Question about OKI C Office Equipment & Supplies
The drum unit life is saying 0% remaining what do i do
timeattack
SOURCE: Replaced new drum unit but LCD keeps saying Drum Near End of Life
Front cover must be open
Press The "Clear" key on the top panel
Press 1 to reset the drum count
Close the over
Posted on Feb 06, 2009
  • 1684 Answers
SOURCE: cannot reset drum counter after fitting new drum
Instructions for resetting the drum count can be found on our web site at:
www.ccl-la.com/brother.htm
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Posted on Jul 03, 2009
komguy
  • 2306 Answers
SOURCE: Drum life remaining
All you need to do is open the front door and press either the options button or menu button, whichever you have, it will ask you if you changed drum, just answer yes, and you're good to go...
Posted on Sep 14, 2009
pineworks
  • 4041 Answers
SOURCE: OKI C8600 Replace Image Drum - 563: K Drum Life
Solution:
  • Power on printer while holding both the + & - buttons simultaneously; release when “OKIUSER” is displayed.
  • Press either the + or – button until “ENGINE DIAG MODE” is displayed; press the Enter button and “DIAGNOSTIC MODE xx.xx.xx” will be displayed.
  • Press and hold both the - & On-line buttons simultaneously until “ENG DIAG LEVEL2” is displayed.
  • Press either the + or – button until “CONSUMABLE COUNTER SET” is displayed, press the Enter button; you are now in the menu to set various consumables.
  • Press either the + or – buttons to scroll through the various consumables, at the desired consumable press the Enter button and the last digit of the count will start flashing.
  • Press the Cancel button to decrease the digit amount or press the On-line button to increase the digit amount; press the + or – buttons to move along individual digits in the count.
  • Once the count is at the level you desire, press and hold the On-line, Cancel, & Back buttons simultaneously until the “*” reappears next to the count; consumable’s count are reseted to the number you specified.
  • Press the + or – buttons to move to the next consumable and repeat at step 5.
  • Once all consumable counts have been set to desired amounts that are below their end-of-life thresholds, you can use the Back, +, & - buttons to exit through the menus
  • until “INITIALIZING” is displayed.
Posted on Jan 30, 2010
SOURCE: oki 5150 color are not print right
You need to replace the magenta drum. Just because there is life left; it's possible it is scratched. Also, take a cotton ball dip in alcohol and wipe the LED's off when the cover is open; those black things that are hanging down from the cover. Also, make sure your drums are installed in the proper spots (magenta in magenta slot). If the toner "rubs off" after it prints... then the fuser is defective.
Posted on Jul 23, 2010
Drum 0% Remaining?
you need to install a new drum and then reset the drum counter:
1.- Open front door
2.- Change the drum Unit
3.- Press Go button and keep pressing until the 4 lights turn on
4.- Release the button and close the door
Oct 30, 2013 | Brother HL 2140 Laser Printer
HL-5250 report shows fuser and laser life at 0% and PF kit 1 at 12%
The fuser is a separate component to the drum and toner in this printer. It has a much longer life than them but will run out eventually. Sadly a fuser unit is not a commercially available consumable for this printer either. I would recommend contatcing a printer technicain or Brother directly for a quote on replacing this part.
Apr 12, 2013 | Brother HL 5250DN Laser Printer
I want to change the setting of my drum unit on a konica minolta C-360
Enter in the service mode by press following keys:
Utility - Meter count-Check details - Stop - 0 - 0- Stop - 0 - 1 - Stop -0 -C - setting IU life stop setting and select NO STOP.
Feb 20, 2013 | Konica Minolta bizhub C250 All-In-One...
How do i reset ricoh sp 1200s drum unit
why toner life end message keep on showing on sp 1200s prints.
Aug 04, 2012 | Ricoh Office Equipment & Supplies
What does a "K Drum Life" warning mean?
Meaning the life of the k drum is near and you need to replaced it soon or later
other message like below need attention
ecblank.gif C DRUM LIFE REMAINING nn% ecblank.gif M DRUM LIFE REMAINING nn% ecblank.gif Y DRUM LIFE REMAINING nn% ecblank.gif BELT LIFE REMAINING nn% ecblank.gif FUSER LIFE REMAINING nn% ecblank.gif K TONER REMAINING nn% ecblank.gif C TONER REMAINING nn% ecblank.gif M TONER REMAINING nn% ecblank.gif Y TONER REMAINING nn%
May 31, 2011 | OKI C3200n Led Printer
Drum life remaining
Sep 14, 2009 | Brother DCP-7020 All-In-One Laser Printer
Oki 5150 color are not print right
Jun 25, 2009 | OKI C5150n Led Printer
Can smears when priting be fixed
Have you tried cleaning the corona wire on the drum unit (the blue slider bit)?
Replace the drum unit (assuming you have already replaced the toner cart?)
To check the remaining drum life press the go button 3 times. A report should print out with the info on. Even though you may have some remaining life, the drum can fail early.
If the dots/marks are repeating about 3 times down the page it is almost certainly the drum unit that has the problem.
Apr 16, 2009 | Brother HL 5250DN Laser Printer
The mfc9440cn i have is continuly saying that the belt unit and the drum need to be changed even though they have both been changed recently. Is this a problem with the printer or the belt unit/drum?
You probably need to reset the counter on the parts life. Depending on the machine you have - you can do a parts life check - but it will always read 0 part life left, if you haven't reset the counter...
Jun 18, 2008 | Brother Office Equipment & Supplies
13 people viewed this question
Top OKI Office Equipment & Supplies Experts
WTF Chuck.....
WTF Chuck.....
Jimbras
Level 1 Expert
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
