Question about HP Laserjet Pro Cp1525n Color Printer Laserjet 600 X 600 Dpi Laser
Colours not calibrating
When i print the colours do not align...so print out quality not showing. when i check status levels, yellow and magenta not falling in the box...changed chips but problem still persist
  • HP Master
  • 783 Answers
Hi Selorm,
i suggest you Go Visit Colours not calibrating Solution Video
OR
In Case You Still face Problem and Need Online Assistance Then Please Follow Us For On : HP Printer Support
Posted on Feb 11, 2014
jilpeshpatel
  • 259 Answers
SOURCE: newly replaced original magenta toner not printing
Dear this printer is solve this problem just
chnge the magenta toner scaner ok ........after that is working but ...do not any idea about this just call me :+91-09328015664
and Email:support@compudesk.in
Posted on Jul 14, 2009
SOURCE: When I calibrate colour Magenta and Lt.Cyan fail to print
boil the head printer in a hot water for ten minutes and wiped it smoothly
Posted on Aug 09, 2009
  • 3 Answers
SOURCE: HP Color Laserjet 2600n Color Alignment
I own a HP 2600n and I had the same problem the way I fixed it was hold both arrow buttons in the turned off the power for 10 seconds while holding the buttons in then turned it back on then released after 3seconds the reset my defaults this cured my problems
Posted on Nov 12, 2009
  • 217 Answers
SOURCE: We use HP Color Laserjet CM1017; Magenta color is not printing
Dirty laser unit - needs (careful) cleaning internally.
See ' Printing Weak Magenta', 'Printing Light Magenta' for HP CM1015, HP Color Laserjet 1600, 2600, 2605.
All the same laser unit
Posted on May 09, 2010
  • 17 Answers
SOURCE: The Magenta colour on my 2605dn is no longer
A faded magenta on this model is probably a dirty scanner mirror.
The printer design puts a fan in an area that blows magenta toner directly at the laser scanner.
The more toner on the mirror, the more faded the print.
You will need to remove the scanner and clean it.
Posted on Nov 03, 2010
Testimonial: "Thanks, very helpful. Found a guide on how to do this so will have a go at it tonight!"
Tried to print something today after not using printer for about 3 weeks. First go all colours were present but streaky. Did the nozzle alignment but on testing found that Magenta was completely missi
Hi Mandy
1) confirm there is ink in the magenta cartridge first - by removing it from printer and looking through the ink 'window'.
If you can't see the ink level, it's either empty or very close to it. If so, replace the cartridge.
2) If ink level looks ok, install it back in printer then set out a full page of magenta (or red) background or large graphic and print few pages on high print quality setting until the magenta starts to print. This works better than printhead cleaning/deep cleaning because it wastes less ink.
3) If it still doesn't print red after 2-3 pages, the printhead is blocked. Take it out and rinse under hot water tap. Keep washing it until only clean water is coming out. Shake any water off then DRY the electrical contacts really well. Don't install a wet printhead back in printer - or you may damage it. Run one or two deep cleans and print a nozzle check. With bit of luck all colours will work now...
good luck!
Jan 13, 2015 | Canon Pixma iP3600 InkJet Photo Printer
My canon irc 3200n is printing shaken images
Difficult to say without seeing the quality of the prints but sounds like a calibration issue. By shaken to you mean that colours have fallen out of line and are leaving outlines on your prints? Possibly giving it a 3D-like effect?
If so I would recommend running a few calibration/alignment cycles from the printer or printer software to bring all the colours back into line.
Aug 07, 2013 | Brother DCP 115C All-In-One InkJet Printer
Horizontal lines. Xerox 6505DN
clean the print heads and align them
Sep 10, 2012 | Xerox 6505N AllInOne Printer
My out of warranty l7680 will not print or photocopy in colour. Printhead status says Refilled supply Detected in printhead Black No/Yellow Yes Magenta Yes/Cyan Yes Detected in Printer Black No/Yellow Yes...
The error states that you are using non-HP cartridges for all colours. If black prints fine then you should replace the colour cartridges with genuine HP colour carts. You should be able to get a refund on the refills since they clearly do not work as intended.
May 25, 2010 | HP Officejet Pro L7680 All-In-One Printer
Printer keeps showing Office Jet 8500 Wireless
The printer wants to align the print cartridge, if you print out the alignment sheet, and then following instruction, place on scanner and scan it in etc, and it fails to callibrate, I have found it is because some of the information on the calibration page is not being printed correctly so therefore machine cant calibrate the print heads from it, this is normally due to poor quality cartridges or failing/empty print cartridge or cartridges, these use two I think, and I bet one of the colours from the colour isn't printing properly, replace colour cart if blacks look good. Below is a link to HP so you can see what a alignment page needs to look like to pass calibration, compare yours and you may find a colour is dodgy on it.
see HP's support information
Nov 12, 2009 | HP OfficeJet 7310 All-In-One InkJet...
I have a used C60. I have replaced both ink cartridges with Epson cartridges. When printing in color, the colors are not accurate. For example, red comes out yellow. Also, there are lines running through...
Hi there. The reason for your problem is that the colour cartridge contains cyan, magenta and yellow ink, plus a black cartridge of course. All the other myriad colours are produced by mixing these four basic colours. So, if you print red, it requires ink from both the magenta and yellow cartridges. Thus if your red produces a yellow print, it means your magenta is not printing. This can be due to a number of reasons, mainly an empty or faulty magenta cartridge or blocked magenta print nozzles.
If you wish me to help you with sorting out the lack of magenta, please post a new comment to this effect.
Mar 04, 2009 | Epson Stylus C60 InkJet Printer
HP 840c Printer - Print quality problem.
I have no magenta trying second cartridge still same problem
Jan 14, 2009 | Apple HP DeskJet 840c InkJet Printer
Jagged edges and misregistration
What printer is it ? Some older ones need manual calibration, where patterns are printed, then you tell the system which is the best one. Newer ones can self calibrate, but still need it done. Go into your printers menu and see if you can find something on calibration or allignment.
Jul 18, 2017 | Konica Minolta bizhub 350 All-In-One Laser...
Konica Minolta 5430DL error code 111112
I couldn't find the install disks so downloaded the driver from the Konica website, un-installed the software and re-installed it. After calibrating the colours everything seems fine now.
Oct 01, 2008 | Konica Minolta magicolor 5430 DL Laser...
Won't print red
Red is a combination of Magenta and Yellow. Print a nozzle check and observe for Magenta, Yellow and cyan. If the three colours are printed, no problem with the cartridge. Then it must be the problem of seeing colours in your monitor. .
May 02, 2008 | Canon PIXMA iP2000 InkJet Printer
HP Laserjet Pro Cp1525n Color Printer Laserjet 600 X 600 Dpi Laser Logo
94 people viewed this question
Seeker5211
Seeker5211
