Question about GE Profile JGP636 Gas Cooktop
Continuously clicks when in off position - GE Profile JGP636 Gas Cooktop
Continuous clicking from an igniter in the off position. I have to slightly turn the control knob towards the hi position to stop the clicking and for the light on the control knob to go off
sounds like it was turned a little past the stop point.
Pull two knobs off and examine the back side that slides onto the shaft.
Switch them and try again.
If the problem is on the same burner, the shaft may be turned past its normal stop position.
You can try turning it until it stops in the opposite direction and force it just a tiny bit more.
That was how I fixed mine.
Nov 06, 2013 | DCS 36 in. CP-366 Gas Cooktop
After using the stove top and all the valves are shut, the igniter continues to click. Not sure which particular one, but I presume the right front, which is the most common used on the stove and the last...
One of the switches that turn on the spark when the burner is turned on has became stuck so even when the burner is turned off it still thinks its turned on. It very well could be the one for teh right front burner or any of the other 3 switches.
Depending on your mechanical ability its not too hard to figure out which one it is. What ya need to do is remove the panel over the burner valves so ya can get to the switches which slip over the stem of the burner valves and remove them in the off position and use a meter set to measure continuity and check each of the 4 switches when in the off position and see which one has a circuit (continuity) when off..when you figure which one has continuity when off that will be the one that is causing the stove to spark when off. Be sure to check all 4 since more than 1 could be bad.
BEFORE ATTEMPTING TO DO THAT AND CHECK WHICH SWITCH IS BAD BE SURE TO DISCONNECT THE POWER TO THE STOVE
GENE
Sep 16, 2011 | Jenn-Air 34 in. Expressions CVGX2423 Gas...
GE JGP 945 continues to spark. Removed all igniters but continues to click. Bad Spark Module?
no,its a bad switch on one of the gas valves,they are piggybacked on the gas valve and are supposed to turn on and off as the valve is turned on and off,on has broken and is on all the time even with that valve in the off position,carefully remove each switch from the circuit till it no longer sparks with all the valves in the off position
Mar 30, 2011 | GE Profile JGP636 Gas Cooktop
My ge monogram stove top burner( model zgu366h)continues to ignite. even after the flame is lit
If you are saying the clicking continues you must move the burner knob past the LITE position.
If it continues clicking with the knob past the LITE position the ignitor switch behind the knob is bad.
Nov 30, 2010 | GE Cooktops
My gas cooktop has just spontaneously started clicking (as if I were moving the knob to start the burner) on the front two burners. I have tried turning the knobs on and off, but the clicking and spark...
One of your burner switches is stuck in the ON position. On older models the switch itself can be replaced. On newer models the whole bunch need to be replaced. c2c8a4f.jpg
Oct 25, 2010 | GE Cooktops
My stove is making strange clicking noises. please help.
It sounds like the ignition knob is stuck in the "ignitor" position. Try taking it off, clean it and adjust it. If that doesn't work, it will have to be replaced with a new one. If yu leave it alone, it will probably wear itself out. Just make sure that the gas valves on the stove are in the off position so that they don't accidentally light on their own. Good luck
Jul 13, 2010 | Cooktops
Electronic ignition clicking on cooktop
one of the burner switches has shorted, and needs replacement. Turn the power off to cooktop, and check with VOM if there is any continuity on any of the switches when the y are in the "off" position. Replace the one which has continuity. Some GE cooktops have an assembly of all four switches and harness. Check by model number with any parts distributor.
Mar 03, 2010 | Cooktops
My GE Profile gas cook top was just cleaned. Now the starter keeps clicking and the only way we can stop it is to unplug the appliance. As soon as we plug it back in it continues to click.
if you have a multi meter you can figure this out. check to see if you have continuity through the switches while they are in the off position and unplugged from the spark mod. if you do replace the wire harness. if you dont replace the spark mod.
Dec 05, 2008 | Cooktops
Continual clicking of the automatic ignitor even when burners are off
some JA models i have seen the the spark switces are poorly constructed or improper installed from the factory and beging to become a probelm after a year or so of use. this is not a gas pressure issue it just plain ole' bad spark switches
Sep 05, 2007 | Jenn-Air 35 in. JGC9536 Gas Cooktop
GE Profile JGP636 Gas Cooktop Logo
82 people viewed this question
Top GE Cooktops Experts
Dan Webster
Dan Webster
Jim London
Jim London
Are you a GE Cooktop Expert? Answer questions, earn points and help others
