Question about MTX tn250/1 terminator 1x200w amplifier class d
No power to MTX TN250/1 Amp
Lost my license, so I left my car sitting in the driveway for 6 months while I was away at college. Meanwhile, my car's trunk accumulated a good bit of water - apparently, Maximas are notorious for having faulty weather stripping. Came home to retrieve my car, hopped in, and noticed the subs didn't hit. Initially, my gain knob's light dimly flickered, and amp's lights flickered, as well. When music was playing, the subs made faint, rhythmic popping noises. However, now, a few months later, neither the knob nor the amp show any indication of life. Can't find the manual for my amp, and I haven't had any luck finding one online, so I don't have a clue whether this is an issue with the amp or the subs (or both) - could this just be a blown fuse, or could condensation in the trunk have seeped into the amp and the subs? I'm planning on heading to the store tomorrow morning to grab a voltmeter, but I have no idea what I'm supposed to be looking for. Wish I had the opportunity to install these bad boys myself so I could know what the hell I'm working with, but they were received/installed as a gift.
    New Friend:
  • 3 Answers
Depends how much water is a bit of water, if the water is inside the amp chances are its fried.
And just to clarify, you've been driving it for a few months with faint popping noises and the subs not working but your door/tweeters working? If so your amp is probably receiving the input for sub sound.
When you get your multi-meter, you want to test from the thick probably red wire to ground to check for your 12V that comes direct from the battery. If you have this, you may have to take the cover of the amp to bits to get to the circuit board, and check there are no moisture deposits or a 'furry like' gunk across any of the circuit board.
There may also be a fuse inside your amp that could have blown due to moisture.
DISCONNECT YOUR BATTERY BEFORE YOU OPEN YOUR AMP or the slightest slip could shock you, or worse totally frazzle your amp.
Easiest way to check your sub would be to back a mates car up to yours and whack your wires from your sub to your amp into his/her amp, and check the bass sounds ok. But with no lighs on your amp i'd start there.
Hope this helps
Posted on Feb 11, 2014
  • realcharliew
    realcharliew Feb 11, 2014
    Ah, I'll try that - thanks for the info! Turned off the subs, disconnected the amp from its power source after I heard the popping noise, and they have remained off in order to ensure no further damage is done. Turned them on for the first time in a few months yesterday to see if my silicon gel drying method was successful. Door speakers/tweeters have been working well, and there wasn't a significant amount of water in the trunk, but certainly enough to make the carpet damp & form condensation during the heat of summer/fall. Car still carries around a faint odor of wet dog.
    New Friend:
You need to think about a better platform : linux for example
Testimonial: "I don't think that's relevant. However, I do use Bodhi Linux on my programming PC, but I'm normally a Mac guy."
Can I use 8 gauge wire for my mtx rfl600
  • No, this is far to powerful of an amp to use 8 gauge. Use 4 gauge copper stranded wire. Using stranded copper wire is best for performance. I recommend a 100amp fuse being ran inline no more than 6 inches off the positive battery terminal as well.
  • You can use a 6 gauge copper stranded wire one one condition and that is if you use only a 4 Ohm speaker. Anything above that you need to go up to 4 gauge.
Regards, Tony
May 23, 2011 | MTX RFL600D Car Amp
My celica has been sitting in the driveway for about 6 months. I connected the battery and had little trouble starting it, but finally got it to start. Then i turned it off and tried to turn it on again...
The battery connections may be dirty. The alternator may not be charging the battery. You had enough battery to start the car and keep it running but because the battery may not have been receiving charge, it lost power the whole time the engine was running. When you turned off the engine, the battery may have been practically dead. So, it wouldn't have any power left when you tried to restart or even turn on.
If you have a battery charger, charge the battery back up. Check the alternator for proper charging output. some auto parts stores will check the alternator output for free.
Feb 25, 2011 | 1991 Toyota Celica
Is there a way to recover a lost product key. I lost my product key when i moved back home from college and i was wondering if there was a way to find a key on the disk or by giving an ID number from the...
