Question about Blackburn Atom SL 4.0 Bike Computer
How do I change wheel size
I am following the instructions but it does not take me to the screen to enter/change wheel size...???
Increase screen font size
How To Change Your Text Size On Laptop
or
How Make Your Screen Resoloution And Font Size Larger
i subscribe to both of these channels and have not had an issue with following their instructions
Jan 04, 2016 | HP Computers & Internet
How to change font size on computer
The steps to change font size can vary depending upon the version of Windows you are using. To know how to change the font size, you can refer to the instructions mentioned on the following links:
For Windows 8.1:
http://windows.microsoft.com/en-US/windows-8/make-text-screen-larger-smaller/?v=t
For Windows 7:
http://windows.microsoft.com/en-us/windows7/make-the-text-on-your-screen-larger-or-smaller?v=t
GuruAid.com
Mar 09, 2015 | Computers & Internet
How to change view size in windows 8
You can change the view size in Windows 8 in the following ways:
1) By changing the size of text and other items on the desktop
You can change the size of text and other items (like icons) on your desktop without disturbing your current screen resolution settings. To do this, follow the steps mentioned ahead:a)Open Screen Resolution by swiping in from the right edge of the screen, tapping "Search" (or if you're using a mouse, pointing to the upper-right corner of the screen, moving the mouse pointer down, and then clicking "Search"), enter "Make text larger" in the search box, and then tapping or clicking "Make text and other items larger or smaller".
b) Drag the slider until the items in the preview image are the size you want them to be.
c) Tap or click "Apply".
You'll see the change the next time you sign in to Windows.
Also, you can change the text size for specific items (such as Window title bars or tooltips) without affecting the size of anything else on your desktop. Follow these steps to do this:
a) Open Screen Resolution by swiping in from the right edge of the screen, tapping "Search" (or if you're using a mouse, pointing to the upper-right corner of the screen, moving the mouse pointer down, and then clicking "Search"), entering "Make text larger" in the search box, and then tapping or clicking "Make text and other items larger or smaller".
b) Under "Change only the text size", choose the item you'd like to change and pick a text size. If you want the text to be bold, select the "Bold" check box.
Note: To view a pictorial description of the above process, refer to the link:
http://nvidia.custhelp.com/app/answers/detail/a_id/3153/~/adjusting-windows-8-display-size%2Fscaling-for-high-dpi%2Fppi-monitors
2) By changing screen resolution
You can change the view size on your desktop by changing screen resolution settings. To do this, follow these steps:
a) Swipe in from the right edge of the screen, tap "Settings", and then tap "Change PC settings" (If you're using a mouse, point to the lower-right corner of the screen, move the mouse pointer up, click "Settings", and then click "Change PC settings").
b) Tap or click "PC and devices", then tap or click "Display".
c)Tap or click the resolution slider and drag it until you find your desired resolution.
d) Tap or click "Apply".
To know more about the best screen resolution settings for your desktop, refer to "Set your monitor to its native resolution" section on the following link:
http://windows.microsoft.com/en-IN/windows-8/get-best-display-monitor
GuruAid.com
Jun 01, 2014 | Computers & Internet
How do i increase the sixe of letters and font
Hi. If you would like to Change the Font Size or Text Size of Website Pages, kindly follow the instructions on this link http://www.southboroughwebsitedesign.com/tips/changefontsize.htm
If you would like to Increase the Font Size on Your Computer Screen, use this link
http://www.ehow.com/how_4553103_computer-screen-reduce-eye-strain.html
Hope this helps.
Nov 18, 2011 | Office Equipment & Supplies
Is it possigle to change the font size in an Email I received
In most email applications, to change the font size on-screen, do the following:
* Hold-down the left CTRL key, and scroll your mouse's scroll wheel: scrolling forward makes the font bigger, scrolling backwards makes it smaller.
* When you have set the font to the correct size, release the CTRL key.
Aug 08, 2011 | Computers & Internet
The wheel size chart in the instruction manual does not include a tyre size of 700 x 54c (29 x 2.1) so I can't set it. Can you advise the setting requied?
It's in the manual. Measure the wheel size and enter it manually.
http://www.sigmasport.com/en/allgemein/showdatei/?download=1&name=2_1_Manual_BC_1106_nat.pdf
There's a picture of how to determine the circumference by rolling the wheel one revolution and measuring it. Be as accurate as you can (to the mm).
