Question about Tunturi Exercise & Fitness
Treadmill cuts out after 7 seconds
Treadmill powers up then cuts out after 7 seconds
4 Suggested Answers
  • 33 Answers
SOURCE: I have a BH treadmill that has an E1 Error messgae...
Your problem might be that a magnet has fallen off. Here's an illustrated guide that should make fixing it easy: http://fixmytreadmill.blogspot.com/2010/10/how-to-fix-treadmill-e1-error.html
Good luck.
Posted on Oct 09, 2010
  • 33 Answers
SOURCE: Treadmill cuts out after 10 seconds and gives an E1 message.
Your problem might be that a magnet has fallen out of place. Here's an illustrated guide that should make fixing it easy: http://fixmytreadmill.blogspot.com/2010/10/how-to-fix-treadmill-e1-error.html
Good luck.
ercupa190
  • 12223 Answers
SOURCE: My Sportcraft TX-400 Treadmill shuts off after 7 seconds
Dear sIR:
This by lack of LUBE, in your schedule maintenance DECK BELT. maybe the belt is worn.
2) Lube the roller bearing.
3) Align the belt see the diagrams
4) Test the input voltage motor, if there are voltage motor, the motor need repair.
5) Test the output voltage board, for input voltage motor, if there are NOT the board is faulty.
Now you can RUN the software calibration for diagnose, troubleshooting. See my personal TIPS for HELPs too.
sincerely. God bless you
Posted on May 07, 2012
How do I calibrate a Trimline 4650.1 treadmill?
WARNING: DURING THE ENTIRE CALIBRATION PROCESS, STAND ON THE PLASTIC SIDE RAILS ONLY!
DO NOT STAND ON TREADMILL WALKING BELT!
CALIBRATION
1. Turn off treadmill.
2. Simultaneously press PROGRAM, ENTER, and START/STOP for about 3 seconds.
3. Maximum speed will be shown in the TIME/PACE display followed by an "E" for English units or an "N" for metric
units. Press START/STOP to change from English units to metric units.
4. Press ENTER.
5. Press START/STOP. Incline and speed will calibrate simultaneously.
6. When successfully completed, TIME/PACE display will show CAL PASS.
7. Press POWER. Your treadmill is ready for use
Jan 02, 2017 | Exercise & Fitness
Pro form 320x treadmill stops working when you get on it
How can I get my Proform 320X treadmill from stopping a ...
www.shopyourway.com > Manage My Life > Questions
How can I get my Proform 320X treadmill from stopping a few seconds after starting? ... -why-does-my-proform-treadmill-belt-only-move-a-few-seconds-stops
ProForm Treadmill 320x User's Guide ' ManualsOnline.com
fitness.manualsonline.com > ... > ProForm Treadmill
ProForm 320x Treadmill User Manual. Page 1. Page 2. Page 3. Page 4. Page 5. Page 6. Page 7. Page 8. Page 9. Page 10. Page 11. Page 12. Page 13.
Nov 03, 2015 | Exercise & Fitness
The Treadmill starts up and after 7 seconds, it stops. The message on the console is "Lose Power." And the console is frozen.
Need more information, I had this happen to me on a Yowza Treadmill. It can be the safety switch.
Mar 01, 2015 | Exercise & Fitness
Bowflex series 7 treadmill Calibration fail. Next indicated action?
It looks like the main circuit board is damaged and needs to be replaced unless there are separate modules in it.
Jan 22, 2013 | Bowflex Series 7 Treadmill Folding Pro...
I have a tunturi t40 treadmill an error code e7 appears And it cuts out after 5 seconds have tried to calibrate the elevation motor but it won't stay at 9 mm gap when it powers up the gap closes
please test the 2 alternatives for error 7. God bless you
see the diagram attached.
ERROR CODE # 7
E7- 1) Alternative Elevation Motor
1)Cause: Elevation Motor not moving Solution:Check Elevation Motor connection
2)Cause: Elevation Elevation Motor screw binding Solution: Clean screw and lubricate
3)Cause: Elevation Motor Motor out of Range Solution: Check motor out of elevation
4)Cause: E-Motor Potentiometer: Solution: Replace Elevation Motor
2)Alternative:
Display Doesn't Light Up: a)Cause: On/Off switch Solution: Test unit is turned on b)Cause: Insufficient Power Source Solution: Plug dedicated120V, 20Amp Outlet
c) Cause: Line Cord Damaged Solution: Replace Line Cord
d)Cause: Fuse Solution: Check Fuse on MCB
Jan 08, 2013 | Tunturi T40 Folding Treadmill
No power
Dear Sir:
The Not power can have many reason, plase do the following:
1)Reset the c. breaker from your house(the breaker that control your outlet where do you have connect the treadmill)
2) Please do the same with the breaker from the treadmill
3)Inspect if the treadmill inside after the transformer has FUSE.?
4)Inspect your power cord.
5) Do not use extension cord power if you are using.
6)Smell if you feel something burn?
7)Retight the wires from power cord, and inside from Treadmill.
8)If there are some wires loose or making colder joint.
9)See if there are corroded cables?
Attached is my design for block diagram, for easy troubleshooting.
2_14_2012_7_47_34_pm.gifSincerely. God bless you.
ernesto a cuadra
managua, nicaragua. c.a
Jan 07, 2012 | Exercise & Fitness
Power cuts out when turned on.
Circuit breaker (house) or treadmill power? Display, treadmill or both? Not much hope for you if you can't try a little to help yourself.
Mar 07, 2010 | Bowflex Treadmill Series 7
Treadmill stops after 7 seconds
you have a broken spinner. Take hte motor cover off and look on the opposite side of the motor. there will be a partof the spinner wheel there. I have yet to find a way to short cirut the connectors nor a replacement wheel.
Feb 16, 2010 | RTO Image 15.0R Treadmill Walking Belt
Good luck.
Jan 23, 2010 | Horizon Exercise & Fitness
Exercise & Fitness Logo
Top Tunturi Exercise & Fitness Experts
gbob59
Jeremiah Meyer
Jeremiah Meyer
Are you a Tunturi Exercise and Fitnes Expert? Answer questions, earn points and help others
