Question about LG WFT1071TP Top Load Washer
Mod.wf-t6517te de error
Washing ;spining display show de error
stradeteox
  • 88 Answers
SOURCE: help me to known
If you push in on the door does the error code go away? If so, then it may just need an adjustment. This is a door error code. Probably a losse or faulty door switch. If you are a do it yourself person you can try shimming out the door switch from the inside. You will need to take the top off of the machine to see if you have enougfh room to get your hand down to the switch where it is held on by 2 screws. If there is not enough room then you will have to also remove the door gasket, front control panel and then the front panel to get to it. It may be possible to put a few flat washers between the door switch and the front panel and then put the screws back in to pull the whole door switch assembly back a little bit (therby causing the door to shut tighter). If this does not stop the DE error then the door switch is bad and will need replaced. Your model number does not appear to be a US model, so I do not know the correct phone number for you to order the part if you need one. You will have to call LG customer service (for the country where this model was sold) to get the correct phone number if you need to purchase a part.
Posted on Jan 07, 2009
heatman101
  • 43501 Answers
SOURCE: LG washer Model wf-t6517te not draining water
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Posted on Aug 19, 2010
  • 3230 Answers
SOURCE: I am getting error DE
HI there,
Well most of the times problem is in the door lock may be it's faulty. or it could be the door lack has failed/is failing or the control board, try closing the door properly and see if it works....... If further you have the same problem then you need to change the door lock (switch).
Good Luck
Thanks for using FixYa!!
Posted on Dec 03, 2010
  • 500 Answers
SOURCE: My fuzzy logic turbo drum
Door Error. Could be that the lid gets bumped open while washing. Make sure it is secure, or it could be a loose connection on the wiring of the door switch itself. This feature is used to prevent small children from sticking their hands into the machine while it is operating, it switches of the working components as soon as an interruption is made with the Door switch.
Hope this helps.
Good Luck :-) - J.Q
* If you found this solution helpful, please vote positively.
Posted on Feb 16, 2011
  • 6277 Answers
SOURCE: I have a fuzzy logic 8.2kg top loader WF-8071TTP.
'de' does stand for Door Error. There is likely to be a problem with either the lid/door solenoid/lock or the 'lid/door closed' sensor becoming apparent with the extra movement of washing requiring a service engineer's attention I suggest ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Posted on Jul 13, 2011
Lg turbodrum fuzzy logic 7.0 wf t700 showing error code "de" what that is mean? And how to fix it?
Try unplugging power, push and hold power button for 5 seconds, then plug back in. See if error code is gone.
Nov 05, 2017 | LG Washing Machines
Lg washing machine wf-sp950g de ( door error )
Hi Azlan.
de Door Error usually shows when the door lock either won't undo...OR The machine won't start after the door is closed.
Both these situations probably mean that the door 'Interlock' is faulty.
The interlock is the part of the door lock which prevents you from opening the door while the machine is working.
It's part of the electrical circuit and should only be serviced by a qualified technician.
Good luck
Nomess
Feb 04, 2015 | LG Washing Machines
Lid open DE error in WF-T6517TE
This is lid magnet peice came out or lid assymble not fixing properway.
Mar 13, 2014 | LG Washing Machines
Lg wf 8071ttp
de is for door error not fit properly or door switch totally defective
call the technician for your safety and not to waste money.
Nov 01, 2013 | Washing Machines
Lg model number wf-t1246tp; error code dE appears on display. however, door is properly shut
'de' stands for Door Error. There is likely to be a problem with either the door solenoid/lock or the 'door closed' sensor. Both require a service engineer's attention I suggest ;-0(
Good luck,
John C
Mar 09, 2011 | LG Washing Machines
I have problem with lg wf-t507 top loaded washing machine when i start it work for few seconds and than show DE .
'DE' on an LG normally stands for 'door error'. It is possible that the door catch/sensor either requires adjustment, if that is possible on your particular machine, or will require replacement.
Sorry but you will need to call your local service engineer ;-0(
Good luck,
John C
Feb 27, 2011 | Washing Machines
heatman101
Aug 19, 2010 | LG WFT1071TP Top Load Washer
Lid open error in WF-T6517TE
it could be that the magnet in the door lid has slipped or fallen out. I stuck a new magnet on the rim of the machine and the dE eror message went away
Dec 13, 2009 | LG Washing Machines
LG WFT1071TP Top Load Washer Logo
15 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
