Question about Belkin (F5D5231V4-SN-PD) Router (F5D5231V4SNPD)
Cant log into router set up
Ive been trying to log into my belkin G router to add some ports into its firewall but it says I'm not authorized.
  • Anonymous Dec 01, 2007
    HOW TO RESTOR TO FACTORY SETTINGS
    Scholar:
  • 127 Answers
You must log in as an administrator account. if you forgot your password for the admin, try to check the back of the router, there maybe a button there that you can reset back to factory default...but be caution, this will delete your recent configuration.
Posted on Oct 27, 2007
HOW TO OPEN sdp PORT
1) You can take the IP add of your device(to which you want to open ports) and then contact the device vendor and ask them to give port numbers for your device. Once u get the port numbers you can either open ports on the router by logging into the router interface using your Default gateway of the router or you could put the IP add of your device in DMZ on the router. Basically this will keep the device out of the firewall of the router( Which is the main reason for this issue). 2) If the first step didnt work you could disable the firewall on the router.
If both the steps didnt work you could check if your router has any firmware update or it has to be reset and re-configured and the above steps should be re-done.
Hope this helped.
Feb 15, 2011 | Belkin Wireless G Plus MIMO (F5D9230-4)...
I am having issues setting up VPN using the Belkin F5D8231-4 Wireless Router. Please help.
connect your computer wired to the router
open the internet explore type this in address 192.168.2.1
on left side grey vertical column click on firewall - disable firewall
on left below firewal u have virtual server click on it and just add this port number which i give
open the following ports in the router
Vpn ports no: TCP- 1723,443,10000
UDp- 1701,500,50,51
when u open this ports your VPN wil work for you
Let me know if it works
Thanks & regards
Milan
Jan 08, 2011 | Belkin (F5D8231-4) Wireless Router...
Hello, i wonder if anyone can help me.. i was given a router today i set it up and it was working perfectly. When i turned my xbox360 on and went on to a game and it said my NAT was moderate. so i tried to...
For resetting the router You have reset key on the back of the router, press and hold the reset key with any sharp objects like toothpick or a paper clip for 35 sec(or more) From the xbox you have to manually enter the ip address
Configuring port forwarding In order to configure this, you need to know:
- The IP address of the computer or device to have the port forwarded to.
- The port numbers to be used and whether these are TCP or UDP ports
(Note: We recommend you use a computer that has a wired connection to the router.)
Oct 04, 2010 | Belkin (F5D7230-4) Router (587009)
Cant gain access to change settings on my router Belkin N1+
hardwire any computer to one of the wired ports in the router...
type 192.168.2.1 in any web browser and log in to router setup utility manually....
password....leave it blank and click submit..
now you can configure settings manually....
Apr 20, 2010 | Belkin N1 Vision Wireless Router
Cant connect 2 wireless
At any cost do not disable the NAT - because thisis the feature which allows multiple device to work with router
So only option you've got now is to reset the router. It should be at the rear end of the router. Hold onto it for 30 seconds, u'll see the light flash and router reboot
Once you've done with that - configure router and make it work.
And as of for the Xbox Issue try these steps:
1 - Assign a Static IP address in the Xbox:
- Go To Network Settings - Configure Network
- Change IP settings to Manual
- IP Address: 192.168.2.45 Subnet Mask: 255.255.255.0 Gateway: 192.168.2.1
- DNS settings to Manual
- Primary DNS: 192.168.2.1 Secondary DNS: 4.2.2.2
2 - with any of the Wired Computers
- open IE - type - 192.168.2.1 - u'll get the Router Interface
- left hand side in the list of options
- click Firewall - leave password blank - disable and apply changes
- click Virtual Servers;
- under enable place a checkmark
- description : Xbox, Inbound Pot : 80(if there are two boxes here duplicate in both the boxes), Type: TCP, Private IP: 45, Private Port: 80
- So Similarly fill up the table for these following Ports
TCP: 80, UDP: 88 Both(TCP&UDP): 53, 3074
Additional Note:
If u've a DSL connection, call ur ISP and make sure ur modem is bridged and the NAT is disabled
Dec 22, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Have blkin 54 - cant upload to my website, keeps interrupting me with belkin homepage
simply goto admin 192.168.2.1 or 192.168.1.1 or 192.168.0.1 you got to tell the router that you wish to kee p the port 21 open for ftp Firewall > Virtual Servers and add a entry using the port 21 and restart the router. Regards GeWiz
Apr 19, 2009 | Belkin (F5D8231-4) Wireless Router...
Belkin turns off and on when i type ip address to get in to setti
Which Belkin device?
A two-port Kvm (Keyboard/Video/Mouse) switcher?
A Belkin PCMCIA card?
A Belkin USB adapter?
A Belkin router?
Mar 27, 2009 | Belkin Wireless Pre-N (F5D8230-4) Router...
My F5D7230-4 Belkin Router Virtual Servers power forwarding broke
Hi there!
Have you checked the Windows Firewall settings? If it is On, try turning it off and attempt the connection with RealVNC. If the problem persists, try adding an Exception to the Windows Firewall, just as an added troubleshooting measure.
Click Start, navigate to Control Panel, double-click Windows Firewall, and open the Exceptions tab. Look for a RealVNC entry. If you don't see one, click the "Add Port" button, type RealVNC as the entry name, and 5900 as the port number. Select the TCP radio button, click OK and then OK once more. Attempt the RealVNC connection again.
I hope this helps! Feel free to reply with results or further questions.
Feb 18, 2009 | Belkin (F5D5231-4) Router
Connects to the explorer BUT NOT IN MSN!!!!
you need to log onto your router
typically browse to http://192.168.2.1
then go to the firewall section of your device you are intrested in the client IP filter section.
Basically remove the filters that you have inplace for complete freedom.
if you can't rememeber the logon details you will need to reset the unit to factory default settings and set the unit up again from scratch, make sure that you know your ISP log on details before you reset the unit though!! ;).
Nov 04, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Belkin router blocking programs
The firewall is probably set to block. The IP address for Belkin is 192.168.2.1. you can log in and set the firewall. Also, if it is a program like gaming , you may have to open a port for it.
http://www.portforward.com/networking/staticip.htm
Sep 29, 2008 | Belkin (F5D7230-4) Router (587009)
Belkin (F5D5231V4-SN-PD) Router (F5D5231V4SNPD) Logo
112 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
