Question about Fisher and Paykel Fisher Paykel Intuitive Eco Washer IWL15
Error code 66 - Fisher and Paykel Fisher Paykel Intuitive Eco Washer IWL15
  • Fisher and P... Expert
  • 554 Answers
66. (01000010) - Pressure Transducer Out of Range Error
The Motor Controller has received signals from the Pressure Transducer outside normal values.
Primary Source - Motor Controller
Action - Replace Motor Controller
Posted on Apr 21, 2014
Error code 66
conflicting info
http://www.obd-codes.com/trouble_codes/gm/gm-2-digit-codes.php
66- pressure sensor or circuit air conditioning
http://www.cadillacfaq.com/faq/answers/dtccode.html
DTC 66 - Driver Air Bag Deployment Commanded
Apr 09, 2016 | Cars & Trucks
Error 66
http://www.registryquick.net/runtime/Fix-Runtime-error-66-How-to-Fix-Runtime-error-66-95318.html
May 22, 2014 | Abit AG8 Motherboard
What is Error code 66?
Error code '66' is a rare case. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy Pull up older posts. Surf the site with patience.
Error codes, and LED blinking codes to many popular brand remote controls are given.
May 06, 2014 | Mitsubishi WD-Y657 65" HDTV
Eror code 66 how to fix it
you might want to unplug the set and plug it back, my list does not show a code or error code 66 for this set. Power it up and let it fail and check for the error, if the wrong model was posted here that may be the reason.
Dec 23, 2012 | Mitsubishi WD60735
Mitsubishi wd60735 error code 66
No such error code that I can find, try to unplug and let it fail again, then do the check again.
Dec 23, 2012 | Mitsubishi WD-60735 Projection Television
Lights 2 and 7 and constant beeping
Error code 66 is water pressure sensor.
66. (01000001) Pressure Transducer Error [Ptx Frequency > 90 kHz]
Note: this supersedes Fault code 65 from V41 Motor controller code onwards.
The Motor Control module has received signals from the water level sensor (Ptx)
above normal frequency values.
Primary Source: Motor Control module
Action: Replace Motor Control module
Dec 06, 2012 | Fisher and Paykel GWL11 Top Load Washer
What does an error code 66 mean on a noritz Model N-0751M
http://www.noritz.com/u/pages_from_field_manual_2010_12_09_pdf__adobe_acrobat_professional.pdf
The Noritz field manual says that error code 66 is Bypass Water Control Valve failure. Call support at 866-766-7489 with your model #, serial # (both on the unit face plate), date of purchase, to see if the valve can be replaced under warranty.
Jul 14, 2012 | Water Heaters
Machine says "I need service"
I took this from the service repair manual. Hope it helps.
HI error code 66 means you have a pressure transducer out of range error.This means that the control module is faulty and needs replacing.please confirm that the error code is numbered 66. On some machines the pressure switch is seperated and sometimes the plastic tub for the switch gets clogged up and blowing through it will sometims clear this fault. Not sure about this particular machine, but you can try adjusting water level to see if it will work at a different level of water.
Mar 24, 2011 | Fisher and Paykel (IWL12)
Hello -Just looking for help on fixing a service code 66 which comes up when you turn the power on. Unknown age on machine. Fisher and paykel intuitive eco model IW811
HI error code 66 means you have a pressure transducer out of range error.This means that the control module is faulty and needs replacing.please confirm that the error code is numbered 66.Please reply for further help and clarification of this fault code.Hope this helps.
Jun 02, 2010 | Fisher and Paykel Fisher Paykel Intuitive...
2010 yamaha r1 shows fault codes 66 & 70. what do these codes represent. thanks.
CODE 66: "Open or short circuit of steering damper solenoid lead."
Check the ESD fuse has not blown first befoe checking the wiring itself.
CODE 70: This model is equipped with an engine auto-stop system. The engine stops automatically if left idling for 20 minutes. In this case, the multi-function meter indicates error code 70, but this is not a malfunction. Push the start switch to clear the error code and to restart the engine.
Hope this helps
Apr 19, 2010 | 2008 Yamaha YZF-R1
Washing Machines Logo
144 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
