Question about Microwave Ovens
Kedu JD2 wiring diagram
I need a wiring diagram for a kedu JD2 relay switch (on/off) that is used on a thickness planer
Diagram of relay switches for firgidaire microwave
Hello friend, thank you for your inquiry!
I see your question is labeled under the model number FMV156DC. Per that model I have located the wiring diagram. I hope this information has been helpful. -Matt
Frigidaire Manual Search Results
Oct 10, 2014 | Frigidaire FMV156DC Microwave Oven
Jes1451bj02
That is most likely a failed door switch or its mount may be loose, misaligned or broken.
It's most often caused by opening the door while it's cooking instead of hitting "Stop" first, or slamming the door.
It would either be the top or bottom switch, whichever one has the thicker wires, probably black wires.
(Sorry, but I don't have the wiring diagram on this model and the door sense switch [not a suspect] will have thinner, more colorful wires).
See these help files first:
http://031d26d.namesecurehost.com/mwd/safety.txt http://031d26d.namesecurehost.com/mwd/disassembly.txt
Then my help file on door switches:
http://031d26d.namesecurehost.com/mwd/doorsw.txt
You can find helpful exploded view diagrams and order parts by entering your full model number (JES145BJ02) here.
May 22, 2013 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave not heating
OK, get ready, this micrwave oven repair can take some time. This is where you must be able to read a wiring diagram and do some "live" checks on parts. First easy check is to make sure power is coming off your control board at the MW relay. Make sure of the wires and test here, if you have 120 volts at this point, you have ruled out a lot of parts that could be the problem. You have now ruled out any switch problems, control board problems, or a thermostat or 2.
If you do not have power from that MW relay on the control board, you must trace the wiring back to see if the proper voltage is going through your switches, any thermostats, and arriving at your control board. Your wiring diagram on your sheet will show you where and what to test. Below is a general switch test troubleshooting guide.
mwswitchtest2.jpgIf the proper voltage is coming into your control board and you are not getting voltage at the MW relay, then you need to replace the control board. If voltage is interupted by a thermostat or switch from your testing to the control board, then replace that part.
Now, testing from the MW relay on to your transformer, high voltage capacitor, magnetron, and diode.Do not do any voltage reading from the secondary side of the transformer on, this can be a deadly microwave oven repair if you do not follow directions. This can result in electrocution and the "blowing-up" of your voltmeter, only do OHM testing with the power off and the capacitor discharged. Someplace in this circuit, usually before the transformer, you will have another thermostat to test. It is usually mounted on the magnetron. Do a quick OHM test to see if it is open or closed.
Now to test either the transformer, high voltage capicitor, magnetron, and diode, you must test each part separately. A good rule of thumb, if your capacitor is bad, change the diode also. Another note, if you are working on an OTR model and you have determined to be one of these "heating" circuit parts, you can not test these parts until you take the unit down. If you don't have the parts with you and you have to order them, order the magnetron, capacitor and diode and you will have a 90% chance of solving the problem. If it is an older microwave, order the thermostat also, most times you can return un-used, un-opened parts. Check with your parts supplier. This way you only have to take the unit down once.
To test these parts, scroll down this page and you will see a chart with component tests. Follow the instructions to find which part(s) are defective in your microwave oven repair.
use the VOM. God bless you
Apr 04, 2013 | GE Profile Spacemaker XL 1800 36 in....
TMTSS2011
use VOM and test it. God bless youOK, get ready, this micrwave oven repair can take some time. This is where you must be able to read a wiring diagram and do some "live" checks on parts. First easy check is to make sure power is coming off your control board at the MW relay. Make sure of the wires and test here, if you have 120 volts at this point, you have ruled out a lot of parts that could be the problem. You have now ruled out any switch problems, control board problems, or a thermostat or 2.
Apr 04, 2013 | Tricity Bendix Microwave Ovens
How fo I replace an integrated relay?
1( you must need skill for solder
2( need the station with pencil solder+resin
3( gum ****** for extract the resin when you are desolderint the i.c Relay
4( be carefully to do it. you must use too wrist for to avoid ESD.
God bless you
Sep 09, 2012 | Kenmore Microwave Ovens
Look like is gona work but,i click start is not work
please see the next topic:
Microwave Runs, but no Heat OK, get ready, this micrwave oven repair can take some time. This is where you must be able to read a wiring diagram and do some "live" checks on parts. First easy check is to make sure power is coming off your control board at the MW relay. Make sure of the wires and test here, if you have 120 volts at this point, you have ruled out a lot of parts that could be the problem. You have now ruled out any switch problems, control board problems, or a thermostat or 2.
Sep 07, 2012 | Microwave Ovens
Power on but no heat
see the next step:God bless you
Jul 26, 2012 | Sanyo Microwave Ovens
Trouble shooting
see the next step and proceed with common sense: God bless you
My old GE oven (JSP38G052BG) won't bake or broil. It start then stop after 1 or 2 minutes. The heating elements get worm. Can you help me please
Hello ediben11.
If your oven's bake or the broiler heating elements won't heat but the range burners still work;the clock may be set for a timed or self-cleaning cycle. So,make sure to check the clock buttons and the knobs are set properly.
*If your clock has a knob that says "push for manual" then push the knob in after that, try the baking and broiling elements again.
*If it still does not work properly, you may have a defect in the thermostat/selector switch/common wiring.
*If the oven does not have a separate bake or broil selector switch; then the thermostat is probably the problem. It is not easy to check the selector switch or thermostat for proper operation. If you suspect a problem in this area, call a qualified appliance repair technician.
Hope this helps.
Mar 23, 2010 | LG LMVM1945 Microwave Oven
Microwave Ovens Logo
296 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
