Question about Canon imageCLASS MF4320D
Can we use canon image class MF4320d as network printer
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 46 Answers
Mf4320dn is a netword if mf4320d its not
Posted on Feb 17, 2014
IB4G2008
  • 3587 Answers
SOURCE: Canon Image Class MFC 8180c "Download Stanby"
that's not too good...let's get down to cases here
Posted on Mar 04, 2008
  • 65 Answers
SOURCE: Need printer driver for Canon D880 Image Class
Here you go. Just select your OS from the drop down.
Please rate this solution.
Posted on Nov 30, 2008
  • 628 Answers
SOURCE: canon copier image class D760 / system error E0003
Try this one from Canon:
Issue: ERROR LCD: System Error E003
Solution: Reset the unit-IC D/PC 1000 Series
Reset the unit
  1. Slide the platen to the left.
  2. Slide the platen back to the right until it locks in place.
Posted on Dec 10, 2008
  • 100 Answers
SOURCE: printer doesn't put image on paper
The laser shutter is bad or stuck. The new one is redesigned. The shutter could be removed but that would break saftey laws. If its under warranty still have a repair center do it.
Posted on Jun 25, 2009
  • 92 Answers
SOURCE: canon image class mf5750 legal size paper
Hi ...
If you wish to print using a paper size which is different from the normal one A4, you need to specify the same to the printer else it will not recognize or will not accept the paper ...
Below are the steps that you can follow to:
1) Specify paper size
2) Specify paper type ..
Specifying the Paper Size At the factory, the paper size has already been set to [LTR]. Normally, you can make copies in this setting. When making copies on other sizes of paper, you need to specify the paper size according to the following.
  1. Press <Menu>.
  2. Press <la.gif> or <ra.gif> to select [COMMON SETTINGS], then press <Set>.
  3. Press <la.gif> or <ra.gif> to select [PAPER SETTINGS], then press <Set>.
  4. Press <la.gif> or <ra.gif> to select [PAPER SIZE], then press <Set>.
  5. Press <la.gif> or <ra.gif> to select the appropriate paper size (LTR, LGL, EXECUTIV, A4, B5, ENVELOPE, or FREE SIZE), then press <Set>.
    black_dot.gif When [ENVELOPE] is selected: white_square.gif Press <la.gif> or <ra.gif> to select the type of envelopes (COM10, MONARCH, DL, or ISO-C5), then press <Set>.
    black_dot.gif When [FREE SIZE] is selected: white_square.gif Press <la.gif> or <ra.gif> to select [VERTICAL SIZE] or [HORIZONTAL SIZE], then press <Set>. white_square.gif Use the numeric keys, or press <la.gif> or <ra.gif> to specify vertical and horizontal sizes of the paper in millimeters (mm).
    Available range in [VERTICAL SIZE]: 127 mm to 356 mm (5" to 14")
    Available range in [HORIZONTAL SIZE]: 76 mm to 216 mm (3" to 8 1/2") white_square.gif Press <Set>. Repeat the steps above to specify both vertical and horizontal sizes of the paper.
  6. Press <Stop/Reset> to return to the standby display.
Specifying the Paper Type [PLAIN PAPER] is selected as the default paper type. When making copies on paper other than plain paper, you can specify the paper type according to the following. Specifying the paper type can prevent poor copy quality, or the printout not being printed correctly.
  1. Press <Menu>.
  4. Press <la.gif> or <ra.gif> to select [PAPER TYPE], then press <Set>.
  5. Press <la.gif> or <ra.gif> to select the appropriate paper type, then press <Set>.
    You can select from the following paper types: - Plain paper (17 lb to 24 lb (64 g/m2 to 90 g/m2 )): [PLAIN PAPER] - Heavy paper (25 lb to 34 lb (91 g/m2 to 128 g/m2 )): [HEAVY PAPER], [HEAVY PAPER H]*1 - Transparency: [TRANSPARENCY] - Label*2 : [HEAVY PAPER], [HEAVY PAPER H]*1 - Envelope: [HEAVY PAPER], [HEAVY PAPER H]*1*1 If print fixing is not sufficient when printed with [HEAVY PAPER] selected, select [HEAVY PAPER H].
    *2 A label that can be loaded in the cassette is a standard type (label standard card) only.
Please vote if this helps ... Cheers :)
Posted on Jul 27, 2009
How to fix error 1753: there are no more endpoints available from the endpoint mapper. I can take prints but can't share it.
try going to printer properties and checking compatibility
change from win 7 or what ever you had to win 10
Jul 21, 2016 | Canon Office Equipment & Supplies
System error e100
m/c on go additional key then printer then printer reset then yes then power cycle hope problem was solved
Jan 25, 2014 | Canon imageCLASS Office Equipment &...
Error E225
imageCLASS MF4320d with error code E225 is the CONTACT IMAGE SENSOR UNIT need to replace. Part Number is FK2-2869-000
Apr 26, 2013 | Cannon Office Equipment & Supplies
Canon mf4320d getting error225
CIS scanner lamp has fault, replace the CIS scanner unit.
Feb 08, 2013 | Canon imageCLASS MF4150 All-In-One Laser...
My canon image class Mf4320d printer shows e225 error
Main Cause: The scanning lamp (xenon tube) is faulty. The inverter PCB is faulty. The CCD/AP PCB is faulty. The reader controller PCB is faulty.Mode of Detection:0000 A specific signal level cannot be attained by CCD gain correction at power-on.0002 The edge gain correction value changed more than a specific level compared with the correction value used for the preceding sheet.
Oct 12, 2011 | Office Equipment & Supplies
How to fix system error e100 canon image mf4320d
my printer model no MF4320D
Problems Printer on is Error For Systems error e225
Jun 07, 2011 | Office Equipment & Supplies
How can download image class mf4320d driver
i want to download a canon imageclass MF 4320d Driver. Please help me.
Dec 08, 2010 | Canon Office Equipment & Supplies
I have just purchased a cannon printer Image Class MF4320d which is perfectly working in windows. But Since I am using Fedora 13 linux OS currently ,Please advise me how to install that. I will appreciate...
I can't find any reference to a MF4320d. but they do have drivers for a MF4350d and a MF4370d, both can be found at http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/imageclass_series/imageclass_mf4350d#DriversAndSoftware also you can type the word linux into the search box there and get more info on linux support. use their phone number or email support for more info. hope this helped...
Sep 14, 2010 | Canon Office Equipment & Supplies
Canon imageCLASS MF4320D Logo
75 people viewed this question
old marine
old marine
