Samsung FPT5084 50 in. Plasma HDTV Logo
mughal Posted on Feb 11, 2014
Samsung lcd tv model le40c530f1w wo,nt turn on psu looks ok need help
No light no sound
5 Related Answers
Anonymous
  • 63 Answers
  • Posted on Oct 02, 2009
SOURCE: NEED MANUAL FOR SAMSUNG MODEL LNT 1953H LCD 19''
..review of the product and related issues:
http://www.amazon.com/review/R2LL7LEO1ABLU8
Crutchfield's take on that model and it 'ease of use issues':
http://www.crutchfield.com/S-rsaLPNJLHDO/p_305LNT1953/Samsung-LN-T1953H.html
..more specifications from that site + related comments:
http://www.crutchfield.com/p_305LNT1953/Samsung-LN-T1953H.html?tp=161&tab=detailed_info
...manual download page for 19" LCD series:
http://www.samsung.com/us/support/detail/supportPrdDetail.do?menu=SP01&prd_mdl_name=LN19B360C5D
Rule of thumb is check a similar product in case you can't find exactly what you want. Discussions on those other sites indicate they only have "user guides" for the LNT 1953H LCD 19" ..and nothing in the way
of serious service manuals (i.e. for the consumer).
Email me back for more info:
[email protected]
roety
Eric Rotmil
  • 587 Answers
  • Posted on Dec 15, 2009
SOURCE: LCD TV LA40R81BM/XTL tv tick tick sound 5min then strat
Hi my name is Roety,
I can help you with your issue ,
This is most likely a power supply issue
I usually replace the swollen capacitors I can see
A repairman would charge about $300 to replace them for you.
If I have helped you with your issue
If you have more questions you can still respond
I will reply asap
Thanks
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
SamsuTech
  • 113 Answers
  • Posted on May 10, 2010
SOURCE: Samsung LCD TV will not turn on or off. Red light
hi,
your lcd ip board (power board) capacitor had already exhusted.
got to replace the ip board.
SamsuTech
  • 113 Answers
SOURCE: LCD TV samsung LN40A450 doesnt turn on
hi,
Anonymous
  • 6 Answers
  • Posted on May 22, 2010
SOURCE: Samsung LTP227W
Usually the power supply is bad. Just 3 capacitors 1000uF 35volt rating. The 3 electrolytic caps will be puffed out, simply replace tham and you will be back in business.
I have a samsung tv 40 lcd you turn it on it makes a sound then no pic but is still powered up
There are hundreds of different models of Samsung LCD TV using numerous methods of screen illumination.
what model?
it could be a faulty PSU or faulty LED strip and unfortunately if you are asking what is wrong, you are unlikely to be able to diagnose and fix.
an LED strip would mean a large disassembly job with a very high risk of damaging the fragile LCD.
a PSU fault would mean knowledge of working with mains powered electronics or you could take a punt and just buy a replacement PSU although it is unlikely to be this if sound is still present.
someone with knowledge of TV repair really needs to be fixing it as diagnosis over the web is impossible, even for a repair technician like myself.
3answers
I am looking for the complete repair kit for a samsung 51 inch plasma tv model number PN51D490A1DXZA.
Samsung LCD / Plasma TV Capacitor Repair Kit ...
www.amazon.com > ... > Capacitors
Amazon.com, Inc.
Rating: 4.4 - ‎86 reviews
Samsung LCD / Plasma TV Capacitor Repair Kit, Replacement Parts: ... 1-220uf 25v; 4-2200uf 10v; 6-1000uf 25v; 6 Inch Solder and Solder Wick; Cleaning Swabs ... pump + Solder wire + Solder wick + CAPACITORS Replacement)-COMPLETE KIT ... In my case, the OEM capacitors did not look bad, but I replaced them all ...
Samsung PN51D530 Plasma TV Repair Kit, Capacitors ...
Amazon.com, Inc.Samsung PN51D530 Plasma TV Repair Kit, Capacitors Only, Not the Entire ... Save on the full line of Powerblanket heating solutions. ... and 8 inches of 0.1 inch (2.5 mm) copper de-solder wick are included in the kit. .... Made Easy · Look.com
EASY MOST COMMON TV REPAIR EVER!!! - YouTube
? 13:13
https://www.youtube.com/watch?v=SXqSg2A5b7I
Jan 6, 2012 - Uploaded by Tampatec
Must See TV FIX EASY COMMON Samsung TV Repair Repairing LNT LCD PLASMA TV FIX SERVICE VIDEO TUTORIAL ... if you go to get tv repair kit- http://tampatec.blogspot.com/ easy ways .... The YSus/Zsus boardlook to be ok but I'm wondering if I need to replace the YSUS board> Any thoughts?
I have a Samsung 46" TV (LCD) which will not display a picture. The white light in the bottom center area lights up and the Red Light in the bottom right hand corner continues to blink. Finally, about...
had a totally knackered Samsung power supply which had to be replaced when I fitted new psu had clicking coming from new psu which turned out to be a faulty relay on the new Samsung p.s.u replacing the relay on the new power supply board got the TV working 100%
1helpful
Samsung TV will not turn on.
OK if it is LCD your and have sounds but no picture you possibly have faulty inverter board that need to be replace
I have a philips 42" plasma t.v.model
hello sir Dave!!!
welcome to fixya..
Lets find out if that problem is worth to repair or not..I need some info regarding your TV such as how many flash of LED lights in front?..It will help to diagnose where the fault came from..
Please reply to this tread to post the info I need..
Thanks for using fixya..
regards,
Chester
2helpful
My Samsung LCD TV will not turn on, it just clicks
A Replacement Power Supply.
Parts: £80 - £110 depending on the model.
Labour: £40 (ish) little bit more with a 90 day warranty etc.
Type your model number into www.chsinteractive.co.uk for the price on a PSU.
Good Luck.
1helpful
Long wait when cold for tv to actually switch on
bad capacitors unplug the tv and let it sit for a day. Lay the tv flat and take all the screws out the back you want to look at the top right corner of the pcb ( power board you cant miss it ) you will probably notice 4 swollen / leaking caps replace these and the tv should work fine. The tvs protection circuit is stopping it from starting your straining the PSU by using it with the caps blown if your not comfy soldering phone a local electronics company im sure they can help you out. you can easily disconnect the headers from the psu board and take that for repair.
i used 35v 1000u caps the caps i removed were 10v 1000u
3helpful
3answers
My samsung TV won't show any picture/sound.
When the TV is on, need to check the back light is on(go back side & look into through)
If the back light is on -- need to exchange the Main Board
no back light -- exchange the Power Board --- 95%
exchange the LCD panel --- 5%(inverter)
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
