Question about Xerox WorkCentre 6015Ni Printer
Paperjam error stays on display - Xerox WorkCentre 6015Ni Printer
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 99 Answers
Open door & close it after replace any jamed paper inside machine
Posted on Mar 19, 2016
Paper jam printer
kindly check it what shows in the display:
"paperjam 0" , its related to pick up roller related problem.
"paperjam 1", its related to cartridge unit, kindly re inserted the cartridge.
"paperjam 2", its related fuser unit, kindly open the rear cover of printer, ther you can see the fuser unit. check the one liver from fuser unit to HVPS .
kindly check all these things and contact
Jan 29, 2014 | Samsung SCX 4521F All-In-One Laser Printer
Error paper jam
It is possible that there is a little peice of paper that has ripped off of the sheet that was jammed. Was the sheet whole when you removed it? If not, check the location where the paper was jammed for bits of the last sheet of paper.
Sep 17, 2013 | HiTi P510L Photo Printer
My canon mp190 gives E3 paperjam error but there is no paperjam how do i fix it?
I have solved this problem with read post at http://slayo.com/how-to-fix-error-e3-canon-mp198-printer.html thanks to slayo.com "Canon MP198 Printer Error E3 is becaused something inside of the printer that makes paper sensor not function properly. To fix this error E3 you must open inside of the printer to remove the things." you must open your printer to remove the things, maybe waste letter or other small part things. Read the post for complete it.
May 18, 2010 | Office Equipment & Supplies
Error code 6A00 what is it how do you fix it? this is what is displayed on the printer. I had a paperjam last night. I removed the paper and it worked ok. This morning it displayed this error message and...
6A00 is AP position error.
First, make sure there is no paper jam anywhere in the machine.. look inside, rear, where the paper tray (output) is, etc to see if you find any shreds or torn paper that may have gotten stuck and you didn't see.Look carefully in the zone of Purge unit, using flashlight in the right side on printer.If this not help your printer need service.
Oct 28, 2009 | Canon PIXMA MP830 All-In-One InkJet...
My printer says there is a paperjam but I don't see a paperjam.
its a mechanical problem ...
check the rollers of the printer ..and the paper pick mechanism ..maybe it can't caught the paper in the tray that why it display an error of jammed..
May 24, 2009 | HP DeskJet 3653 InkJet Printer
LCD SAYS PAPERJAMMED
try to clean and oil the print head sharf. and clean the miler strip. this is the plastick pease with the black lins on. at the back of the print head carige
Feb 10, 2009 | Samsung SF-330 Plain Paper Inkjet Fax
Tally 2280+. While printing, goes offline and displays paperjam.
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Dec 29, 2008 | TallyGenicom 2280 Matrix Printer
Paperjams
Sounds like the pick up rollers are worn or dirty.
You can try to clean them with alcohol.
When you pull the tray out the rollers
should be towards the front of the printer.
Nov 21, 2007 | HP Color Laserjet 3550 Printer
Printer
Sometimes just a teensy bit of paper stuck inside will make it say paperjam. I would check very well.
Dec 11, 2006 | Canon I900D InkJet Photo Printer
Xerox WorkCentre 6015Ni Printer Logo
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
