diagram", Computer---WNC---Internet. “You can (setup) personal computer, internet settings.” I hope this Fix it.
Posted on Jan 22, 2010
1alexh
  • 484 Answers
SOURCE: laptop doesnt connect to wireless internet (wireless card is fine
When you reformatted your HD, did you use IBM's method which utilizes a hidden partition? This results in a laptop which appears to be as if it just came from the store, like a brand new laptop.
This method sets up the computer in the exact way that IBM built it. And puts all devices in their proper configurations.
If you have not done too much yet, you might want to try that method right away and see if it doesn't make a big difference in the way your laptop works.
-a.
Posted on Feb 19, 2010
  • 95 Answers
SOURCE: my computer is not detecting wireless internet
My Network Places>View Network Connections>Right click on wireless and click enable
OR
Right click on MY COMPUTER SORTCUT> properties>click HARDWARE TAB>Click DEVICE MANAGER>in pop-up window got to network adapters>right click and click ENABLE.
Posted on Apr 17, 2010
SOURCE: My asus n61j won't connect to the Internet using internal adapter
Hi there, I just bought a new Asus NJ series, and all of a sudden my wireless dissapeared! I FOUND THE SULOTION, well, I hope it works for you. Look on the left side of your laptop, right at the front left side is a switch/button. I think I accidentally switched it of, but now everything is working fine!
Posted on Oct 27, 2010
My belkin n USB adapter (f5d8053) has been unable to access the wireless internet at my new place, through the mwn-apr150n medialink wireless n broadband router. My other devices connect fine, it's...
Please check the Network Range B/G/N Signal.
This could be the issue if other aplications are able to connect.
Also try to delete Wifi Profiles using the USB and add fresh wifi networks
If not in install & reinstall the the USB Software on ur pc / laptop
Lastly if this doesnt work try to use the USB Adapter on another network / other device and try to connect
If it doesnt then u have a USB Issue
Cheers
Eddie
Jul 02, 2017 | Belkin Computers & Internet
I am unable to connect internet on samsung r580 windows 7 on my pc win 7 it works fine but it wont works on r580
Not being able to connect to the Internet depending on what method you are using for your internet connection if wireless or cable or DSL I would reboot everything unplug it all modem routers if any and modem or DSL box and the computer as well. What happens sometimes when Windows sleeps it closes off the Internet connection as well and you may have to log back in. Make sure that you are powered off and then connect everything back up again and let it do its thing and try to access the Internet again.
If it will not access the internet make sure that you do not have laptop set to wireless if you are using a cable or DSL R-45 cable wiring. I'm assuming wireless for the laptop so make sure that the switch if any is switched to wireless as well.
If all else fails contact your IP service and have a technician come out and take a peak at it. Often times it has been my IP on their end that does not work and they have to reset the router or modem to get the DNS to work again. Often times it is just easier to call them and have someone come out and fix it should be free for you to have this done. Thanks for using FixYa! I hope this assisted you. John
Apr 20, 2011 | Samsung R580 Notebook
Just brought a Sony Bravia HX 800 and added a wireless LAN adapter (UWA-BR100) to get Internet TV. After network set up NOT able to access internet. Message reads Wireless device OK Local Access FAILED...
Hi
I got the Bravia KDL-40EX713 and the uwa-br100 I had massive problems getting it to work with a BT home hub. Eventually I found manual setting that work. Firstly I logged on to the router and went the the advanced settings bit, then I went to the DHCP table that shows all the devices connected. I picked an unused Ip address from the range of existing ones being used (this sort of thing 192.168.1.73)
I then used the following settings for the other fields (I don't think the secondary dns setting is right but it still works)
ip 192.168.1.73
sn mask 255.255.255.0
default gateway 192.168.1.254
primary dns 192.168.1.254
secondary dns 192.168.22.23
If the DNS server ip is wrong then you get local access OK but internet access failed.
Hope this helps.
Ian
Jan 30, 2011 | Apple AirPort Extreme Base Station
I have a new acer aspire 5534 that won't find internet
did u setup the network TCP/IP setting...and provide the IP address and other DNS address etc
Dec 26, 2009 | Computers & Internet
Connected but could not access internet
When connected via wireless open a command box and type "ipconfig /all" and note the DNS settings assigned to your laptop. Then do the same with the wired connection. If the wireless connections are not receiving valid DNS settings, that would explain why you won't be able to access any Web sites. You can then re-configure your router to issue the correct DNS settings as per those issued to the wired connection. You could alternatively add these DNS servers as static settings on your laptop, but its best to do it on the router and leave your laptop set to automatic.
Dec 11, 2009 | Linksys Wireless-G WRT54G Router
Wireless connection problem
When you say "IP and DNS settings are correct", can you define what "correct" is? IP and DNS settings change depending on the wireless network they're using, so one setting will not work for all networks. The most "correct" setting you can have is probably DHCP - which is called "Obtain IP address automatically" and the same for DNS. If your laptop has any statically assigned IP information, make a note of what they are, and then change it to DHCP and see if you have better luck. If you have statically assigned IP information, it will allow you to connect to the wireless network, but not provide internet access because your IP scheme and DNS settings are wrong. It sounds like the scenario you're describing.
May 17, 2009 | Dell Inspiron 8000 Notebook
Dns error (80710102) on my ps3. It works wirelessly fine (but weak signal causes glitches) - but when I use a wired connection it will sometimes work fine for an hour or so and then kick me off the network...
I had the same problem and tried every solution. On the linksys website for my router they said to update the firmware. I did, enabled upnp and everythings good. Just reset you ps3 internet connection, set it to auto and let it do its thing.
Apr 11, 2009 | Sony Playstation 3 (PS3) Console
Laptop finding router but no internet connection
If you can connect directly to your virgin Media Broadband and get internet then your laptop and broadband router is fine.
The wireless router appears not to have a DNS entry and you will need to add that manually.
I suggest that you connect directly to the Broadband modem, be sure you can get onto the internet. Once you have confirmed you can get onto the internet you need to get the dns information from your Broadband modem for later.
once connected directly to the broadband modem, click start>run> then type "CMD" then click open. you will get a prompt type the following and record the DNS Server ip addresses.
"ipconfig /all" then hit enter
this will display your ipaddress information but mostly you need the DNS server ip addresses.
once you have recorded them rerun the install, but this time instead of at the end of the install where it shows the Wireless router information you can modify or change it and add the DNS server entries.
Also by default most wireless routers ip address is 192.168.1.1 and you can type that from a internet explorer and change it from there as well. I believe it's no ID or user name and the password is admin.
Good luck
Jan 28, 2009 | NetGear WGR614 Wireless Router
"Failed to lookup DNS" error with Aluratek wifi internet radio
Here's the useless response from Aluratek customer support:
"Failed to lookup DNS, the password is case sensitive, if you are using upper lower case letters you have to key in the correct case otherwise you won't be able to connect your radio. Thanks."
However, Aluratek advised another AIRMM01 owner to obtain a newer modem. I bought a new Actiontec GT724WGR Wireless DSL Modem and that resolved the problem with my AIRMM01F.
Dec 28, 2008 | Aluratek AIRMM01 Internet Radio Alarm...
please help me iam wired connection to the playstation 3 i have ((dns error)) but i still can make any download please help me quikly ......
engineer.sabah .talal
Apr 01, 2008 | Sony Playstation 3 (PS3) Console
Computers & Internet Logo
171 people viewed this question
Top Fujitsu Siemens Computers & Internet Experts
Lee Durbin
Lee Durbin
Marcin
Are you a Fujitsu Siemens Computer and Internet Expert? Answer questions, earn points and help others
