Question about Compaq Cq5110y Amd Athlon X2 7550 2.5ghz,3gb,200gb,dvdrw,vista
Jumper settings for hp compaq cq5110y bios /password
I NEED TO KNOW WHERE THE FACTORY SETTINGS ON THE JUMPERS ARE POSITIONED ON THE BIOS ,CMOS PASSWORD
4 Suggested Answers
SOURCE: compaq presario 5340 motherboard jumper setting
key bord or system unit error
Posted on Jun 12, 2008
colliewob
  • 781 Answers
SOURCE: Compaq-TPN10-01-Motherboard
F1 / DEL / CTRL + ESC / F2
Try any of the above
Posted on Oct 04, 2008
Geekman
  • 32281 Answers
SOURCE: jumpers on c500 compaq presario laptop
You can remove or change the Window's User or administrator's password and privileges. You need access to a computer with Internet access to download the Hiren's Boot CD and burn it onto a CD. Then insert this CD into the laptop/computer and boot up the laptop/computer with the Hiren's CD and follow the instructions. There are very useful utilities CD and it a Linux boot CD which contains quite a lot of Utility programs including a password removal program. Click on one of these links to download HIREN'S BOOTCD :- http://www.hirensbootcd.net/ http://67.20.82.163/
Posted on Mar 28, 2013
Hp compaq power-on password
If you do not know the "power-on" password for the computer, you have to open the case and find the jumper labeled "Clear CMOS". When you find that jumper, move the jumper from its present position on say pins 2-3 to pins 1-2 and power-on the system. it may ask if you want to clear the power-on password or the CMOS in general, or it may appear to do nothing. Wait 10 seconds or so and power off the computer. Move the jumper back to its original position and power-on the computer. It may ask if you want to reset the CMOS settings by entering the BIOS and then select Default System Settings and save the settings and restart the system. This should allow you to boot the system after having erased the "Power-on Password".
Aug 27, 2011 | Computers & Internet
My HP mini 110 have a bios password how i reset it?
you have a tutorial here...i hope it will help you
http://www.governmentsecurity.org/forum/index.php?showtopic=2411
Feb 12, 2011 | HP Mini 1000 Netbook
Reset power on password
YOu can reset bios password with 2 method.
(1) open back cover of laptop then find motherbord .Pull cmos cell from motherbord for 15 minutes then again put it in it's position .then it not ask for password.
(2)You can clear password with jumper settings find jumper on motherbord named clear cmos it has 3 pin .1-2-3
Put jumper in 2-3 position then again put it in 1-2 position then check .
Let me know if you need more assistance.
Thanks.
Nov 09, 2009 | HP Compaq 8510p Notebook
Power-On Password on Compaq Presario C300
Thanks.
Nov 09, 2009 | Compaq Presario Notebook
RESET BIOS PASSWORD ON COMPAQ 6400 LAPTOP
Thanks.
Nov 16, 2009 | HP Compaq NC6400 Business Notebook
Can anyone help me on how to reset the Bios password to default on an HP Compaq 6710b Laptop? I have an HP Compaq 6710b Laptop. It is booting but it cant go beyond bios boot and i cant enter setup as it is...
A. By Using the Motherboard Jumper:
In most motherboards CMOS battery is soldered, which makes it difficult to remove the battery. In this case we use another method.
Almost all motherboards contain a jumper that can clear all CMOS settings along with the BIOS password. The location of this jumper varies depending upon the motherboard brand. You should read your motherboard manual to check its location. If you don't have the manual then look for the jumpers near the CMOS battery. Most of the manufacturer label the jumper as CLR, CLEAR, CLEAR CMOS, etc.
When you find the jumper, look carefully. There will be 3 pins and the jumper will be joining the center pin to either left or right pin. What you need to do, is remove the jumper and join the center pin to the opposite pin. e.g. if the jumper joins center pin to left pin, then remove it and join center pin to right pin. Now wait for a few seconds and then again remove the jumper and join the center pin to left pin.
Make sure to turn the PC off before opening the cabinet and resetting the jumper.
B. By Using Software:
I have found that BIOS/CMOS Password Recovery Tool is the most effective.:
BIOS/CMOS Password Recovery Tool is a program that works instantly to remove any lost or forgotten BIOS/CMOS password. Simply boot your PC to DOS and execute the program, and get access to forgotten BIOS/CMOS passwords in just seconds
BIOS/CMOS Password Recovery Tool Service: http://www.biospasswordrecovery.com/
Oct 16, 2009 | HP Smart Buy Notebook
Don't reset password BIOS HP DC7100
If you cannot access the machine after if has been powered up, it is still possible to get past the BIOS password. The BIOS password is stored in CMOS memory that is maintained while the PC is powered off by a small battery, which is attached to the motherboard.
Open the CPU casing locate the CMOS battery in motherboard and remove this battery, all CMOS information (including the BIOS password) will be lost. You will need to re-enter the correct CMOS setup information to use the machine. The machines owner or user will most likely be alarmed when it is discovered that the BIOS password has been deleted.
On some motherboards, the battery is soldered to the motherboard, making it difficult to remove. If this is the case, you have another alternative. Somewhere on the motherboard you should find a jumper that will clear the BIOS password. If you have the motherboard documentation, you will know where that jumper is. If not, the jumper may be labeled on the motherboard. If you are not fortunate enough for either of these to be the case, you may be able to guess which jumper is the correct jumper.
This jumper is usually standing alone near the battery. If you cannot locate this jumper, you might short both of the points where the battery connects to the motherboard.
If all else fails, you may have to clear the BIOS password by resetting the RTC (Real Time Clock) IC (Integrated Circuit) on your motherboard.
Many RTC's require an external battery. If your RTC is one of this type, you can clear the BIOS password just by unsocketing the RTC and reseating it. Good luck!
Oct 04, 2009 | Computers & Internet
Need help forgot password for HP Compaq NX7330
here are 2 password type first 1 is bios password if tell me about your bios password it prompt when u powerup follow procedure below
For that you need to reset factory defaults settings for bios.
For reset bios u have to open back side of your laptop then u find motherbord circuit there.
pull cmos cell on motherbord for 15 minute then it reset to defaults.
Also u can reset with jumper settigns read carefully on mother bord there is 1 jumper near cmos cell u read there " bios reset or clear"
It is on 1-2 position right now set it in 2-3 position then power up then all bios settings are reset.
then again set it in 1-2 its original position.
Then it not want password.
And if u tell about windows password
Then when you power up the computer press F8 key then enter in safe mode then wait until it prompt for user passsword
then enter in administrator then if u able to enter then reset your password.
But if u set and forgot default administrator password then u should need winxp recovery disk.
Please rate me .
Thanks .
Jul 29, 2009 | HP Compaq nc6320 Notebook
I have forgotten the power on password of my compaq nx6310 laptop
Jul 16, 2009 | Compaq Evo N610C Notebook
Reset bios password
You need to locate the Cmos battery, not the jumpers, this is not a desktop.
Locate the Cmos battery, disconnect the battery for ten seconds, and Bios will reset to factory default.
Jan 03, 2009 | HP Compaq nx6110 PC Laptop
Compaq Cq5110y Amd Athlon X2 7550 2.5ghz,3gb,200gb,dvdrw,vista Logo
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
