Question about LG WM2487H Front Load Washer
Error IE when washing on quick 30 - LG WM2487H Front Load Washer
Inlet water not coming in check tap valve at inlet valve there is one strainer clean otherwise inlet valve gone.
Posted on Feb 11, 2014
LG dishwasher LD1419W2 which would not fill -error code IE. I replaced the inlet hose complete. Now it has the error code FE and the water overflows onto the floor when in wash cycle. Peter
Try resetting by:
turn off dishwasher
trip circuit breaker to remove all power to unit
wait 30 seconds
restore power
start dishwasher
the drain pump should start and drain all water then start a cycle. Good luck
Nov 14, 2017 | LG Dishwashers
I have SE showing on my Samsung washer/dryer please respond with any suggestions
Samsung washing machine no workeing ? dL
The door was unlocked while the washer was running
dS
The door was opened while the washer was running
d5
FL
The washer failed to lock the door
Hr
Washer temperature control problem
Heater Relay Failure (on main PCB)
LO
The door will not unlock
5E
Washing machine has failed to drain the water
4E
Water fill time out
ND
Water Does Not Drain From Washer
NF
Water fill time out = No Fill
dE
Washing machine door detected as being open
UE
Washing machine has detected an imbalanced load
DC
Washing machine has imbalanced load and will not spin
3E
Motor fault detected
bE
Motor short error
OE
Washing machine has detected an overfill situation
LE
Water leak - Excessive SUDS - Bad water level switch
HE
Water heating error detected
tE
Water heating sensor (thermistor) error detected
IE
Water level sensor fault
CE
Abnormal water temperature detected
E1
Not filling in allocated time
E2
Pump won't empty - not draining
E3
Overflow - overfilling with water
E4
Out Of Balance (OOB) detected
E5
Water temp rising or falling too quickly
E6
E7
Pressure switch
E8
Temp too high on low temp washes
E9
Water leak, Water level has reduced
EA
Motor generator error
EB
Motor error
Sep 30, 2016 | Samsung Washing Machines
LG front loading washing machine Direct Drive 7 3.5KG Trouble shooting Error OE
go to lg.com, enter your model number and manual will show error codes and fixed for some including OE
Aug 29, 2015 | LG Washing Machines
I have an lg tromm with an ie code replaced water pump and main board and the ie error still there cleaned inlet filters also help
I have had problems similar to this with my Tromm, and I was able to get it to cooperate by unplugging it for a short period (30 minutes) of time and trying again. This cleared the error code and the washer worked for a long time before having to redo this procedure.
Mar 19, 2014 | Washing Machines
This is my Beko 6kg a class 1200 rpm washing machine. I'm looking for the quickest wash. It has a quick wash button but I can't seem to find a quik wash. Like a 30 minute wash??
The machine washing speed is not only TIME but WEIGHT... If you are able to push the Quick Wash, then that is the Quickest to get the job done "RIGHT"
Apr 08, 2013 | Washing Machines
I have a 711 front loarder it will do a quick 30 cycle but if i put it on a 1/55 cycle it comes up with a IE fault
"IE"
- Water level sensor error
Water sensor fails to send signal for longer than 5 seconds.
Press POWER button. No other buttons work:
Check wiring harness
Check pressure sensor switch
Check circuit board
Nov 01, 2012 | Westinghouse Washing Machines
Wot is the best setting for a quick wash
If your washer is a Hotpoint WF430, then the quick wash programme is L.
This is a 30 minute, 30 degree wash.
Trust this is the information you are looking for.
Please rate my solution.
Thankyou.
Jan 19, 2010 | Hotpoint WF430 Front Load Washer
After switching on the washing machine and keeping the mode in Quick 30,nothing is happening
More info please. ie is there still water in the washer? Does it happen to all the programs etc.
Sep 20, 2009 | Washing Machines
Machine won't wash
sent machine to scrap metal
Jan 03, 2009 | Washing Machines
Which programme saves the most energy?
yes a quick wash is for coloured clothes that have been worn once or twice and dont have bad stains on them.This quick wash will take between 30 and 50 mins to do a wash and is the best programme for the clothing that I have discribed ie: worn 1or2 times and no stains will save you on electric and water peter
Jun 09, 2008 | Zanussi Washing Machines
LG WM2487H Front Load Washer Logo
20 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
