Question about Amana Refrigerators
How to test control board on amana model abr222fes
Coils are covered with frost
  • 35 Answers
SOURCE: Not cooling
Replace heater and defrost timer
Posted on Dec 09, 2007
Techsim
  • 59 Answers
SOURCE: Amana SxS fridge not cooling or freezing
You have a sealed system problem. There is either a small leak or a restriction somewhere in the tubing. This isn't something you could've caused so don't worry about that. Unfortunately this isn't something you can fix yourself either. You require a certified refrigeration technician to fix this problem.
Posted on Nov 03, 2008
mastatech
  • 478 Answers
SOURCE: amana SXD22S2W Side by Side not cooling - no frost on coils
He's right,sorry.
Posted on Mar 12, 2009
Sea Breeze
  • 4654 Answers
SOURCE: Amana Refrigerator Model ABB2222FEQ Control Panel Cover
Yes, I can help you and send you the service manual also, Thanks, Sea Breeze
Posted on Jun 16, 2009
aasc
  • 1606 Answers
SOURCE: I have a ge sxs model #gss22jepcww fride not
Pull the refrig out and remove the 8 " x 10 " panel . Behind this panel , is the main control board ( you already know , since you changed it ) . Unplug the refrig . Remove the BLUE plug from the board , with 3 larger wires going to it . Looking at the blue plug , the sequence will be wire1,wire2,space,wire3 . Get a short piece of insulated wire , and strip about 1/4 inch from each end . Insert 1 end into wire2 , and the other into wire3 . Plug the refrig back in . After about 3 min , look in the freezer , at the bottom , behind the crisper , look for a red glow . If no red glow , unplug the refrig , and reassemble the plug and cover . This no glow , indicates a shorted defrost heater WR51X10101 . It is also advisable to replace the defrost thermostat ( pt. number WR50X10068 ) when replacing the heater . To access these parts , you will have to remove the inside rear wall of the freezer . The heater , is at the bottom of the coils , held on with 2 screws , and the thermostat , is the 1 " cylinder , with a blue and pink wire going to it , clipped on the top left of the coils .
If you do get a red glow , then the # 4 thermistor is bad . This tells the main control board , the temp of the coils , if they need defrosted , when they are thru defrosting . This thermistor is the 1 " long , torpedo looking piece , clipped on the top left of the coils , with 2 white wires going to it . Part number WR55X10025 . It would be advisable to also replace the # 5 thermistor , located at the bottom of the freezer , slightly in front of the drain , also with 2 white wires going to it , slid into a housing . This thermistor , is the freezer thermistor , which tells the control board , the freezer temp , when to cycle off , associated with the fan speed also .
Posted on Jan 21, 2010
FREEZER COOLING OK BUT FRIDGE LOW COOLING
Remember that most all refrigerators only have cooling to the freezer... the refrigerator depends on stealing some of that cold to be cool, so here's my top 3 guesses...
Cause 1 The defrost heater is defective, so frost accumulates on the evaporator coils, and the coils will become plugged with frost causing the airflow through the coils to be restricted, and the refrigerator not to cool. Check the evaporator coils to determine if they are frosted over. If the evaporator coils are frosted over, test each component of the defrost system after clearing any restrictions to the cooling fan and defrosting with a hair dryer.
Cause 2
The evaporator fan motor draws cold air over the evaporator coils and circulates it throughout the freezer. If the evaporator fan is not working, the freezer or refrigerator will not cool adequately. To determine if the evaporator fan motor is defective, try turning the fan blade by hand. If the fan blade does not turn freely, bench test it for function and use a multimeter to test the motor windings for continuity. If the windings do not have continuity, (very odd) replace the evaporator fan motor.
Cause 3
Damper Control Assembly The air damper control opens and closes to let the proper amount of cold air into the refrigerator compartment. If the damper does not open properly, it won't let enough cold air into the refrigerator. Check the damper control to determine if it is broken or stuck closed or that an inadvertent bump has shut it off to the refrigerator compartment
Apr 09, 2016 | White-Westinghouse WRSZ28V8GM Side-by-Side...
Ge refrigerator model gss22kgmc
check defrost element, if good check defrost thermostat, if good change defrot timer/control board depending on your specific model you can look at this link provided its a diff model but none the less quite similar
am searching for Main PBA for fridge freezer model no SRL 629EV The number...
Sep 02, 2014 | GE GSS22KGMBB / GSS22KGMWW / GSS22KGMCC...
