Question about Acer Computers & Internet
External monitor cord loose connection on pav70
Screen is broken so the only way to use it is to connect it to an external display but the connection is loose and I've tried taking the laptop apart and pushing the connector out,drilled small holes for the cord to be secure&it worlks but I have to push it in really hard and not move or it changes colors a bunch then screen says no cable, I'm limited on funds do u have an easy fix for this prob?
    Top Expert:
  • Acer Master
  • 25,696 Answers
Replace the screen is the best answer.
http://www.ebay.co.uk/bhp/acer-aspire-one-pav70-screen
Posted on Feb 11, 2014
SOURCE: external monitor connection
Try the keys at boot up.
Posted on Jan 16, 2008
ceezer
  • 20 Answers
SOURCE: how to connect my compaq presario V6000 to my dell monitor.
try hitting Function (FN key next to the control) and F7 at the same time on the laptop. Also, is the dell monitor's input set to VGA (some have multiple inputs like DVI, VGA, HDMI, etc)
Posted on Jul 08, 2008
tleeski
  • 29 Answers
SOURCE: D800 laptop will not display on external monitor
Most laptops go into standby mode when the lid is closed. To stop this, (Windows XP) click Start, Control Panel, Performance and Maintenance, Power Options, then click on the Advanced tab, select "Do nothing" in the drop-down for "When I close the lid of my portable computer"
Posted on Feb 12, 2009
bob_computer
  • 3153 Answers
SOURCE: connect broken laptop screen to external monitor
I would back mothmans answer 100% but might suggest you re-assemble the display to the laptop if you continue to have problems getting an external display going.
Posted on Sep 07, 2009
nanbuenbrazo
  • 553 Answers
SOURCE: Gateway W340UA laptop - no display...
Sometimes it di happen , specialy in most laptop which is being used more frequently and longer usage, the advisable use of a laptop is atleast 2 to 4 hours then shut it off and have cool down for 30 minutes to one hour then you can used it again, unless you got a support inclined base for laptop with support ventilating fan to help down minimize the heat accumulated during the usage.
have it check your video card with the proper technician, but first try to cool down your unit and try to open it again, and if still does'nt work then have it check by the service center
Posted on Nov 03, 2009
My Sony Vaio VPCF12Z1E starts, but no image on display?
Did you try connecting an external display? If the external display works then there is a problem with the laptop screen and it needs to be replaced.
Jan 23, 2013 | Computers & Internet
Laptop turns on but screen dose not
First, connect an external monitor, turn on your laptop, then pres fn+f5 or f7 button to switch signal to external monitor.
If it's not working, then your motherboard (if your video card is integrated), or your video card should be replaced.
If external monitor is working, than you have problem with connections from motherboard to display, or display itself.
Broken video cable (or cable has come loose from the connector), broken lid switch, display backlight or inverter.
Hope this will help you...
Nov 17, 2012 | Toshiba Satellite Pro L450-136 Laptop AC...
Dell laptop not detecting external display
Usually the external monitor and laptop screen toggles in one of three states.
LCD only
External monitor only
Both LCD and external monitor
Wait a couple of seconds between when you press Fn F8
This model laptop may not allow ectended display.
May 29, 2012 | Dell Latitude D830 Laptop Computer PC...
I have verticle lines on my screen and is changing color
Typically, when you see that it means the connection is being broken between the graphics card and the LCD screen. Unfortunately, you have to take apart the laptop to diagnose the connection problem. Often it's just a loose connection socket; some laptops are easier than other to gain access to the graphics module. Most of the time it is located underneath the keyboard.
Nov 15, 2011 | Toshiba Satellite C655-S5068 Notebook
My samsung laptop has a screen problem coz its screen turns to white(nothing you can see) then I connect the power supply (adaptor) I did also use the system recovery cd but the problem still not solved,...
Hello:
This is a hardware problem.
1.- Try to connect an external LCD screen (like a T.V) or CRT monitor using a HD15 VGA cable, switch to the external screen. You should use Fn + F5 to switch between screens. (See your Samsung keyboard for exact key combination). If image comes out, your motherboard has no problem.
2.- The internal cable connection to the mainboard may be loose. You need to take apart the display panel to check it out.
3.- If you can see light on the lcd screen, that means your lcd inverter works fine, so, the lcd screen is damaged. You must replace the lcd screen.
4.- If you can't see any light on your screen, your screen inverter needs to be replaced.
I hope this helps. Thanks
Feb 08, 2011 | Samsung NC10-14GW Notebook
My LCD monitor is white when i work?
I can tell that this problem may be related to the following:
1. Loose connection between the video cable and the LCD screen.
2. Defective LCD screen.
3. Defective motherboard (I assume the graphics card is integrated into the motherboard).
Most likely you still can use the laptop with an external monitor. Just connect the monitor to the VGA port on the back or side of your laptop and then switch the video output from internal to external mode.
On Toshiba laptops you can toggle between internal and external screens using Fn+F5 keys. Hold down Fn and press on F5 until you get video on the external monitor.
On IBM laptops use Fn+F7.
On HP laptops use Fn+F4.
It's possible that you have to use a different key combination on your laptop but you get the idea.
On some laptops, in order to be able to use the external monitor, you have to connect it to the laptop and then restart the laptop so the external monitor is detected by the laptop.
I noticed that in some cases the laptop screen may turn white because of poor connection between the video cable and the LCD screen. If you want to check this connection, you'll have to take apart the display panel because the connector is located on the back side of the LCD screen
Reconnecting the video cable may fix your problem.
If reconnecting the video cable doesn't help, most likely you have a problem either with the LCD screen or with the motherboard
The best way to find out witch one is causing the problem is testing the laptop with another working LCD screen. Without this test you'll have to guess because as I mentioned before this could either bad motherboard or bad LCD screen.
You'll have to disconnect the video cable from the LCD screen (connector 2) and the inverter board (connectors 3 and 1). After that you connect another working screen and test video.
Hope it helps, else you will have to send the system for servicing to the manufacturer
Regards
Jan 27, 2011 | Acer Aspire 4315 Notebook
When I power up my laptop the screen does not show anything. It is just white screen no windows log or bios when the computer is booting. I can connect an external monitor to the laptop and the see that it...
You've got a loose connection between the laptop and the internal screen. Take the computer to a qualified technician, tell him/her the symptoms, especially the part about the external monitor working fine, and pay the technician to fix it.
Oct 27, 2009 | Acer Aspire 4315 Notebook
Connect broken laptop screen to external monitor
Suggestion- on my toshiba fn-f5 switches display modes, but to remove display connectors, you may have messed up your keyboard ribbon cable connection. it probably has a small sliding lock to hold it in place- if the lock isn't tight, your keyboard may not be recognized, which could mess up your display. Also, make sure your battery is charged and/or your power supply to your laptop is connected. hope this helps!
mothmanmeg@gmail.com
Sep 06, 2009 | HP Pavilion dv6000z Notebook
HP Pavilion laptop screen has gone black/blank
You can either use an external monitor for working with the laptop or talk to HP for replacement.
The best option is to use external monitor to backup data before sending it to replacement.
Good luck
Jun 22, 2009 | HP Pavilion dv6835nr Notebook
Lcd disolay has liens through it and colors are off.
If tapping the screen (on sides or back of case - not the screen itself !) affects the display it is usually loose connections either at the motherboard or behind the display where ribbon cable connects. relatively easy repair for someone who can take apart a laptop but you need the repair manual because there is a sequence that needs to be followed.
Feb 19, 2008 | Acer Aspire 5100 Notebook
Computers & Internet Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
