Question about Samsung RF265ABBP (25.8 cu. ft.) Bottom Freezer French Door Refrigerator
Samsung Refrigerator - suddenly freezing ice cream rock hard
We moved the refrigerator from one side of the kitchen to the other (6 feet) on Dec 29 after perfect performance for more than 3 years. Feb 1 or 2 we noticed that the 4-ltr bucket of ice cream we put in a day or two before was frozen so solid we couldn't dig out a scoop! We did not bump or tip the refrigerator in the move - only unplugged and replugged it into a different outlet. All else seems fine.
4 Suggested Answers
landsend
  • 1066 Answers
SOURCE: SAMSUNG RS263OSH SIDE BY SIDE REFRIGERATOR DEFROSTED
sounds like a bad timer in the defrost cycle.  Call a tech repairman
Posted on Mar 27, 2009
  • 736 Answers
SOURCE: my side by side kenmore refrigerator, freezer isnt freezing
in the back of the freezer there is an "evaporator coil" .. that has many fine fins and is used to cool the air .. you dont normally see it because there is a panel bolted over it ... if the door was left ajar for awhile then ice forms on the evaporator and stops air from flowing thru it ... the result is that it cant cool the freezer properly ... if this is the problem then you can fix it by taking everything out ( use an insulated tote to store things or use a neighbors frig overnight .... turn your refrigerator off or unplug it ... open both doors and let it thaw out for a day or overnight ... put down towells to collect the melting ice .. you can even blow warm air into the bottom of the freezer to make it thaw faster but be careful not to overheat plastic parts .. once the unit is completely free of internal ice then it should start to work again like new ..
Posted on Nov 12, 2009
  • 552 Answers
SOURCE: I have a 3 year
I have seen this several times, replacing the thermistor fixed it both times, let me know,
http://www.appliancerepairlesson.com/
Posted on Mar 07, 2011
Ice cream is not freezing on FFUS2613L Frigidaire Refrigerator
Thanks for your post, friend!
I understand that your ice cream inside of your Frigidaire refrigerator, FFUS2613L. I would turn down your thermostat to see if that would help correct the issue of your ice cream not freezing. I hope this helps. -Matt
Sep 30, 2014 | Frigidaire FFUS2613L Side by Side...
Ice block
There is some cooling in the freezer which is allowing the temp to raise above freezing for a brief period. Check gaskets and or the temp setting. Is ice cream hard or soft. Ice cream freezes at around 15-18 degrees. My guess is that the door gasket is allowing air inside the box.
Feb 03, 2013 | Samsung RF265AA Bottom Freezer French Door...
Freezer too cold. Ice cream freezes hard like a rock. Freezer does not respond to temp control which is turned to maximum warm.
Have you checked for an ice buildup on the evaporator coils. One cause could be that the thermostat is getting a false reading because of ice build up.
Aug 02, 2011 | Frigidaire 14.7 Cu. Ft. Top-Mount...
Ice cream will not freeze, but will make ice cubes.
Actually, it's not as you think. Ice cubes are made between 0-4 degree Celsius and ice creams are frozen below -3 degree Celsius. Your freezer temperature may be between 0 and -3 degree Celsius and that is causing the problem. An ideal freezer should have temperature between -3 and -30 degree Celsius.
Apr 20, 2010 | Samsung RS2578BB Side by Side Refrigerator
Freezer was freezing ice cream rock hard and refrigerator liquids( ie. milk, beer) was only a little cool. how should i adjust the number settings?
Don't do anything too quickly here. Move the freezer number one digit warmer and fridge one digit cooler today.
Check temp (and icecream) tomorrow. If not satisfied, move one more digit on the freezer or fridge until you are happy.
Mar 18, 2010 | Maytag MSD2756G Side by Side Refrigerator
Too cold
If the unit seems to be running non stop, you may have a bad cold temp control. If you have ice cream in freezer, it will likely be rock hard, that you need a chisel to scoop. if your ice cream is ok, its likely not the temp control. On your GE, in the fresh food section, do you have a canopy on the ceiling of fridge, and likely covers the whole top back portion of your fridge? If you do, there is a damper door inside, that breaks off its hinge, and stays wide open, allowing cold air from freezer to constantly be pulled into fridge, freezing food. If you do have this canopy, it will need to be replaced, as you cannot reattach the damper to its hinge.
Feb 15, 2010 | GE Profile PSW26P Stainless Steel Side by...
Whirlpool Side by Side: Freezer freezes refrig doesn't cool.
check for a blockage. There is only one cooling section, divided by airflow for freezer / fridge.
Perhaps something sticky is in the vents, or the freezer section has poor airflow, resulting in ice formation.
Unplug the unit for several hours, clean out vents, and make sure freezer section has good airflow from the vents.
Aug 30, 2009 | Whirlpool GS6NBEXR Side by Side...
Freezer not getting cold
Call local Repair shop, No Fix possible, leak in the coils, can't repair.
buying new fridge.
Mar 22, 2009 | KitchenAid Architect® Series II KBRS22KT...
Freezing problem
I think you mean that milk freezes, etc.
Probably bad thermocouple. In the refrigerators I'm familiar with, there is a thermocouple thermostat in the freezer. There is no measuring of refrigerator temperature; it just gets a portion of the cold freezer air.
If the thermostat is bad, then ice cream should be rock hard too, for it never quits cooling except on defrost cycle, three times per day.
Jun 16, 2008 | Candy CPCA270FFK Bottom Freezer...
Samsung RF265ABBP (25.8 cu. ft.) Bottom Freezer French Door Refrigerator Logo
110 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
