Lavadora bosch waq2447pee codigo error e17 - Computers & Internet
blueextc3221
  • 15935 Answers
SOURCE: la lavadora no funciona sale codigo Lr
The LR error on your non-spinning Maytag Neptune is usually, though not always, accompanied either by a burn spot or a blown fuse on the Motor Control Board.
Maytag upgraded the motor and motor control board because this problem was so prevalent. Big rash of these a few years back... and insludes replacement instructions with the kit.
The LR code means "locked rotor" - the control is not seeing the motor turning.
The image below contains the wiring diagram for this washer as you requested but there are some other things to consider.
Usually when the LR code is displayed the motor has stopped turning for some reason.
By definition the LR code means the control has tried to turn the motor but was unable to.
The error code can be caused by to large of load, to much soap/suds in the water or a problem with the spin bearing.
The cause of the LR message can be little problem like suds or a major problem like the spin bearing and sometimes it's difficult to pin down.
You don't mention in your question if the LR code occurs every load or once a week.
Try running a rinse and spin cycle empty and see if the washer completes the cycle.
The 2nd image contains the information on how to enter and run a diagnostic cycle which may help pin the source of the problem down.
This test completes all functions of the washer is a short time. It will fill, tumble, drain and spin all is a few minutes.
At the end of a successful test cycle a PA should display which means "Passed" and is what you want to see.
Image 1: http://media.fotki.com/1_p,sqwrrqkkqkstsftxgtqsskgwtqkq,vi/kkwrfdskkxkgbffwfww/1/1303472/5961857/image53872img-or.gif
Image 2:http://media.fotki.com/1_p,sqwtrsgdwsqtqsqxgtqsskgwtqkq,vi/kkwrfdskkxkktggsfsw/1/1303472/5961857/image53908img-or.gif
From another source...
"Installing replacement motor, motor control harness, and motor control circut board.
Pretty easy install. On a scale of 1 to 10 I'd call it a 3.5.
If you can use a screwdriver, a wrench, and have played with legos before, you can probably do this job.
It took me about 3 hours to do, but this was with inferior tools, and two smoke breaks included.
Minimum tool requirements: Adjustable-head cresent wrench (8 or smaller handle), phillips head screwdriver, utility knife.
Recommended tool equirements: Small ratchet with socket set, ratcheting screwdriver with phillips head and small socket attachments, brew.
The instructions are pretty clear.
Once you pull the front panel off, there are two braces at 45 degree angles on the lower corners of the washer.
The instructions don't ask you to, but I would remove the brace on the left to make life easier.
This gives your arm more room to work and makes it easier to pull the motor out the front.
They ask you to remove the wiring harness from the motor first and then pull the harness out with the control board.
My wrench was too big to get to the bolt to remove the harness from the motor.
All I did was cut the harness - since they supply a new one - then pull out the control board, then pull out the motor.
As far as getting the pulley off, slip it on and off at the large wheel, this is much easier than taking it off at the small motor drive shaft.
The only other thing of note is to make sure you look at the diagram for the conectors a few times before you snap it together.
There are a few ways you could hook it up wrong so pay attention. There should be no loose ends when you finish.
Also, I couldn't get the flange back on on the rear acess panel when closing it up, but it doesnt seem to serve muc purpose besides asthetics, so I tossed it.
The $200 for the parts and shipping was well worth it. I saved about $150-250 to do it myself...."
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question $#$Er
Posted on Oct 01, 2010
ZJLimited
  • 17970 Answers
SOURCE: yo tengo en la lavadora el codigo f-21 what is
F21 de error se muestra cuando la lavadora no se puede drenar, pulse Pausa / Cancelar dos veces para borrar la pantalla. Despu?s de esto, por favor revice la manguera de drenaje y filtro de la bomba de drenaje para los bloqueos y asegurarse de que no est? obstruido con part?culas extra?as. Tambi?n puede consultar la bomba de drenaje para verificar que su funcionamiento.
Si necesita m?s ayuda, consulta otros consejos en este enlace: won_39_t_finish_cycle_21_f_flashing
Esperamos que esta ayuda le sirva (recuerda votar y comentar esta respuesta).
Posted on Jul 25, 2011
SOURCE: e17 error code
Got an E17 Error today on a Bosch 6450 Series washer (the user manual says Bosch Vision 300/500/DLX series). Here's what I did to fix the problem.
- Tilted the unit back, propped up the front with some 2x4 (lying flat; that's all the room I had).
- removed 3 screws (Torx 20 I think) under the front lip. Then slid the cover (below the washer opening) down. This revealed the pump to empty the washer, a manual door lock opening pull rod, and a drain line (?)
- Looking through some holes in the front panel I saw some water on the bottom of the washer... but I spent a lot of time with the pump cleaning it out first (some zipper pull got in there and made a lot of plastic shavings). - Ultimately I got my hand the bottom of the washer and soaked up the water that I could find. That's when I realized
- there is a micro switch mechanism at the bottom near the front. This must be the "AquaStop". The mechanism contains a bit of styrofoam that floats up on any little amount of water that collects under it and triggers the microswitch. So, I removed that unit, wiped the water up... put it all back together. No more E:17 error.
Still don't know how the water got there in the first place though.
Posted on Jan 01, 2012
emirmv198320
SOURCE: lavadora whirlpool duet sport me
mi lavadora duet sport aparece f28 que le puedo hacer
Posted on May 30, 2012
gopakumarg43
  • 75289 Answers
SOURCE: Por favor donde obtengo los codigos de errores de lavadora IPSO mod CW8.URGENTE
If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common set-up codes to check with TVs and other devices are given, in the order of the "device's brand name list" in alphabetical order. Pull up older posts.
http://electro-medical.blogspot.com/
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Search the site by type in the brand name to your device, in the "Search box at the top right of the display window" to see the set-up codes to your device, with different brand remote controls.
Posted on Dec 07, 2015
Hi we have a Bosch Exxcel 7 with E17 error code. We've checked filter and pressure. Any ideas??
E17 indicates that water is leaking and getting into the bottom of your machine
Feb 23, 2017 | Bosch Washing Machines
How do your error E17 on a Bosch Maxx 7 varioperfect.
Hi Kerry, The same question was asked on this site back in March 2009 !! and the link below has an answer..... CHEERS..
E17 error code Fixya
Apr 04, 2016 | Bosch Washing Machines
I have a bosch lifestyle dishwasher that keeps coming up e17...we have had plumbers around and there is no problem with pipes or water so what else can it be
You did not specify the model so I can only assume what means the alarm code E17 - probably water level too high - flow sensor.
The dishwasher has, for some reason detected an overfill and is reporting that through this error code. The flow sensor note is there as that can cause this fault code to be displayed.
Dado
Jul 10, 2015 | Bosch Dishwashers
Tengo una lavadora electrolux maxi clean y me manda codigo de error e4 que tengo que hacer
Buenos dias tengo una lavadora maxi clean que no centrifuga y los demas ciclos los hace sin problemas, como le reviso l control de nivel por que la bonba suena como si tubiera agua la tina por mucho rato.
Gracias
Nov 03, 2010 | Washing Machines
I just bought my washer today and it won't finish the first cycle. It is showing "E17" and won't drain. What does "E17" mean and how can i fix my washer. Help!!
When the washer shows error code E17 you need to turn the tap fully on and check that the supply hose is not bent or jammed up, next make sure the filter is clean. Then make sure the water pressure is not too low. After you do all that, run a load with no clothes in the washer and use one cup of white vinegar and the code will dissappear
Nov 19, 2009 | Bosch Washing Machines
Computers & Internet Logo
David Payne
David Payne
