Question about Nikon Cameras
Memory contains no images message
New camera for use in hospital, set it up and it tells me 'memory contains no images' which we know but can't get rid of the message or take pics. Any ideas?
  • 188 Answers
SOURCE: Message Display
sometimes this problem occures due to defective or fake memory media. try using a good branded card.
Posted on Sep 14, 2006
t00nz
  • 4738 Answers
SOURCE: iPhoto says camera contains no photos, camera says memory card full
Take no more pics until you've recovered the photos, take the card out of the camera. Here's some freeware photo recovery software that should be what you're looking for:
http://camerarepair.blogspot.com/2007/12/recovering-those-accidentally-lost.html
You will need to use a flash card reader with this software. If you don't have one, get one, they're cheap:
http://www.amazon.com/s/ref=sr_st?keywords=card+reader&rs=172282&page=1&rh=n%3A172282%2Ck%3Acard+reader&sort=price
Posted on May 01, 2008
  • 415 Answers
SOURCE: Cannot remove memory card write protection Nikon Coolpixs9
Take your memory card out and look to see if you may have moved the sliding switch on the memory card, if you have move it back.
Posted on Feb 13, 2009
  • 11967 Answers
SOURCE: Nikon Coolpix S550 memory card problems
Your camera uses a different filing system than the other camera...they are not interchangeable.
Posted on Sep 28, 2009
rajdeepdutta
  • 2517 Answers
SOURCE: FOLDER CONTAINS NO IMAGES.
Please follow the instruction below and let me know what is happening.
1. format the new card.( Can't format is from any virus
infected PC ).
2. Insert the card then reset your camera setting.
3. select your mamory card default for save the
photographs.
4. Before start photography confirm that your battery
is fully charged.
Thnaks & please give me feedback about your camera.
Posted on Feb 03, 2010
I cant take pictures from my new NIKON D3000.....the message coming after the click is "THIS FOLDER CONTAIN NO IMAGE".with a warning symbol....shutter is working properly...focus is also...
hi there, i`ve once experienced the same problem as yours,
have you tried to reset all the setting in the camera?
you can find the switch near the USB port, then simply push it using pen or screwdriver
after doing that, try to reformat your memory card using camera option
i hope this post will help, thanks
Jan 17, 2011 | Nikon D3000 Digital Camera
I appear to have lost all my holiday photos due to a crash within the camera when the memory was reading full. Although the camera is not recognising any images on the card It still has a message saying...
you can try to get your images if you use an adapter for the memory card that connect to your computer then there is an application that recover files from a memory card
Hope it will help
Aug 22, 2010 | Fuji Cameras
Is San Disk memory card compatible with Digimax 401 ? I inserted one and got the message card errior.
SD Memory Card is compatible with your Digimax 401 camera. You just need to format the card.
Formatting a memory card
** This is used for formatting the memory card. If you run [FORMAT] on the memory card, all
images, including the protected images, will be deleted. Be sure to download important
images to your PC before formatting the memory card.
** If the memory card is not inserted, the internal memory will be formatted.
** Be sure to format the memory card if you are using a newly purchased or non-initialized
memory card, if it contains data that the camera cannot recognize, or if it contains images
captured with a different camera.
Formatting a Memory Card
1. In any mode other than Voice Recording mode, press the MENU button.
2. Press the LEFT/ RIGHT button and select the [SETUP] menu tab.
3. Select the [FORMAT] menu by pressing the UP/ DOWN button and press the RIGHT button.
4. Select a desired sub menu by pressing the UP/ DOWN button and press the OK button.
- If [No] is selected : The memory card will not be formatted.
- If [Yes] is selected : A [PLEASE WAIT!] message appears and the memory card will be formatted. If you ran FORMAT in Play mode, a [NO IMAGE!] message will appear.
Apr 12, 2010 | Samsung Digimax 401 Digital Camera
My samsung s630 says the memory is full. I cleared photos from the sd card and internal memory, but still can only take four pictures in the lowest quality and size setting.
Memory card might gone bad but can do this following troubleshooting step. Formatting a memory ** This is used for formatting the memory. If you run [Format] on the memory, all images, including the protected images, will be deleted. Be sure to download important images to your PC before formatting the memory. Sub menus
[No] : The memory will not be formatted. Press the menu button three times and the menu display will disappear.
[Yes] : A [Processing!] message appears and the memory will be formatted. If you run FORMAT in Play mode, a [No Image!] message will appear. 1d36119.png
Be sure to run [Format] on the following types of memory card.
- A new memory card, or an unformatted memory card
- A memory card that has a file this camera can't recognize or one that has been taken from another camera.
- Always format the memory card using this camera. If you insert a memory card that has been formatted using other cameras, memory card readers, or PCs, you will get a [Card Error!] message. ** There might be bad sectors on your memory card.
Apr 12, 2010 | Samsung S630 Digital Camera
infected PC ).
photographs.
is fully charged.
Feb 03, 2010 | Nikon D40 Digital Camera with G-II 18-55mm...
My camera says memory contains no images, I have a
You may refer to this camera photo recovery guide that helped me before
Recover images from digital Camera
Jul 10, 2009 | Nikon Coolpix S210 Digital Camera
Took memory card out to print at Sams Club- said "No image"? placed memory card back in camera and when turned on camera diplay said "No Image"? did not delete them- are they in camera and I can recov
Most cameras have built in memory. Remove memory card and turn camera on in play mode. If you see the pics then they in cam memory ; take camera to photoshop they will download it for you.
Please tell me you found them I have a 2nd grader and I know how imporant these memories are for us especially.
May 12, 2009 | Canon PowerShot A470 Digital Camera
Internal Memory is Full
Go into review, and then menu. Go to image storage and then set "auto" or memory card. You may have it set to store your images in the internal memory.
Jan 26, 2009 | Kodak EasyShare M863 Digital Camera
Memory card contains no images after camera turned back on
Are you able to access the images using a card reader on your computer ?
Apr 18, 2017 | Nikon Cameras
Error message: file contains no image data
Hello!
I may be able to add some advice on how to solve this unfortunate problem of "file contains no image data". I have been suffering from the same problem. I have recently been on some amazing vacations and the photos I have lost due to this problem have been invaluable to me! I would pay an insane amount of money to get these photos back, but unfortunately I cannot!
I have a nikon coolpix camera. I contacted the nikon coolpix technical support center. I spoke with a representative who asked me what type of memory card I have. As it turns out I have a generic memory card, which is not compatable with nikon. The only memory cards brands that are indicated to be used with the nikon coolpix camera that I have are as follows: Toshiba, Panasonic, Lexmark, and Sandisk. Those are the only 4!
I was told that if you use another memory card besides the memory cards brands that I have listed... that the camera may communicate incorrectly with your memory card, which results in data that is incomplete to support an image. When this happens you will only see a portion of your image, and you cannot get it back. These bad images with incomplete saved information are called "corrupt files". The representative told me that there are some programs that are available to purchase that may be able to correct corrupt .jpg files, but she believes that they are memory card brand specific.
To put it simply, when you do not have to compatable memory card in your camera, it is as if your camera is speaking english and your memory card is speaking chinese and they are not communicating properly (this was the way the representative explained this problem to me). So check your user manual for your specific type of camera or look it up online to see what type or brand of memory card you should be using! I truly hope this helps someone avoid losing invaluable photos!
Nov 29, 2008 | Nikon COOLPIX L18 Digital Camera
Cameras Logo
49 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
