Question about Polar Cycling
Seal polar cs200 broken - Polar Cycling
How do I unlock "Buttons
You can reset the computer as follows:
Reset the cycling computer by pressing and holding all buttons until the display is filled with digits. By pressing any button the unit goes to the Basic Settings mode.
A copy of the manual can be found here
Feb 22, 2011 | Polar CS200 Cycle Computer/Heart Rate...
I have the CS200 and can't figure out how to turn it OFF after riding my bike. Can you help me with that? Where would I get a copy of the instruction manual. Thank you, Nancy
The CS200 should automatically turn itself off. A copy of the manual can be found here: http://www.evanscycles.com/product_document/file/ea5/394/ec0/403/polar-cs200-computer-manual.pdf
Feb 18, 2011 | Polar CS200 Cycle Computer/Heart Rate...
I dropped my Ohaus about 3 feet onto carpet. Now when I turn it on it boots to the E screen everytime. Help!
I am an Ohaus technical specislist. I have unfortunate news. You scale is broken and there is no other way to fix it but get it repaired. You can send it to us at:
Ohaus Corporation
Atten: Service Department
7 Campus Drive
Suite 310
Parsippany, NJ 07054
Jan 02, 2011 | Ohaus CS200 Standard room Scale 200g X1g...
OHAUS CS 200. Reads E everytime its turned on
This forum is for Cameras. Please post in a more appropriate forum.
Oct 07, 2010 | Ohaus CS200 Standard room Scale 200g X1g...
I have a polar cs200. There is a visual display but nothing works while I ride. I replaced the battery but that didnt help. I put the computer next to the sensor but there is no response. Any suggestions....
The most likely problem is that the battery in the sensor that goes on your front fork needs to be replaced. The easiest way to tell if it that's the problem is to position the magnet on the wheel close to the sensor and then move it quickly back and forth a couple of inches. If you do not hear a clicking sound then your sensor battery is dead
Feb 22, 2010 | Polar CS200
How to change from miles to kilometers
Try the mode button- sometimes you have to hold it for 5 seconds.
Oct 02, 2009 | Polar CS200
Battery replacement polar cadence sensor CS 200
Polar sucks, I'm going to Cateye
Sep 06, 2009 | Polar CS200
Works erratically, am wondering if the contacts where the belt snaps together need to be cleaned, but I don't know how to clean them.
First up, are the batteries in the belt OK? That is usually the first thing to go on any Polar. Secondly, you're placing it in the right position, it's comfortably tight ( doesn't go lose as you breathe out ) and your head unit isn't right out on some Tri bars or something? Sometimes they don't like to send too far, and putting it back closer to the belt is the answer. A quick way to clean the contacts is with an old toothbrush and tooth paste, as this usually has mild abrasive in it. My bet is the battery in the belt is getting low, as it's a common problem.
Jun 29, 2009 | Polar CS200 Cad
Cycling Logo
Top Polar Cycling Experts
kirkjw
Level 1 Expert
mcgsp
Level 1 Expert
nelson morales
Level 1 Expert
Are you a Polar Cycling Expert? Answer questions, earn points and help others
