Question about Coffee Makers & Espresso Machines
Burco coffee maker produces so much steam that only about 2 thirds of the water that is put in comes out again.
  • 3 Answers
SOURCE: Coffee won't brew
It is probily the thermal switch between hot wire and element. Check to see if you are getting power through this switch.
Posted on May 19, 2008
  • 7 Answers
SOURCE: No steam, just hot water.
The steam wand has to be removed to be cleaned properly. Unfortunately, this procedure is not outlined in the manual. Just cleaning the wand on the outside or using a clip to clean the tip is not enough.
The other end of steam wand where it connects to the pressuring cabin actually swivels around a fitting. It is this fitting that you need to thoroughly clean. Years of using the machine can cause calcification around this fitting.
If you look under this end of hte steam wand, you should see a philllip-headed screw. Before you loosen this screw, you have to remove the grey trim so that the entire wand can be remove.
Once the entire wand is removed, what I just described will be much clearer.
Posted on Mar 18, 2009
EsWorld
  • 1618 Answers
SOURCE: Gaggia evolution not producing coffee
One question before I make any suggestions: If you remove the shower screen and screw, do you get a nice flow of water or is it still steam?
If you get a nice flow of water, then check your screen hold it up to the light and you should be able to see through the tiny holes, if not, get a pair of needle nose pliers and being very careful hold screen over an open flame like the stove burner. The coffee will burn before the anything happens to the metal. When it is cooled screw into group and see if the flow of water is better.
If you get nothing but steam then it is time to descale the machine.
Posted on Apr 06, 2009
SOURCE: New Mr. Coffee Espresso machine producing white gunk
Hello aura20,
I bought one this week and had the same problem. I used vinegar and rinsed thoroughly and yet the whit flakes remained. I did some research and found that high end espresso makers often have very fine screens that catch minerals and grounds and so on. This Mister Coffee espresso maker has only a metal basket with tiny holes so it's not really filtering anything. Moreover the metal is treated aluminum, so it scales naturally. Also, if your water is hard like mine that just makes things worse. I just tore off a piece of paper towel only big enough to line the bottom of the filter basket and not come up around the edges. Then I put a drop of water on the paper towel and pressed the paper towel against the filter basket so I could see the little holes through the paper towel. Then I rinsed the machine again and the white flakes were completely gone from the water and the paper towel had collected it instead. I did the same thing with a new piece of paper towel and I added coffee, I did not add the maximum amount of coffee and I did not tamp the coffee. The product was smooth and creamy as it came out of the machine very slowly. But it tasted great and it was strong and clean. Upon removing the basket I found hard dry grounds stuck to the basket and paper towel. I had to use a spoon and running water to dig all of it out. It's not as good as professional espresso makers, but it'll do for a quick shot. I hope that helps.
Posted on May 20, 2009
EsWorld
  • 1618 Answers
SOURCE: My Gaggia Baby C coffee maker has stopped pumping water
From what you have asked the only thing I can suggest is that the pump needs to be replaced. Do you hear the pump vibrating? The lines from the pump may be blocked. Have you tried to descale the machine.
Posted on Jun 06, 2009
Why is Delonghi Perfecta not producing steam to froth milk.Nothing at all happens when cappacino button is pushed
At wits' end DeLonghi Magnifica steam function - Coffee Forum
www.coffeeforums.com/.../9427-wits-end-delonghi-magnifica-steam-fun...
Jun 1, 2012 - While I quite like the coffee it produces, the steam function seems to be ... it with the magic DeLonghi descaling solution, so I'm certain this is not ...
DeLonghi not producing steam Questions & Answers - Fixya
www.fixya.com > Forum > Tags > not producing steam
Ask your DeLonghi not producing steam questions. Get free help, advice ... Ad. Question about Esclusivo Magnifica ESAM3300 Espresso Machine. 3 Answers ...
Delonghi 3500s coffee machine not producing hot water or ...
Dec 06, 2015 | DeLonghi Perfecta ESAM5500 Fully Automatic...
Saeco vienna super automatica coffe maker produces very little coffee and it comes out very slow.
sounds like your pump. When you turn steam knob on, you should hear the pump go bump,bump,bump. When hot water is turned on, you should hear pump run steady.
Jan 07, 2013 | Saeco Vienna SuperAutomatica Coffee...
Hi, I have a Cafe Chic coffee/expresso/cappiccinno maker that has not been working properly. When I try to make coffee, the water that is suppose to travel through the filter and coffee grains ends up...
obviously you have leaking steam valve, use my recipe for rearing it:
you should take out the knob first, than you try to disassemble the SHAFT of valve from the valve body, in this types(small espresso coffee machines) usually producer use conical valve, without seals she close metal to metal, when you get out the SHAFT you will see one line on the conical end. for repairing it will be enough to visit one metal workshop where they will take a small amount of brass from end and polish it. then you put it back and work again with your machine. During assembling valve change 2 o rings and put one fitting 1/4'' to block the shaft coming out.
PS: notice you only polish the SHAFT , don't let them to short the more than 0.5 mm
Mar 03, 2011 | Espressione Cafe Chic 1377
My machine has stopped producing hot water. The lights don't even flash to show it's heating up when I switch it on, it just goes straight to ready mode & then when I brew some coffee it comes out...
Either your coffee boiler elements are damaged or the thermostats on there are damaged or tripped, use an ohms meter to check element and thermostats.
May 20, 2010 | Gaggia Syncrony Compact Coffee...
Water is leaking into the drip tray.
Clean the chamber below the white plastic valve, there is also a small discharge that leads from there into the drain tray clean that hole also.
Second the thermostat that controls the steam may be damaged or the cpu board, the contact the controls the steam may be damaged, i have seen both of those happen on some units.
Oct 10, 2009 | Saeco Vienna SuperAutomatica Coffee...
Steam wand shooting water instead of steam
You're supposed to wait for the blinking light to go solid before attempting to steam your milk!
Until then, the water isn't hot enough (it's at coffee-brewing temp, not steaming temp) to produce steam.
Further, after steaming, the water is too hot for coffee's correct brewing temp, and the light again blinks until it has cooled down enough, if you care.
Dec 11, 2007 | Nespresso C190 Titanium Espresso Machine
Coffee Makers & Espresso Machines Logo
16 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
