Question about Canon imageRUNNER 3300 All-In-One Laser Printer
Ir e000051 0000 - Canon imageRUNNER 3300 All-In-One Laser Printer
IR light doesn't work on security camera.
nitevision is in monochrome.. but if the irs dont work in that camera need to either get an ir light for that unit or replace that specific camera..the ir board is burnt out..or disconnected..I have several systems in use at different locations and I do installs for residential locations..I get some of my units off ebay..
Jan 20, 2014 | Zmodo Surveillance CM-S38901SV 540TVL High...
The difference between the inner and outer surfaces of a cylindrical pipe is 88cm sq..if the height of the cylindrical pipe is 14cm and the volume is 176cm cube. Find the inner and outer radius of the...
The surface area of the outer surface is the circumference of the outside of the pipe times its length. So, if OR is the radius of the outside of the pipe and SO is the outer surface area,
SO = 2 * pi * OR * 14
Similarly, the surface area of the outer surface is SI = 2 * pi * IR *14 (if SI is the inner surface area and IR is the radius of the inside of the pipe.
The question states that the difference between the outside surface area and the inside surface area is 88 sq. cm:
SO - SI = 88 ; substituting:
(2 * pi * OR * 14) - (2 * pi * IR * 14) = 88 ; factoring
(2 * pi * 14) (OR - IR) = 88 ;dividing both sides by 2*pi*14
(OR - IR) = 88/(2 * pi) = 88/(2 * 3.14159*14) = 1.00
So, the outside radius is 1 cm more than the inside radius.
It's not clear if the volume stated is the volume of the metal in the pipe or the volume of air inside the pipe, so I will solve it both ways:
If volume of 176cc is of the air inside, the formula for this volume is 14 * pi * IR *IR
176 = 14 * 3.14159 * IR * IR ; dividing both sides by 14 * 3.14159
176/(14 * 3.14159) = IR * IR ; doing the arithmetic
4 = IR * IR ; taking the square root of both sides
sqrt(4) = IR
IR = 2 cm
substituting back into the first equation, the OR is 1cm more than the IR, so
OR = 3 cm
If volume of 176cc is of the iron in the pipe, the formula for that volume is the difference between the volume of the outside of the pipe and the volume of the inside of the pipe, or
(14 * pi * OR * OR) - (14 * pi * IR * IR) = 176 ; factoring
(14 * pi) ((OR * OR) - (IR * IR)) = 176 ; dividing both sides by 14 * pi
((OR * OR) - (IR * IR)) = 176/(14 * 3.14159) = 4
but, since OR is 1 cm more than IR (from above), we can substitute OR = IR + 1
and OR * OR = (IR + 1) * (IR + 1) = (IR*IR) + 2*IR +1
So, ((OR * OR) - (IR * IR)) = 4 becomes
(IR*IR) + 2*IR +1 - (IR*IR) = 4 ; simplifying (IRsquared - IRsquared = 0)
2*IR + 1 = 4 ; subtract 1 from both sides
2*IR = 3 ; divide both sides by 2
IR = 3/2 ;
IR = 1.5cm
OR = 2.5cm
Jan 11, 2011 | Mathsoft StudyWorks! Mathematics Deluxe...
HOW CAN i RESET SAT CODE FOR DIH REMOTE CONTROL FOR DIFFERENT DISH BOX
nmg55
Not all remote are compatible with all our receivers. Depending on the receiver and remote model numbers, if they are compatible you can readdress the remote to the receiver. I have provided a link for readdressing the remote to the receiver. I hope this helps.
Instructions on how to readdress the remote to the receiver:
http://www.dishnetwork.com/SupportSection/remote-setup
Remotes and receivers models:
222 -
21.0 IR / UHF Pro
222k - 21.0 IR / UHF Pro
301 -
3.4 IR
311 -
3.4 IR
322 -
4.4 IR / UHF Pro
381 -
6.4 IR / UHF Pro
411 -
20.0 IR
501 -
6.4 IR / UHF Pro
508 -
6.4 IR / UHF Pro
510 -
6.4 IR / UHF Pro
512 -
6.4 IR / UHF Pro
522 -
6.4 IR / UHF Pro
612 -
21.0 IR / UHF Pro
622 -
21.0 IR / UHF Pro
625 -
6.4 IR / UHF Pro
722 -
21.0 IR / UHF Pro
722k - 21.0 IR / UHF Pro
Ray Calo
DISH Network
Nov 06, 2010 | DISH Network IR Remote Control
Ir 2022n fixing gear number
Problem for Canon iR 2022 Printer Ir 2022n fixing gear number
Dec 30, 2009 | Canon iR 2022 Printer
Which one is better to buy IR 5075 or IR 5065
The all above models are same with minor change for speed
You need model as your daily output requirement
All models are heavy duty.
you can select any one for upto 10,000 print or copy per day or for 20,000 & up print/copy select ir 5075
Jun 15, 2009 | Canon imageRUNNER 5000 Copier
PLEASE HELP ERROR CODE
The machine's hard drive has died. you will need to get a Canon technician out to replace it for you and to re-install the machine's system software. In addition to this you will also need to reconfigure some of the machines settings such as the address book, as this is usually lost when the hard drive is formatted or replaced.
May 07, 2008 | Canon imageRUNNER C3220 Color Copier
Error Code description
The Canon is coming on with a code E602-0003 can somebody please help it is only 9 months old and the company we bought it from is out of bussiness. Please email me @ reception@biscayneroofing.com
Thanks
Madlyn
Feb 25, 2008 | Canon (6981A002AA) for imagerunner 2200,...
IR Receiver
Are you serious?
In case you are serious, IR=infrared.
When you point your TVs remote control toward the TV and press a button, it is the IR receiver on the TV which receives the IR signal which is transmitted from the IR LED (Light Emitting Diode), which is the small bulb like part, on the front end of your remote control.
Any device using a IR remote control, must have an IR receiver to gather the siganl being transmitted. The IR siganl is a coded message of instructions for the device.
Dec 08, 2007 | Jazz DV-179 Digital Camera
Canon imageRUNNER 3300 All-In-One Laser Printer Logo
13 people viewed this question
old marine
old marine
