Question about Hitachi 17 Cu.Ft aprox. R-Z400 2 Door Refrigerator FOR 220 VOLTS
POWER CONSUMPTION OF HITACHI RSG-37 BPND REFRIGERATOR
Power goes down suddenly
If it is out of warranty, write down the model of boards inside
replace the power board, once installed power it up, and see if this
does solved your previous issues, good luck
Mar 18, 2014 | Hitachi Gst Hitachi L37X01A 37 inch Full...
What is the average power consumption (watts)? What is the start-up power consumption?
Sir / madam
Horsepower (HP) is the name of several units of measurement of power. The most common definitions equal between 735.5 and 750 watts. Horsepower was originally defined to compare the output of steam engines with the power of a draft horses... In refrigerator the unit use is horsepower(HP) 1 HP = 750 watts
Jun 21, 2011 | Refrigerators
37" hitachi plasma tv doesnt turn on
If you have a light on ( standby light ), then I would say power supply fault, tv could be shut down because of faulty capacitors in power supply. if you dont have any lights at all , check fuse in plug,
( there will almost certainly be a fuse in the tv) but, that is for a tv guy to fix.
pete
Nov 10, 2010 | Hitachi 32HDX60 32 in. Plasma Television
I want to buy a window Air Conditioner. The AC which available in my city is LG, Samsung, Hitachi, Haier, Whirlpool, Hyundai, Voltas, blue star.. I don't want to go for LG and Samsung other than that which...
Hi, most of the units you have listed are fair, but if it were me buying for my home, I would have to go with the Hitachi. Another top of the line unit would be the Mitsubishi unit. It would be between the two. As far as power consumption, and the Seer rating, either one would be a good choice. Don't go with the LG for sure as they tend to have many problems with them breaking down, just being honest. Good Luck with your choice.
Sincerely,
Shastalaker7
Apr 16, 2010 | Heating & Cooling
I want to know the wattage for Hitachi 43fdx11b
225 normal up to 265 watts for high brightness scenes.
When the set is off it draws 2.7 watts
Sep 25, 2009 | Hitachi 46F500 46" Rear Projection...
How Much power consumption per day in 5 star refrigerator?
See inside the refrigerator , you will see the plate will indicate the power then times hours when it works without interruption.
Aug 29, 2009 | Refrigerators
Refrigerator (Whirlpool) increase in electricity usage
very doubtfull fridge fault would double elec consumption. look at rating plate and see how many watts then equate this to light bulbs. average light bulb is 60-100 watts (uk). does circuit breaker you turned off only control the fridge?
Mar 21, 2007 | Frigidaire FRT15G4B Top Freezer...
Hitachi 17 Cu.Ft aprox. R-Z400 2 Door Refrigerator FOR 220 VOLTS Logo
29 people viewed this question
Top Hitachi Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
Are you a Hitachi Refrigerator Expert? Answer questions, earn points and help others
