Question about Lenovo 3000 G530 Notebook
Language files when i do system update it says there are problems loading language files
    Top Expert:
  • Lenovo Master
  • 26,659 Answers
Try running Windows Updates, if you are Windows Based.
Posted on Feb 11, 2014
Error 9119, 9114 rosetta stone
When you install Rosetta Stone it puts its language files in a different folder. When you uninstall the program the language files are left intact and are never touched. If a problem occurs and one of the language files becomes corrupt and unreadable you're going to get that error 9119 every time when you try to re-install your language pack. Each language level has THOUSANDS of files in hundreds of sub-folders. Each file in those sub-folders has an hexadecimal name of 40 or more characters in length. So good luck trying to find the corrupt file(s). Also, because the file or files are corrupt, they can't be read or deleted. You're going to have to perform chkdsk on your hard drive to recover the bad sectors...eventually. The quickest and simplest way to fix your Rosetta Stone problem is to rename the folder where it puts its language files to something else. On an xp system the default name is "C:\Documents and Settings\All Users\Application Data\Rosetta Stone". I changed mine to "C:\Documents and Settings\All Users\Application Data\Garbage Files". That way when Rosetta Stone goes to install its language files it will recreate the folder cleanly instead of trying to overwrite the old folder and its corrupt files. That will solve your problem. You can then run chkdsk at your leisure and delete the Garbage Files. Good luck and spread the word.
Dec 29, 2012 | Rosetta Stone Computers & Internet
Change the operating system in english before is french language
1. Click on Start button, click the Control Panel, click Clock Language and Region and click Regional and Language Options.
2. Click the Keyboard and languages tab. 3. Display language, choose any language from the list and then click ok
if you not see the list of display language, you need to install additional language files. How to install addition language file 1. click on Start, All Programs and click on Windows Update. 2. Check Online Update from Microsoft Update, any update are found, click optional update are available. 3. Select language pack you want. 4. click Install update to use your administrator password or confirmation
Jun 22, 2011 | Computers & Internet
My sony vaio laptop was from japan. model VPCEB37FJ. I want to change the language from japaneese to english
The original language of the operating system cannot be changed without also updating the associated driver files, and those driver files are not available in languages other than the one that ships on the computer. However, the operating system can be configured to display in a different language by upgrading to the Ultimate version of the Vista operating system and then installing and using the appropriate Windows Vista language pack.
To change the language settings, a language pack must first be installed. Follow this procedure to download and install a language pack.
  1. Click the Start button, and then click Control Panel .
  2. In the Control Panel window, click Clock, Language, and Region .
  3. In the Clock, Language, and Region window, under Region and Language , click Install or uninstall display languages .
  4. Under Choose to install or uninstall display languages , choose Install display languages .
  5. Under Choose your method of install , choose Launch Windows Update
  6. Under Select the updates you want to install , select the Language Packs to install and click the OK button.
    NOTE: The Language Pack updates will be listed under the optional updates .
Apr 10, 2011 | Sony VAIO VGN-FJ270/B Notebook
I have a Designjet z2100. I loaded the drivers from the support site. Whenever I print, the printer display reports wrong file format. I am using window 7 64 bit and have tried using windows update to...
Next time include the System error code, in this case 61:XX.
Power off and remove the power cord. Reconnect and power on. Make sure that the correct driver is loaded.
Make sure that the Graphic language setting is correct.
Resend the file to the printer.
Make sure that the Firmware is up to date. Upgrading the Firmware will re-install the PostScript fonts.
It is also possible that the file is password protected.
Do all files fail?
Mar 25, 2011 | HP DesignJet Z2100 InkJet Photo Printer
When i came to install arabic language the computer didnot find the file from the windows cd what can i do
you can download the language pack in
CONTROL PANEL > WINDOWS UPDATE > OPTIONAL UPDATES > SELECT THE LANGUAGE PACK YOU LIKE
Then install it!
akuma_ryu21 rate it pls!!
Jan 21, 2011 | Computers & Internet
Change the language
click start control panel,regional and language options select regional language options from the drop down list select the language you want also from the bottom drop up list you can select your present location location
hope this helps
Jan 13, 2011 | Computers & Internet
My Sony Ericsson Z310i has stopped working, won't charge and won't turn on. I've heard that if you update the software it loses that problem but I can't because the computer does not register it.
for updating your Sony Ericsson you need the software tools then you need to check cid of your phone then down load same cid files from the tools online first file should be same generic and second file language file means if you are Europe then put any Europian file then flash. its quite difficult to do your self.
Dec 19, 2009 | Sony Cell Phones
Nuvi 205 is locked in Spanish. How do I change it back to english?
You can download the language files using the WebUpdater
program. When prompted to check for additional updates, checkmark
the language files that you wish to load to your Nuvi.
Oct 13, 2009 | Garmin nuvi 205 GPS Receiver
How do you change the language?
I had the same problem with my Canon Smartbase MP730. Printer properties was in Portuguese, no matter how many times the driver was uninstalled and reinstalled.
By running Filemon from SysInternals I realized that when showing the printer properties files in the
C:\BJPrinter\CNMWINDOWS\Canon MP730 Printer\LanguageModules\0409\
folder were created. One of those files was CNMmhya.hlp. When clicking on it a Help-window with Portuguese text shows up - even though the code 0409 means English. This is a symptom of the problem. This file was copied from somewhere in the Windows folder.
To fix this annoying problem, the following worked for me:
-> Unplug the printer
-> Uninstall the driver
-> Rename the following folder with the portuguese language driver stuff which still remains, even after uninstallation of the driver:
C:\WINDOWS\system32\spool\drivers\w32x86\3
(if you cannot rename it, reboot and try again). You should first check that there are indeed portuguese help-files in this folder. To do that, click on one of the .hlp files. If they are not your problem could be a different one, but it could also be that the files are stored nearby in the file system.
-> Reinstall the driver with the language of your choice. This time there won't be Portuguese files blocking proper installation of your new files.
-> Replug the printer to finish the driver installation
Now you should have finally gotten rid of the Portuguese (which may seem Spanish or Italian to some) text in Printer related windows.
Jul 09, 2008 | Canon MultiPASS MP360 All-In-One InkJet...
Save settings + refresh + update problem
im not sure about all the other problems you have but i do know my start up screen is REALLY long to so i think it's just the Sansa...i dont think thats anything to worry about and i did see something about having to go through select a language so i would search some of the problems ppl had on this site
Dec 01, 2006 | SanDisk Sansa e250 MP3 Player
Lenovo 3000 G530 Notebook Logo
21 people viewed this question
Top Lenovo Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