If you've just done a system restore then MS Office should still be on the system. Click on the the link and download Keyfinder (the program will download straight away) Run the program and on the left of the window you will see MS Office, click on that and it should show you the product key. Youcan either save it as a test file or write it down. Link below >>>>>>
http://www.softpedia.com/dyn-postdownload.php?p=17673&t=4&i=1
Good luck
Jan 05, 2011 | Microsoft Office 2007 Enterprise Edition...
Brutus amp output problem
must be a bad amp..have you tried bridging them maybe youre channels are out it happens even if its brand new...factory deffects
Feb 21, 2010 | Hifonics Brutus BX 1605D Car Audio...
Im trying to run two kenwood 6/9,s and a mtx sledge hammer 12'' sub of a mtx 6004 amp.where do i put my rca,s front or rear / and if this is poss how do i bridge the sub ????? im lost
Im kind of confused with what exactly your asking. Are you trying to run 3 subs off of an amp? If so, the RCA's should go to the front of the amp, and if your plugging 3 subs in to it, you need to have a 3+ channel amp. There is a way to hook it up differently though. I have 4 12" Hifonics subs running off a 2400 watt Nitro-BMW-486 amp. I just have two subs running to each of the two channels.
Sep 26, 2009 | Car Audio & Video
MTX Thunder problem
Make sure that your connection at the battery is still good-sometimes the wire corrodes up front when your system is installed for a long time-so check that out and of course the fuse that you installed a foot away from the battery so that you dont burn your vehicle down if a short occurs somewhere down the line
Jun 03, 2009 | MTX Thunder 421D Car Audio Amplifier
Need help MTX 1501d amp diagram
Remove cover and set in direct sunny window for long time, may be no problem with it, Took a month to dry one of my amps out enough that it decided it would come back to life, cell phone dropped in sink took 2 weeks, If you try power to it too soon --fried--, good luck finding diagram and repairing it sincerely-hope its okay, good amp, bad luck,
Mar 13, 2009 | MTX Thunder 1501D Car Audio Amplifier
About 6 months ago i had installed the mtx thunder 6500d amp to run my 2 rockford fosgate power T1 12inch subs and every thing was great untill recently it stop puting out sound it still powers up and...
good morning and welcome to fixya. not a bad setup you have here at all, you ned to start by checking the speaker wires inside the box to the connector inside and then the wires from connector to amp on outside. if everything looks fine there, then you need to check the amp for power out of the rca plugs to make sure the channel is not dead. if you are looking for a new amp you can try several different ones from fosgates new line up to soundstream's. im running 4 polk momo 12's on the tarantula amp and love it. they are great amps. hifonics also has a new line up pretty cool stuff, heard really good things about there stuff to. good luck and let me know so i can help you out.
Mar 08, 2009 | MTX Thunder 6500D Car Audio Amplifier
Wiring
if you get a buzz or whine noise that changes on acceleration of the engine,,, for some reason your amp is picking up alternator "noise" the most common cause of this is a corroded/dirty/non bare metal/poor ground connection to the cars chassis form your amp.. recheck your connections and make sure! Another trick is to run the rca cables on the opposite side of the car as the power wire. Also if your rcas have a small wire in the center DO NOT USE IT FOR A REMOTE WIRE!!! it is meant to be grounded on both ends to eliminate noise. Also p.a.c.(pacific accessory corporation) makes a noise filter you can put inline betwen your rca cables and the amp. I have had some sccess with that..
Aug 22, 2007 | iLO XM-MP3-CD Car Stereo
MTX 502 2 chanel amp Pre amp problem?
Unless your amp is 1 (one) ohm stable then you may have fried it. When you attach a 2 ohm load across a bridged amp then you have effectivly placed each output channel on a 1 ohm load. Not a good thing in most cases. Try hooking up ONE speaker on one channel and one input to that one channel one at a time. Then switch the speaker/input to the other channel and see if you can get either or both channels to work independently. Needless to say you must turn the amp off before you make ANY change in the wiring.
Jun 25, 2007 | MTX Thunder 2-Channel Amplifier 502 Car...
MTX tn250/1 terminator 1x200w amplifier class d Logo
79 people viewed this question
Top MTX Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a MTX Audio Player and Recorder Expert? Answer questions, earn points and help others
