Question about Candy CPCA250K Bottom Freezer Refrigerator
Candy CPCA 250K fridge and freezer have stopped working, light comes on in the fridge but fans are not working
SOURCE: Fridge freezes contents
Check the door seal is not split,it may be letting air into the compartment
Posted on Nov 14, 2008
  • 5 Answers
SOURCE: freezing frosting fridge
i had the same problem recently with all my fridge food freezing up, this all seemed to start when i discovered the interior bulb blown i replaced it still nothing also noticed warning lights on front out,i could hear the motor going so i knew it was on i removed back cover and found the heater covered in ice it turned out it was the failure of the control board causing these problems had it replaced and working fine now hope this is of help dmb23
Posted on Jan 11, 2009
  • 5 Answers
SOURCE: Fridge has become freezer and freezer become fridge
sounds like the control board i had same problem along with no light i had to have control board replaced working fine now
dmb
Posted on Feb 09, 2009
SOURCE: Candy CPCA270FFK Thermostat replacement
if your refrigerator is in warranty than contact your service authority......or if you had purchased it by your own than ...... my friend! the thermostart does'nt have any warranty
Posted on May 14, 2009
  • 85 Answers
SOURCE: Candy Frostfree Fridge freezer, model CPCA240FFK
1st of all conferm that the compressor is automatically (through Thermostate) going to ON/OFF or not, if it automatically goes OFF, i sugges its OK. and if not its no problum. (Minimum 4 hours rest is Must of a compressor, u can maunally OFF it for daily 4 hours Sleep)
Take Care
Shafky
Posted on Jun 17, 2009
Candy CSC 1745WE fridge freezer just started making a noise like the cooling fan is catching on something.This noise stops when you put pressure on fridge or freezer doors. Any ideas, many thanks.
If the defrost is not working then ice could be forming inside the unit. If that's the case then it will get worse as more ice forms and the unit eventually wont cool or will cool very little. Sometimes a panel or the fan blade isn't adjusted right and it hits something making noises. In the case you would have to pull the covers off inside the freezer .
Sep 19, 2016 | Candy Refrigerators
Candy fridge freezer not cooling in fridge compartment but freezer working ok
Check to see that fan in back of freezer is running. That's what pushes cold air into fridge.
Aug 04, 2013 | Candy Refrigerators
My candy fridge freezer stopped working, both parts..... orange light flashing and light inside fridge coming on and off all the time....model number is CPC240FFK
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Apr 16, 2011 | Candy CPCA270FFK Bottom Freezer...
My cpca 291 fxk problem is freezer frosting up and struggles to freeze things and fridge is not cold enough
sounds like your fan motor has seized or burnt out a winding,, this will need replacing. check by holding lid open to raise temp but at the same time hold down the button that the lid presses on when its shut, after about 10min the fan should run.
Nov 10, 2009 | Engel Freezer 22 Qt. Fridge/Freezer
Fridge don't work after defrosting session
It depends on weather or not you damaged it during the defrost. Most fridges' are self defrosting. Look at the coils behind the back cover inside the freezer. They should be covered in a light frost if the compressor is working right. Or Is the fan in the freezer running. It has to blow the cold air around the freezer and to the fridge side. It may cut off when the door is open so hold the door switch in to check. The humming in the freezer could be the fan trying to run but can't because of a defective fan or being blocked by somthing.
Sep 02, 2009 | Candy CPCA270FFK Bottom Freezer...
Fridge Icing up on N1B Candy frost free fridge freezer
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Sep 02, 2009 | Refrigerators
dmb
Jan 25, 2009 | Candy CPCA240FFK Bottom Freezer...
Nov 12, 2008 | Candy CPCA240FFK Bottom Freezer...
Fridge freezer icing up
YOUR DEFROST TIMER COULD BE STUCK,FIND IT ON BACK OR FRONT OR INSIDE TURN SLOW CLOCKWISE TILL CLICK,IF FRIG. IS RUNNING IT SHOULD TURN OFF AND GO TO DEFROST,ALSO THE DEFROST HEATER IN FREEZER COULD BE BAD,OR THE TERMINATOR IN FREEZER COULD BE BAD OR THE FREEZER FAN MIGHT HAVE STOPPED,LET ME KNOW WHAT YOU KIND,THANKS-MIKE
May 29, 2008 | Candy CPCA240FFK Bottom Freezer...
Candy CPCA250K Bottom Freezer Refrigerator Logo
41 people viewed this question
Top Candy Refrigerators Experts
Charles T Nevin
Charles T Nevin
Cesar Quant
Cesar Quant
Are you a Candy Refrigerator Expert? Answer questions, earn points and help others
