Question about Shark NV352 Navigator Lift Away Vacuum Cleaner
Brushroller won't spin, and the belt is NOT broke
  • Shark Master
  • 18,424 Answers
This link is the manual go to page 17 for solution
http://s3.amazonaws.com/szmanuals/dfc8a36ffd18f8a15809319354dd6017
Posted on Feb 12, 2014
How do i change the belt on a hoover model #U4509
Lay the unplugged vacuum upside down and remove the bottom plate covering the brushroll to remove the brushroll and belt. Make sure brushroll bristles aren't worn, replace it also if needed. Make sure brushroll will spin freely. Put new belt around motor shaft then around brushroll. Pull on brushroll with both hands to get enough leverage to stretch the belt far enough to drop the brushroll in place. Put bottom plate back on and insure brushroll will turn by hand before you turn it back on..
Nov 12, 2016 | Hoover Vacuums
Why does my brush roller stop and heat up belts?
Hi! If you have replaced the belt with a new one and your brush-roll is still not spinning, your brush-roll may need to be replaced. Remove the brushroll and clear it of hair and debris. Spin the end caps with your hand. They should spin easily with no tension. Inspect the area on the brushroll where the belt rests on for damages. To order a replacement brushroll click on this link. Search Results It could also be that the incorrect belt is being used with the vacuum. Make sure you are using genuine Hoover parts when replacing the belt. Click on this link to order a replacement belt. Search Results & Search Results
Hope this was helpful!
Jun 09, 2014 | Hoover U6437-900 / U6439-900 Windtunnel...
Brush won't spin when carpet cleaner is running
see this causes and fix it. God bless you
If the vacuum cleaner brush is not spinning, the brushroll bearing might be jammed. Try removing the brushroll assembly and cleaning all hair, string, lint, etc. from the brushroll bearing. If that doesn't solve the problem the brushroll may need to be replaced.
If the vacuum cleaner brush is not spinning, the brushroll assembly itself might be jammed. Try removing the brushroll assembly and cleaning all hair, string, lint, etc. from the brushroll bearings. If that doesn't solve the problem the brushroll may need to be replaced.
If the vacuum cleaner brush is not spinning, the brushroll itself might be jammed. Try removing the brushroll and cleaning all hair, string, lint, etc. from the brushroll bearings. If that doesn't solve the problem the brushroll may need to be replaced.
If the vacuum cleaner brush is not spinning the cogged belt might be broken, stretched out too much, or might have fallen off. Check the belt and replace as needed.
If the vacuum cleaner brush is not spinning the drive belt might be broken, stretched out too much, or might have fallen off. Check the belt and replace as needed.
If the vacuum cleaner brush is not spinning the belt might be broken, stretched out too much, or might have fallen off. Check the belt and replace as needed.
Sep 27, 2012 | Vacuums
Brush bar not spinning when set to high or low on carpet
1) adjust the belt, see for broken or worn, and replace
2)see for brushroller obstruction, and clean it and repair
3) see if the brushroller without belt run smooth, otherwise repair and fix it.Lubricate.
4)See if the motor run without load( NOT belt+brushroller) very well. in negative case repair motor.
God bless you
Jul 15, 2012 | Vacuums
How to put a Kirby Vacuum belt back on New belt seems too short
To put on a kirby belt all you need to do is put on the belt on the brushroll, put the brushroll into the housing making sure the marks on the end of the brushroll are the same. Take the spin dial in the front and "hook" the belt till the dial reads off. Put the head back on the machine and spin the dial to "on".
Jan 27, 2010 | Kirby G5 Bagged Upright Vacuum
Belt problem
the brush is jammed most likely or not in correctly
Aug 08, 2008 | Kirby Generation 3 Bagged Upright Vacuum
Eureka Altima is smoking!
http://geeksquad.fixya.com/ThreadView.aspx?prdid=618889&thid=606496
Posted by saysay on May 18, 2008
Help! My vacuum is smoking. It won’t work anymore and starts to smoke as soon as it gets turned on.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
Eureka Altima Upright Vacuum Model #2996AVS – it is probably doing 2 things, it could be the belt and or brushroll and the easiest ay to check is to remove the belt and see if the motor smokes, if the motor is fine then buy a new belt and check the brushroll to see if the brushroll spins freely, there are bearings in the brushroll and thread and hair get bound up in the ends and needs to be cleaned out. So #1, check the belt – no smoke from the motor then check the brushroll to see if it spins freely then changed the belt. If the motor smokes check your purchase date it may still be under the one year factory warranty from the dop. #2. Either clean or replace the brushroll and belt. If you have any further questions, feel free to contact your local vac dealer. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don The Vac Man
Go Ahead. Use Us.
May 18, 2008 | Eureka Altima Upright Vacuum Model 2996AVS...
Brush roll not spinning
http://geeksquad.fixya.com/ThreadView.aspx?prdid=414813&thid=453845
Brushroll not spinning
Posted by vistaloopy on Mar 19, 2008
I have a Eureka Bagless Optima 431 Lightweight Upright that is not working. I took it apart to clean the brushroll and have tried to put it back together several times, but the brushroll will not spin anymore. Maybe I'm putting the belt in the wrong spot? Where can I find a diagram or something?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Eureka 431A Optima Bagless Upright Vacuum. You have only 2 choices, the belt is either side driven belt or the belt is a center driven belt and the brushroll has one side that is for the belt and the side driven brushroll and the motor pulley must be in line in order to work properly, you may want to check the bearing holders, some vacs will mark the ends with words like NEW or USED and both have to be identical in order to fit right. Once you have the brushroll out it should spin if you set it on it’s side and if that happens you are OK, then watch the ends of the brushroll. Align the end with the motor pulley, B4 install the belt place the belt on the pulley side and install the brushroll. Then once the brushroll is in and spins properly, and then you can use a belt puller and stretch the belt onto the motor pulley and then track it in a straight line. If you need further help please feel free to contact your local vac dealer in your area. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.eureka.com Customer Service 1-800-282-2886
Customer Service Dept for U.S.
Electrolux Home Care Products
P.O. Box 3900
Peoria. IL 61612
Hours of Operation
Monday thru Friday 8:00am to 7:30pm CST
Saturday and Sunday 10:00am to 6:30pm CST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Mar 19, 2008 | Eureka 431A Optima Bagless Upright Vacuum
Belts
Recently received a kirby from mother in law and don't how to change the belts
Dec 15, 2007 | Kirby Ultimate G Bagged Upright Vacuum
Shark NV352 Navigator Lift Away Vacuum Cleaner Logo
65 people viewed this question
Top Shark Vacuums Experts
Thomas Perkins
Thomas Perkins
Ruth summersides
Are you a Shark Vacuum Expert? Answer questions, earn points and help others
