Question about Sharp Televison & Video
Sharp ht dv40
After power blackout there is a "word scrolling" on the display at the Sharp DVD cinema HT-DV 40. Pushing "shift" & "demo" buttons to get out of the demo mode do not work. Are there any other options?
SOURCE: Sharp DV-RW250 problems transferring video to dvd
have you tried formatting?
Posted on Jun 19, 2008
SOURCE: dvd multiregion unlock code
Perfectly it work on the SAMSUNG HT X40
Posted on Oct 18, 2008
drlalitv
  • 488 Answers
SOURCE: REGION FREE CODES
try this:
1. Power
2. open
3. stop
4. applay code : 734466
5. select region 0
6. exit setup
hope it helps!
Posted on Nov 21, 2008
jaffa012001
  • 376 Answers
SOURCE: Unlock Sharp DVD region code
open drawer on dvd
then press volume + key
while holding it down press the language key
and release volume+ still holding language
then look then use up and down arrow keys to change region code
Posted on Dec 15, 2008
ginko
  • 19396 Answers
SOURCE: SAMSUNG HT-TZ212 home cinema kit comes up with protect
Protect mode will kicking whenever a fault is detected.
Causes that can start protect mode are:
Electrostatic harges on internal circuits.
Leave the unit unplugged for power for one hour or so, this will allow discharge.
Bad speaker wiring.
Check speaker wiring, try unplugging and plugging back, or start after removing one speaker at the time.
Internal fault.
Internal fault is the natural cause for protect mode. If all the above did not work, then the problem is a blown component or an internal fault. In this case the unit must be taken apart , tested and repaired by an experienced person.
If the unit is less than one year old, or if you want to get service, call Sony at the phone number listed on the product documentation.
Regards.
Posted on May 04, 2009
Mi HOME THEATER WITH DVD HT-X1 dice protect y se apaga
Mi HOME THEATER WITH DVD HT-X1 dice protect y se apaga. q debo hacer
Jan 04, 2012 | Sharp HT-X1 System
Sharp HT-DP3000 reciever don't know how to plug in speakers
Hello, many thanks for your request. I found a quick manual for HT-DP3000, you can download it here:
http://www.tradebit.com/filedetail.php/9120914
(Check out for the green download button on the upper left side)
Aug 31, 2009 | Sharp HT-DP3000 System
I have a Home Cinema with DVD model HT-M700H and a DVD is stuck inside and the tray will not open. The player starts to read the disk but cannot play it. There is no mechanical noise when I press...
If the disk is stuck in then the is a big problem with the dvd draw, sounds to me like the motor has shorted out if there isnt any noise, you can getthe disk out manually by unplugging the Cinema system, get a paperclip , its either to the left or the right of the dvd draw is a set of gears that is explosed to allow manual retrevial of the disk, push it into either the left or right bottom of the dvd draw and if you feel a little resistance , you have found the gear, just keep pushing in until you see the dvd draw start to emerge, then gently pull it out with your fingers.
jon.
Aug 12, 2009 | Sharp Audio Players & Recorders
Protection displayed and shuts off When I press the power button Protection is appear on screen on my home cinema system dvd player
check wiring on speakers it sounds like you have some wires touching together somewhere or you have a bad speaker.
Jun 15, 2009 | Samsung HT-X20 Home Cinema 600W Theater...
Samsung HT-A100 Home Cinema system plays cd only with tv on!
You need to put away the remote for your TV and use only the remote for your HT system. Your HT remote should work on your TV by default. Your Samsung HT remote should have a TV button and a DVD/Receiver button (or HT button). When using only the TV, press the TV button and then use it for just the TV and when using the HT system, press the DVD/Receiver button and then you can use the HT system.
If for some reason your TV is not set on the Samsung HT remote by default, your HT users manual should have a list of codes that you can use to program your HT remote. Hope that helps you. Gary
Mar 18, 2009 | Samsung HT-A100T Theater System
How do u turn off the demo mode?
WITH THE SYSTEM OFF. PRESS "X-BASS" ON YOUR CINEMA COMMANDER. SHOULD DO THE TRICK.
Mar 20, 2008 | Sharp HT-CN300 System
Sharp Ht-C500DV
plug in the audio out from your playststion to audio in<aux>of your dvd,then select aux on.
Feb 22, 2008 | Televison & Video
Samsung home cinema system HT-THX25 Multiregion hacks
Turn on the HT with no DVD. Press the following buttons on the remote: ENTER 8, 4, 2, 6, 9 ENTER
It will turn off. When turned again on it is a region free HT.
Feb 02, 2008 | Samsung HT-X20 Home Cinema 600W Theater...
Televison & Video Logo
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
