Question about Bernina Activa 140
Machine siezure too stiff to turn manual control
Brother 3034d overlocker, handwheel is very stiff. I have oiled it and nothing happened. How do I fix it please?
If it is a mechanical machine, you can perform more oiling than recommended in the manual. I remove the base of my Bernina overlocker and oil the other moving joints. Even applying heat from a hairdryer may help. Below is the process I use for sewing machines, but it would work on a serger too:
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&cad=rja&uact=8&ved=0ahUKEwinkayZg5TYAhVbImMKHd5GCG8QFggpMAA&url=http%3A%2F%2Fwww.pfaff.com%2FSiteMedia%2FPFAFF%2FProducts%2FMachines%2FSupport-manuals%2FHobbylock-_787_788-manual-EN.PDF&
Dec 17, 2017 | Brother Sewing Machines
Riccar serger hand wheel stiff
Could very well be seizing due to lack of oil or buildup of lint, etc. Sergers generally require frequent oiling with fresh good quality oil (consult the manual). Continuing to force the motor to run when the machine is seized can burn up the motor.
Sep 10, 2016 | Riccar Sewing Machines
How do I get a Service manual for an Industrial Sewing Machine
If the handwheel is really stiff and the machine is making awful noises, then your machine may need oiling. Don't know if this is the case with your industrial machine, but it may be something to consider.
Jun 12, 2014 | White Sewing Speedylock 1600 Mechanical...
New Home machine has not been used for about 2 years, and is very noisy and stiff. Seems to need oil but the manual says to not oil it. ??
since the machine has been sitting up for 2 years & it smells bad then the
machine needs to be serviced
Apr 14, 2012 | Sewing Machines
Motor is fine, but won't sew
since the machine has been setting for 20 years, it needs to be serviced
the old grease & oil have probably turned the gunk. the servicing can also tell if any parts are damaged
Mar 18, 2012 | White Sewing Sewing Machines
The needle doesn't go up & down. Any suggestions? Thank you
Does the handwheel turn eazy or is it stiff. If it is stiff you need to take the top and bottom off and lubricate all moving parts. may take a bit of turning the handwheel and lubicating(it may tire you out). If the handwheel is not stiff I would check to see iff the motor is spining at all. If motor is not spining may be a bad footcontrol. If it is spining try cleaning the belt pullys and tighting the belt.
hope this helps
Mar 22, 2011 | Kenmore 15516 Mechanical Sewing Machine
Its a Singer 400z and the workings are very stiff,
You'll need to lubricate the machine, or take it in for service. If you have the manual for the machine, it will have photos, showing you where the oiling points are for your particular model. Be sure to use a good Sewing Machine Oil.
Here is a Singer website, with frequently asked questions. It might be a help to you. http://www.singerco.com/support/faqs.html
Oct 20, 2009 | Singer Sewing Machines
Bernina Patchwork 140 handwheel is getting stiff to turn
A stiff handwheel can be a simple as a thread stuck in the raceway or as severe as a failed uppershaft bushing.
Using your instruction manual, perform the basic maintenance and see if that helps. If not, take it to a repair person for evaluation.
Jun 17, 2009 | Bernina Activa 140
Husqvarna Viking 6440 buttonholer, reverse frozen
A seller on e-bay who redoes Viking machines says the the grease they put in them (the older vikings) becomes too stiff and the knobs stop turning. He cleans them out and then he adds some kind of teflon lubricant. Probably can find him on e-bay still. He is informative.
Kathy
Dec 06, 2007 | Husqvarna Viking 1
Sewing Machines Logo
15 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
Chris Wetmore
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
