Question about Wharfedale Televison & Video
How do i find the model number of my wharfdale tv
4 Suggested Answers
dave1645
  • 834 Answers
SOURCE: i need an instruction manual for a wharfdale tv
try here
Free Wharfedale owners manuals, user guides & how to instructions ...
Wharfedale manuals. Wharfedale user manuals. Wharfedale owners manuals. Wharfedale how-to instructions. Wharfedale
Posted on Nov 24, 2009
  • 7 Answers
SOURCE: what wall bracket do i need for my wharfdale 42
Check for 3 things, 1 location on wall ( you need to attach it on a wooden stud in the wall, 2 weight and size ( you want a mount that usually sized for 40" to 48" or 50" inches which will accomodate for the weight, 3 One that Tilts ( get one that will at least tilt up and down, due to the reflection of any lights or sunlight. also because you may need to adjust it so that you can see it from a seated position.. other than that any brand will do, more you pay the better (and easier) they are to put up... Good luck
Posted on Mar 25, 2010
walesarumi
  • 6993 Answers
SOURCE: my friend has a Wharfdale
The issue you describe is consistent with a power supply board issue. This is the board where the AC goes to. This problem may have occurred as a result of irregular power supply, or excess power supply or power surge.
The TV is receiving current but cannot circulate or transfer the current to other necessary part of the TV because of the defective power supply board. You might be lucky it's just a blow fuse. Also a defective transformer can cause your TV not to power on.
All these can be checked on the power supply board.
But more often bad capacitors causes problem on the power supply board. I do not think the power board needs replacement, rather those defective capacitors is causing this issue. Open unit up and take a look at the power supply board.You will probably see one or more electrolytic filter capacitors that are bulged up in the top-not perfectly flat like the others.
The value of these capacitors will be different, most likely they will be somewhere around-820 to 2200uF/25 V( or /10V sometimes)
You can replace them with same values but I would recommend the voltage rating to be higher(like 35V for an original 25V) for reliability purposes.
What happens is,these bulged top capacitors will cause a low and unfiltered DC voltage=main board will malfunction(the relay will keep clicking until the caps are holding enough charge to bring the voltage up over a threshold point).
You can buy these capacitors at any Fry's or Radioshack store or you can order them online at vendors like "mcmelectronics.com"(look for electrolytic capacitors). After replacing these capacitor(capacitors) most likely the normal operation will be restored. Or you can by a refurbished complete power board to save you some stress.
Note: There may be also some other causes for this symptom ,like a defective T con board ,or main board,but the bulged top capacitors are the most common cause for this issue.
If you don't know about TV repairers, take the TV to the nearest repairman to fix the fault for you. Also, note that TV stores a lot of current, so wait a while before opening the TV back cover.
I hope this helps.
Regards.
Posted on Jul 12, 2011
I have a Stang ST-620+ Universal tv remote,looking tv code for all wharfedale tv models
wharfdale TVs are rebadged by Argos, so I am unsure of the actual manufacturer, and therefore the control signal scheme that they use.
It might help if you gave the model number of the particular TV, as they could be using several different manufacturers in their range of televisions.
it is unlikely there will be a single code that covers the whole range of Wharfdale Tvs
Jul 30, 2016 | Universal Televison & Video
I have a one for all URC-7740 remote and brought a wharfdale tv but cant find the code. Please help.
Hi cgroom,
If you go to the oneforall website - http://www.oneforall.com/en_UK/support you can enter the model number of your remote. It is either printed on front of remote under the oneforall symbol or in the battery compartment at the rear.
Then you can enter the make and model of the device you're trying to use it on, TV, DVD, etc. (TV Model Number is usually on a label at rear of tv) It will give you a code to input into the remote. It gives you instructions on how to do that underneath the code.
Hope that works for you. I have found them to be pretty good for tv's, freesat boxes etc.
Regards, Tom.
Mar 25, 2011 | One For All URC 7740 Remote Control
I have a 42" LG plasma TV with a number of different inputs including a spare HDMI and component sockets, but have no idea whether there is a cable or convertor to allow me to connect to the amplified base...
do you have a cable box? with your wharfdale set-up, you could run the video from the cable box into the tv, and run the seperate audio oupputs from the cable box into the wharfdale.
thats really the most common way to run audio, either that or through hdmi- either way, you will need to hqave a cable box to complete the set-up, cause not that many tv's have audio or hdmi outputs.
Oct 12, 2010 | Wharfedale Moviestar 70+ System
I require a user manual for a 74cm Wharfdale TV - Model WH-TV29PFJTT
Don't know if it's any help, but tvmanualsonline have a manual for a WH-TV/DVD21NO combination TV/DVD for download.
Apr 18, 2010 | Wharfedale DVD-M3 DVD Player
What wall bracket do i need for my wharfdale 42'' plasma tv, model number w42s40pe
Mar 24, 2010 | Televison & Video
I have been given a wharfdale dvd player without a manual the model is DVD65ST -there are are 4 speakers one big one 2 smaller and one seems to have 2 speakers in it - how do i connect it to my tv?
your tv must have audio line input connectors, plug it there and select that input function on your tv it usually activates on the video button on your remote control unit
Dec 16, 2009 | Televison & Video
I need an instruction manual for a wharfdale tv model number 10HDAF
try here
Nov 24, 2009 | Televison & Video
Wharfdale TU320DTR channel settings
check the menu of your remote thin find the channel setings
Dec 30, 2008 | Televison & Video
How to connect speakers to wharfdale 22 inch digital lcd dvd combo tv
please specify the exact model number of your "wharfdale 22 inch digital lcd dvd combo tv."
Thank you for selecting FixYa!
azkeyz@fixya.com
Wizard Division
Sep 23, 2008 | Televison & Video
Televison & Video Logo
20 people viewed this question
Top Wharfedale Televison & Video Experts
Gareth Cockram
Gareth Cockram
Jonathon summesfield
Are you a Wharfedale Televison and Video Expert? Answer questions, earn points and help others