4. Wheel size BIKE 1
• Press MODE to change to BIKE 1.
• Press SET briefly and the first digit flashes.
• Set the value by pressing RESET, change to the next digit by pressing MODE.
• Bike 1 is always the bike with the handlebar holder WS 1
Feb 05, 2011 | Sigma Sport BC1106 Dts Wireless Bike...
How do I reduce the screen size? Everything is appearing too big, especially in my web browser.
Your screen resolution might be set to a lower setting.To make the content on your screen
smaller,you need to set a higher screen resolution.Please follow the instructions on the following link to
do that.
http://www.helpwithpcs.com/tipsandtricks/changing-screen-resolution-win-xp.htm
Nov 27, 2010 | Compaq FP 7317 17" LCD Monitor
How to convert this copier from inch to metric system??
SELECTING THE ORIGINAL SIZE
If you loaded a non-standard size* original or the original size was not correctly detected, set the original size manually.
Perform the following steps after placing the document in the document feeder tray or on the document glass.
1 Press the [SPECIAL FUNCTION] key.
The special function
screen will appear.
2 Select "ORIG. SIZE ENTER" from the
menu with the [ ] or [ ] key.
3 Press the [OK] key.
The original size selection
screen will appear.
4 Select the original size with the [ ] or
[ ] key.
The selected original size
is highlighted.
• To select an AB original size, press the [ ] key and
go to step 6.
• If you selected "SIZE INPUT", follow steps 4 through 6
of the procedure in "USING THE BYPASS TRAY TO
COPY A SPECIAL SIZE ORIGINAL" (page 51) to set
the horizontal and vertical dimensions of the original.
5 Press the [OK] key.
You will return to the base
screen and the selected original
size will appear in the original
size display.
Selecting an AB original size
6 Select the original size with the [ ] or
[ ] key.
To return to selection of inch original sizes, press the
[ ] key to return to step 4.
7 Press the [OK] key.
size display.
* Standard sizes:
The following sizes can be detected correctly: 11" x 17", 8-1/2" x 14", 8-1/2" x 11", 8-1/2" x 11"R, 5-1/2" x 8-1/2"
(A3, B4, A4, A4R, A5). If a non-standard size original is placed (including special sizes), the closest standard
size may be displayed, or the original size may not appear.
Note
DUPLEX
SPECIAL FUNCTION
ACC.
DUPLEX SCAN
DUPLEX SCAN
SPECIAL FUNCTION
SPECIAL MODES
ORIG. SIZE ENTER
PAPER SIZE SET
DISPLAY CONTRAST
GH
PQR
DUPLEX
SPECIAL FUNCTION
DUPLEX SCAN
SPECIAL FUNCTION
SPECIAL MODES
ORIG. SIZE ENTER
PAPER SIZE SET
DISPLAY CONTRAST
GHI
BACK OK
ORIG. SIZE ENTER
11x17
8 x14
81 x11
INCH
ORIG. SIZE ENTER
11x17
8 x14
8 x11
INCH
To cancel an original size selection, press
the [CA] key.
OK
ORIG. SIZE ENTER
A3
B4
A4
AB
OK
Note
Oct 02, 2008 | Sharp AR-207 Copier
Video capturing size question
You have two choices for Video size when creating MPEG4's. 320 x 240 or 160 x 120. Use the following instructions to change the size. Digital Still Camera Mode 1. Set the mode switch to MEMORY CARD position. 2. Set the power switch to CAMERA mode. 3. Press the MENU button. 4. Turn the MENU DIAL to highlight MEMORY. 5. Press the ENTER button to enter the submenu. 6. Turn the MENU DIAL to highlight MPEG4 SIZE. 7. Press the ENTER button. The MPEG4 SIZE toggles between 320 x 240 / 160 x 120 with each push. 8. Press Menu to Save and Exit.
Sep 06, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
Blackburn Atom SL 4.0 Bike Computer Logo
65 people viewed this question
Top Blackburn Cycling Experts
John Egan
John Egan
Donald Ayers-Marsh
Are you a Blackburn Cycling Expert? Answer questions, earn points and help others
