Question about Refrigerators
I pushed refrigerator out to clean behind it and it stopped working GE model TFX22ZG
thaurfen
  • 623 Answers
SOURCE: GE refrigerator side by side not working properly.
check your condenser...or let a repairman check it i don't think there is diy's here
Posted on Aug 22, 2008
  • 31 Answers
SOURCE: Kenmore Elite model 73503201- FRIDGE DOES NOT COOL, FREEZER WORKS
Look in the back of the freezer, there will probably be a metal panel with a plastic vent on top.
Look through the vents in the metal panel, and you should see the shiny metal fins of the evaporator. If the fins or the vents are plugged with frost, that is your problem. The freezer will stay cold because a small amount of cold air will be forced through the frost but that will not be enough to make it up to the refrigerator portion. You can defrost the unit by removing the metal panel and allowing the frost to melt. Careful use of a hairdryer can speed up this process. This will likely be a temporary fix. The root cause of excessive frost can be caused by a bad door seal or a defective defrost circuit.
First check that the door seal is good by closing the door on a dollar bill at several points around the door, both on the freezer and refidgerator door. If you can pull the bill out with no resistance, the door is not making a good seal. Inspect the seal and make sure there isn't anything stopping the door from closing such as food, or a shelf not pushed in all the way.
If the door seal is good, the defrost system is likely defective. The defrost system has three main parts, the defrost heater, thermostat, and timer. If either one of the parts fails, the freezer will plug up with frost every few weeks. If you can troubleshoot this by manually starting the defrost cycle. Let me know if you would like this procedure.
Posted on Jan 07, 2009
Sea Breeze
  • 4655 Answers
SOURCE: freezer and refrigerator not cold fan working but
I'm ready to help you when you are. Zero may just be off on that model but if fans run then the compressor is also getting power and overheating. The start relay and components that keep the compressor going are what important now. Don't leave plugged in or the internal overload may damage. I will wait for a reply, Sea Breeze
Posted on Dec 18, 2009
woodchuck789
  • 4070 Answers
SOURCE: ge profile refrigerator door stop isn't working
Did it ever work or for some reason you never noticed it before? I've had to swap the door stops to get the door to stop. They can usually be swapped around according to what's needed in different situations.
Posted on Jan 20, 2010
SOURCE: fridge stopped working
Temp gauges keep shutting off to "0" for the fridge and freezer. Any ideas on how to fix this problem
Posted on May 13, 2010
How do i fix my Ge refrigerator water and ice in the door
Disassemble and clean and lubricate linkage that may be binding. .
May 19, 2015 | GE Refrigerators
I have a GE side by side fridge. First the water would stop working intermittently. Then the ice and water stopped all together. Now on top of that its making a clicking noise and the freezer works for...
Your model needs attention soon to prevent damage to the control board. Something simple as a fan going bad will cause a chain reaction on your model. Let me know if you would like my assistance or your you would like to call in a technician. I can help you repair from here or my site. Thanks, Sea Breeze
Nov 26, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Profile model PFS22MISBWW stopped working, panel problem?
Replace the main control board on the back of the refrig . PT# WR55X10656 . It's behind a panel about 10" x 6" .
Aug 07, 2009 | GE PDS22LBN Bottom Freezer French Door...
Can't find refrigerator coils/ cooling issues
There're two coils ,the condenser coil wich you already clean (also make sure the condensing fan motor works properly and the fan blades are also clean).The other is the evaporator coil wich is located inside the freezer behind the back wall cover.
Apr 21, 2009 | Refrigerators
WHISTLING NOISE DAY AND NIGHT IN FREEZER SECTION REFRIGERATOR GE MODEL GSS201BPDWW WHEN MOTOR IS WORKING
The whistling is caused by the air circulating fan located just behind the light. It is easily accessed by removing the light cover and the two small hex screws above the light. To stop the whistling I simply turned the freezer off and pulled the fan cover out slightly to reveal the fan blades. I then pushed the blades down, toward the bottom of the until the blades stopped and i could feel the shaft slightly protruding from the top of the blades. Repositioning the blade has stopped the incessant whistling. Hope this helps!
Apr 18, 2009 | GE Refrigerators
GE Side by Side Refrigerator
Check for frost on the back wall of the freezer section. If no frost buildup is noted check that the condenser under the refrigerator behind a removable panel in back is clean and that the fan there operates when the compressor runs.
If you have frost buildup in the freezer section on the back wall you have a defrost system problem. These problems are not related to the cleaning ladies work unless some paper or other item may be stopping the fan from turning.
Jun 11, 2008 | Refrigerators
Fridge stopped getting cold
Check for frost on the back wall of the freezer section. If there is frost there your problem is defrost related to a timer or defrost heaters. I say this because you indicated it still makes ice cubes which indicates it is still working to some degree. Check the condenser for cleanliness and clean if necessary. Under the refrigerator front behind toe plate and /or in back behind removable panel.
May 19, 2008 | GE Refrigerators
Ge side by side not cold enough in fridge or freezer
if there is no frost build up in freezer section sounds like a refrigerant leak
Apr 14, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Side by side frigidare brand refrigerator model#frs6b5eew3
Check this out it may help you http://appliancehelp.hypermart.net/xmb_ge_arctica_sxs.pdf
May 13, 2007 | GE Profile PSW26P Stainless Steel Side by...
Refrigerators Logo
22 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
