Question about LG Studioworks E700B 17" CRT Monitor
Is base of LG CRT monitor available in the market
The grip of the base of LG CRT Monitor has been broken And now I have problem to keep the monitor Kindly solve it
  • 10 Answers
SOURCE: 700e Lg crt monitor problam power on eht on but not display
The normal crt monitor have a demo display when you unplug the vga cable to PC like this image below.. fd6b6b9.jpg
Note:
If the crt monitor green LED light steady and heater beam have light, the horinzontal and High Voltage supplied to tube is completely good. If you encountered this problem just focus on video section of crt monitor. But before you start... find the flyback transformer behind this they have two controls screen & focus. After you found it plugin the monitor use plastic precision or small screw philip driver for safety to high voltage at horizontal area choose screen control rotate it to clockwise direction follow this....
5b5166c.jpg If the display responses or from dim to lighter 100% you have a problem to ABL find this at the bottom of horinzontal section near at flyback transformer pins trace the line of ABL for dried solder, open resistor if nothing happen find the Video IC at chroma section and replace it. follow this...
3c6e89c.jpg For LG & Redfox you found LM1269NA Visit this site for seaching semiconductor matches www.alldatasheet.com Good luck.
Check this site for searching semiconductor
Posted on Aug 25, 2009
SOURCE: LG Studioworks model (500G)CRT Monitor flickers most of the time
lg 500g studioworks green color
Posted on Sep 03, 2009
dnewcombe1
  • 1564 Answers
SOURCE: i got lg 700e crt monitor the problem it has
The unit is saying goodbye, in it's special way. There are very limited repairs for CRT's nowadays. A good cheap flatscreen is always available. Trust my word on the CRT's. Sorry. Thank you, Dana
Posted on Oct 04, 2009
Geekman
  • 32281 Answers
SOURCE: my lg 14 inch crt desktop monitor pictue become
The CRT has screen adjustments, there is a screen adjustment button on the monitor that will allow you to adjust the width of the image as well as the height etc.
Posted on Jan 21, 2010
ruwidperd372
  • 279 Answers
SOURCE: sir, i want default menu setting for lg crt
1024X768 32bits screen refresh rate 60 Hz
Posted on Apr 10, 2010
How to open notch lg700e crt monitor 17''
put the crt screen downward pull plastic button and keep pulled then give the shock to base the base will be removed then take the flat screwdriver then look the gap at upper side and insert the screwdriver into it move screwdriver downwards there are two locks bend it by screwdriver the monitor will be opened
Mar 21, 2010 | LG Studioworks 700S 17" CRT Monitor
Tilt lg monitor
Press down one of your palms against the base, then at the same time, pull the chin of the monitor upwards.
Dec 31, 2008 | LG Flatron F900P 19" CRT Monitor
Hai i have a problem in my 17inch samsung CRT monitor
hello ramesh here.
i hope you should try in lajpat rai market in new delhi. and it would be approx 800- 1000.
you did not maintain that where you live.
thanks
bye
Nov 13, 2008 | Samsung 21" FLAT CRT COLOR MONITOR
2SC5589 in LG 17" CRT Monitor
This transistor is manufactured by Toshiba and is only available through Gateway.
Dan
May 07, 2008 | LG Flatron 776FM 17" CRT Monitor
Display green,red
It should be dry solder joints on the CRT board,the picture tube base is normally dry solder.
Opening the monitor could be tricky as there are two plastic locks which hold the top end of back cover.
Samir
Mar 09, 2008 | LG Studioworks E700B 17" CRT Monitor
Shape
if it cannot be adjusred from outside then the problem in monitor. check hor osc & h/sync section in monitor or loose contactin that section. if you want manual you can go to www.serviceinfo.com
Sep 26, 2007 | LG Flatron 776FM 17" CRT Monitor
Screen Gone "Yellowish" Colour, Appears that Blue colour is not working
your problem is in blue color cathode circuit. as you say that it becomes ok tha5t means 1 cable wire is loose from computer to monitor. 2 crt base loose. 3 loose contact in blue video ckt. 4 signal processor cable to crt board connector loose.(blue wire)
Oct 14, 2006 | LG Flatron F700B 17" CRT Monitor
LG Studioworks E700B 17" CRT Monitor Logo
130 people viewed this question
Top LG Computers & Internet Experts
Michael Vincent Cruz
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
