Question about Braun 8585 Electric Shaver
Open the shaver head
How to flip open the shaver head for manual cleaning?
3 Suggested Answers
SOURCE: Model 6550 electrc shaver how i can open case
I.fix problem
thanks
Posted on Oct 03, 2009
brector3
  • 1610 Answers
SOURCE: Braun Synchro 7526 Electric Shaver How do I open
You will find an instructional video at shaveroutlet.com. See link below
http://www.shaveroutlet.com/braun_syncro_shaver_disassembly
You will also find compatible batteries at the link below
http://shaveroutlet.com/shaver-replacement-parts/shaver-replacement-battery-aa-nimh-p-108.html
Posted on Nov 28, 2010
I have a norelco model 6701x that will not charge - the charger is good as it works on another shaver just fine. What would you suggest - have always been able to coax it into charging, or indicating...
Most likely, the batteries are dead and need replacing. You will find the correct batteries at shaveroutlet.com. See link below.
http://shaveroutlet.com/shaver-replacement-parts/shaver-battery-pack-for-most-norelco-more-p-278.html
To open shaver, remove flip up back cover then remove screws unserneath. At the page linked above, view helpful installation videos by scrolling down the page
Aug 11, 2011 | Norelco Health & Beauty
I've purchased new blades for my Arctic. they did fine until they got clogged. what can i do to clean my blades? this IS a problem. if i can't find a solution i can't purchase norelco again. please...
It's a hack, but you can use needle nose plyers to let you pry open those razor blade heads to clean the blades inside the heads. My Arcitec shaver stopped working after being clogged, rather than pay $50 for new blades, I just opened it up, took out the blades and cleaned it with an old toothbrush and soap.
803a8aba-577b-4dd5-b52e-ae7a2458bab2.jpg 5ad496c8-7607-44bc-a579-a1f98a4246fb.jpg c362edfb-fb3e-4c00-8221-99b8a095d1d7.jpg
Nov 06, 2010 | Norelco Arcitec Electric Shaver with Jet...
1.5 year old 7140XL worked fine, then next time would not turn on at all. Charge light shows charged.Any suggestions?
There are two likely possibilities. These problems would either be that the head is damaged or jammed or there is a loose connection inside.
You can easily test if it is the heads by flipping up the head assembly and then turn it on. If it runs with the heads flipped up but not when they are snapped down, you can assume that the heads are the problem and they will need to be replaced. You will find replacements for this model at shaveroutlet.com. See link below
http://shaveroutlet.com/norelco-philips-hq8-spectra-sensotec-replacement-heads-p-251.html
If the shaver will not run with the head flipped up either, you may have a loose connection inside...usually from the moto to the circuit board or from the battery to the circuit board. You may be able to locate and repair this but if your shaver is 1.5 year old, it is still under warranty. If this is the case, contact Norelco using the info in your user manual for the warranty
Jun 30, 2010 | Philips 7140XL Electric Shaver
Lost directions on how to use jet clean system. Do not know how to use it.
Visit this site below and enter your product number. If you don't have your product number or it doesn't appear, then type in "jet clean" then scroll down and click on personal care. You can then click on a jet clean model and then open the .pdf of the manual. The instructions should be similar. There is nothing to using it. Fill the reservoir with jet clean solution to the max line. Put the shaver in the cradle heads down and press the button on the front of the cleaning base. If it doesn't stay down and clean you may have another problem. If so, then search "Norelco Arcitec Electric Shaver with Jet Clean" on this site and you can find answers to your problems.
http://www.support.philips.com/support/sms_page.jsp?userLanguage=en&userCountry=us
Jun 09, 2010 | Norelco Arcitec Electric Shaver with Jet...
I do not know how to take each one of the 3 heads out in order to clean it
Hi. The shaver heads are not removable like on older models, you'll have to grip the grips on each side of the head and swing the top open to clean.
May 20, 2010 | Norelco Arcitec Electric Shaver with Jet...
How i clean my razor
I have this razor as well. Just flip the heads open, dump the hairs in the garbage and rinse the heads (while open) under hot water. Keep the heads open until dry and close on up.
May 20, 2009 | Norelco Arcitec Electric Shaver -...
How to disassemble Braun 4505 shaver. Cutter stopped working.
You want to go to this site and get a repair manual. http://web.archive.org/web/20041025223715/63.230.9.155/braun/Srv_Man/SHAVER/
Follow the instruction and remove the swivel head. Then remove the 2 screws at the bottom. I still have problem sliding the two side head support off.
Apr 08, 2009 | Braun 4501 Electric Shaver
Norelco shaver, 7310XL will not run with the headsdown in place- will run if open? The shaver is charged and all the heads are in place but when you close the heads down on the shaver - locked down...
Make sure that the comb and cutters have been dismantled and cleaned thoroughly. If they are jammed up with hair they won't work. Also check the surface of the comb and make sure there are no bumps or dents that will stop the head rotating.
Mar 25, 2009 | Norelco Health & Beauty
Braun 8585 Electric Shaver Logo
23 people viewed this question
Top Braun Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Braun Health and Beauty Expert? Answer questions, earn points and help others
