Question about Master Heaters B155DST
Where is the photo eye on the direct master space heater
Blp170vta heater starts upfor about 30 seconds then shuts off
propane no photo cell its has a thermal and an over heat disc on the in line thermal can b jumped to check for heat desk fail if it doesn't run still then the thermal coupler could b bad and changed
Dec 11, 2013 | Master Heaters BLP170VTA Gas
Kerosene garage heater (Desco) fan starts, burst of kerosene, and the heating element is red. Within a few seconds, heater stops abruptly. Email address: p.s.stohr@sbcglobal.net Thanks for your help.
Remove the top from the heater and clean the flame sensor. It should be the photo eye type. Remove it from it hold and clean inside with soft cloth or cotton swab with alcohol. If this doesn't help, let me know what you find. nitensheaterservice@earthlink.net
Jan 11, 2011 | All-Pro Kerosene Garage Shop Heaters - All...
I have a allpro propane space heater. it fumes and burnes my eyes
these units have to be used in open area, with air flowing, they produce carbon monoxide...
Dec 19, 2010 | All-Pro Propane Garage Shop Heaters - All...
Hi i have a master space heater model 150 paraffin, runs ok with the cover off but when i put the cover back on it stops. The flame out button clicks to shut the heater down. any info please
These units have a air pump on the back of the fan motor. Has anyone messed with the settings? The pump usually runs off of 5 to 6 lbs. of pump pressure. This is what controls the fuel flow that is sprayed out of the fuel injector. This unit also should have a photo eye for flame out control. It is positioned near the ignitor looking though a hole in the combustion chamber. Make sure it is clean and looking in the hole. Make sure your ignitor is working also.
Dec 01, 2010 | All-Pro Kerosene Garage Shop Heaters - All...
Master heater only runs for 5mins
Check the photo eye to make sure it is clean,clean it with soap,and water,and add a additive to the fuel for gelling.
Jan 14, 2010 | Master Heaters B155DST
Propane heater burning eyes
HI it sounds like you have incomplete combustion on this heater making funes needs to be checked over by a gas fitter
Jan 05, 2010 | All-Pro Propane Garage Shop Heaters - All...
Raw propane fumes and burning eyes
Ours didn,t burn liquid propane too well, so ccheck your connections on your tank for vapor or liquid.
Dec 17, 2009 | All-Pro Propane Garage Shop Heaters - All...
Reset button keeps popping and the time between becomes shorter.
check the photo eye. It's the little rubber boot on the bottom right on the back side of the burner. If it's dirty, it may not be shutting off the igniter. If the igniter runs continuously, the safety breaker will trip.
Dec 18, 2008 | All-Pro Kerosene Garage Shop Heaters - All...
Master Heaters B155DST Logo
Top Master Heaters Heating & Cooling Experts
T bone 1963
Gil Shultz
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Master Heaters Heating and Cooling Expert? Answer questions, earn points and help others
