Question about Hayward SAND FILTER, PRO SERIES
Pantera wicor how often do I need to change the sand?
    Top Expert:
  • Hayward Master
  • 4,262 Answers
Every 3 years
Posted on Mar 05, 2016
2 Suggested Answers
  • 4044 Answers
SOURCE: I have a P20 Pantera
The last time I saw this there was a valve problem on the controller and the filter sand needed changed. If that sand has been in there more than 12 months and running most likely the sand needs replaced. While you have it open you can check the pipes and fittings in the Filter Unit to make sure something didn't come loose. If I remember correctly it recommends changing the sand every 2 to 3 years unless there is a lot of build up which you described indicating the need to change it. The 2 to 3 year recommendations comes not so much because of the sand but to inspect the inside of the filter unit as well.
Posted on May 25, 2011
Rubber web like gasket under control lever, provider needed
that is called a spider gasket, generically!, So Good Guess!
Any Pool & Spa Supply store should have or could get one.
Amazon is a good place if you are an online shopper...
Amazon com Sta Rite filter spider gasket
You will need to know the size of your valve... 1.5" or 2.0 "
May 25, 2015 | Pool & Spa
Pantera pool filter model p24
give them model number of filter and multiport you need new multiport gasket (spider gasket)
Feb 09, 2014 | Hayward SAND FILTER, PRO SERIES
Pantera wicor model no. P24
if not able to get seal check hardware store for oring or replace unit
Have a pantera p24 sand filter from wicor and the lable has gone from the control lever. I need to know what function is in each position.. filter, rinse, backwash etc.
don't know if you got it fixed or not but can give you mine....if your looking at it from the top it goes like this....in the twelve o'clock position nothing,1 o'clock is recirculate then 3 o'clock is backwash then 5 o'clock is close then 6 o' clock winterise then 7 o'clock is waste then 9 o'clock is filter then the 10 or 11 o'clock is rince. hope that helps..
Jul 15, 2011 | Wicor Industries Master Plumber Geyser...
Labels Gone
I also have the same problem with the label on my filter. My pool dealership said I would need deal with Wicor directly. I see two other people with the same problem, however, neither has been responded to. It is VERY difficult to run your pool properly if you don't have your control lever labeled. An immediate response would be greatly appreciated.
Apr 23, 2010 | Wicor Industries Master Plumber Geyser...
I have a Pantera 2 sand filter by wicor, 2nd hand. they told me it leaks abit around the top, but I could by a kit for it where do I get a kit or how do If fix it?
Depending on which model that you have, you may be able to find replacement parts online. Poolcenter.com is one place that sometimes has older parts. In fact, if you follow the link below, it will take you to a parts listing online:
http://www.poolcenter.com/parts_filter_starite_pantera.htm
However, that is for the Sta-Rite/Wicor model and may not be the one you have there. If it is not, one possible option is to email Pentair from their website. If you can take a jpeg photo of the filter, they may be able to further assist you in finding the correct parts.
Jul 02, 2009 | Pentair FILTER TANK BOTTOM, 48 SQFT
Older Polaris doesn't sweep
If the unit travels normally and picks up debris as it should,there may be a problem with a feed hose inside . Separate the haed shell and inspect. often the plastic clamps finally give out and allow hose to pop off. Also check inner hoses for any swelling and possible slits.If the unit doesn't act in a friendly way then you have water supply issues and/or inadequate water pressure to unit. Check stream from wall with unit disconnected.
Apr 06, 2009 | Polaris 380 In Ground Pool Cleaner
Hayward SAND FILTER, PRO SERIES Logo
52 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