Frost builts up in the coils
Frost will normally build up if you do not have frost free freezer and in which case it is possible the frost free system is faulty. If it is not frost free then it has to be defrosted a few times in a month. However if the frost comes up very quickly then there are possible causes.
You may be having leakage from the door seals or there are items in the freezer that are not properly covered to avoid moisture escaping. Other possibility is that your freezer is set too cold and there are not many items in it.
Aug 18, 2014 | Amana Freezers
I have an amana bottom freezer/refrigerator model ABB2522FEQ. the bottom freezer works great, but the coils have frozen two times. I thawed coils out again and it only lasted 2 weeks, eventhough the fan...
HI,IF THE FREEZER IS BUILDING ICE ON EVAP COVER THAT IS NOT DEFROSTING PROPERLY,REPLACED THE CONTROL BOARD AND DEFROST B-METAL TO REPAIRD THE PROBLEM..
Jul 04, 2011 | Amana ABB2524DE Bottom Freezer...
Amana Bottom Freezer 7 years old running but not cold.
Check to see if the condenser fan at the back underneath near the compressor is running. If no check fan.
Are the condenser coils near there warm or room temp. should be warm
How to check stuff>
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Is the evaporator fan in the freezer running. It blows cold air into the fridge side through a damper in the wall between the freezer and fridge. Make sure the damper is open.
Below the evaporator fan is the evaporator coils. Remove the back cover inside the freezer to observe the frost pattern. Light frost everywhere(NORMAL) or a partial pattern of ice(LOW ON FREON) or nothing(LOW FREON OR COMPRESSOR PROBLEM).
heavy frost-
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Aug 25, 2009 | Refrigerators
Suddenly there is frost covering everything! What
It may not be sealing properly. check to see if a dollar bill will easly slide between the seal and the door. move the food ( and ice) away from the door then test with the dollar again. If it is not sealing clean with soap and watr using a dish brush. test again after drying. The last is to put a small amount of silicone greaseon the seal. The plumbing section section of the hardware store carries plumbers grease.
Aug 17, 2009 | Amana ARB8057C Bottom Freezer Refrigerator
My in-laws Amana ATB1832AR Top Freezer has stopped cooling. It was purchased 7/1/2005. Is there an inline fuse for the compressor that may have gone out?
you might have a defrost problem. Frost free models have a heating element that is controlled by a timer to automatically defrost ice, ie defrost timer turns on defrost heating element every 12 hours to melt ice in freezer and allow good air flow.
You can test defrost element with an ohm meter(located inside freezer coils-will have two wires going to a plug connection), if OK replace defrost timer (located in various places depending on make and model
Aug 13, 2009 | Amana ATB1832AR Top Freezer Refrigerator
I have an Amana Side by Side. The freezer section
check defrost heater, defrost thermostat. If the heater and thermostat are ok it’ll be the adaptive defrost control.Part 13 on this diagram of your fridge controls. http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=ASD2625KES&productCategoryId=0165000&brandId=1268&modelName=AMANA-REFRIGERATOR&diagramPageId=00005&componentDescription=CONTROLS&documentId=M0612301&backToLink=Return%20to%20Sub%20Components%20list
Below the evaporator fan is the evaporator coils. Remove the back cover in the freezer to observe the frost pattern. Light frost everywhere(NORMAL) or a partial pattern of ice(LOW ON FREON) or nothing(LOW FREON OR COMPRESSOR PROBLEM).
Jul 13, 2009 | Amana ASD2625KE Side by Side Refrigerator
My refrigerator is 4.5 years old and the problem is that the freezer has ice build up in a matter of days, so much that it prevents air flow from the freezer below to the fridge above. I have defrosted it...
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes.
Jul 01, 2009 | Amana 19 cu ft Bottom Mount Refrigerator,...
The freezer is accumulating frost. i have
Some models like yours came with a defrost control board and others came with a defrost timer. They should be found inside the fresh food compartment and behind the temperature control panel. You will need to inspect and let me know which you have. Unplug first. If the control board looks or does not look burned it could be bad. The timer can be turned clockwise until compressor stops and should remain stopped for about 25 minutes. and then turn itself back on. If these look good then we need to remove the rear panel inside the freezer and test the defrost element with one wire disconnected to check for continuity. Just to be sure the element has not burned out. The defrost thermostat is connected to the defrost element and will have open contacts inside it above 50 degrees. Do these test with power unplugged and let me know what you find. Sea Breeze
Jun 21, 2009 | Amana Easy Reach AFD2535DE Bottom Freezer...
Refrigerators Logo
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
