Question about Air Tools & Compressors
Wire 230 volt air compressor wiring diagrams
Need a pictorial diagram for a 230 volt single phase air compressor components line starter press switch compressor motor
  • 37 Answers
On 230 volts you have 3 wires 2 are 115 volt and the third wire is ground. As long as you hook the ground wires together correctly the other wires don't matter. Usually the ground wire is either white or green. The black wires are hot (115 volts).
Posted on Feb 20, 2014
  • 52 Answers
SOURCE: Compressor wired wrong from the factory and will not run.
I cannot find any diagram from this description. do you have a model # of motor?
Posted on Mar 10, 2009
  • 98 Answers
SOURCE: how to wire it up
if the unit has a starter on it there will be 2 terminals at the top of the starter connect the incoming wires two these terminals making sure that the 2 wires do not touch each other. If unit has only a pressure switch the wires should be tied to the terminals marked line , 1 wire per terminal please.
Posted on Jul 21, 2009
protek480
  • 1714 Answers
SOURCE: i need a wiring diagram for a kobalt 60 gallon air compressor
If it's a 220 volt motor, hook l1 and l2 (220 volts) to the line terminals. If it's a'dual voltage' motor (120 or 220)and you want to use 120, hook 120 to the terminals marked 'line'. Make sure the motor is connected for the voltage you're using if it's dual voltage.
  • 5 Answers
SOURCE: I wish to rewire a single phase electric motor
The motor itself should have a sticker which describes the wiring for 115. It is a small change involving a single wire moving from one pole to another inside the motor starter cap (the bump on the motor itself).
Posted on Aug 29, 2009
  • 6 Answers
SOURCE: converting 3 phase compressor to single phase
Start w/ a single phase motor. Or maybe your question is just confuseing me.
Posted on Sep 12, 2009
SINGLE PHASE WIRING DIGRAM
You need a single phase motor to do that. A 3 phase motor cannot be made to run on one phase.
May 16, 2013 | Ingersoll Rand - Rand Type - 30...
Sometimes IR 30 goes into a strained free wheeling state
Did you change the 3 phase motor out with a single phase motor? A 3 phase motor cannot be made to run on single phase.
Feb 02, 2013 | Ingersoll Rand - Rand Type - 30...
Century single phase 2 hp 3450 rpm type cs motor Frame f56
the motor is on 220 volts ,i like hook that up on 120 volts ,,thanks
May 10, 2012 | Air Tools & Compressors
Need wiring diagram
Mike I do not have a wiring diagram. If you let me know what you need maybe I can help.
Dec 21, 2011 | Ingersoll Rand Type 30 Reciprocating Air...
How to wire a t30 1 phase 230 volt in control box, they used white black green, are the white and black both line voltage for 230 volts? its a model 2475
yes white and black are both line voltage in.each wire will have 110 to 120 volts. Attach one wire to top of starter contactor left side the other to top of starter contactor right side. Attach green wire to ground.
Jun 01, 2011 | Ingersoll Rand Type 30 Reciprocating Air...
I NEED THE WIRING DIAGRAM TO HOOK-UP AN INGERSOLL-RAND TYPE 30, MODEL V 234 N4, SER. # 30T 37128 I UNDERSTAND THAT IT CAN BE WIRED FOR 110 VOLT OR 220 VOLT POWER.
The wiring diagram is on the outside of the
motor case, on most motors,on the label
Also on the inside of the wiring connection
cover
May 25, 2011 | Ingersoll Rand Type 30 Reciprocating Air...
Trying to rewire my ingersoll rand air compressor motor, psi switch motor starter, need some kind of diagram, it has a 5hp single phase 220
Please check out the Web Site Below. It is a Quick Start manual for IR Compressors.
It should have everything you need. It DOES NOT Show you any wiring connections AT the motor.
Hope this helps....Jim
http://www.irtechpubs.com/ir_pdfs/Compressed%20Air/Air%20Compressors/Reciprocating%20Compressor/80445703.PDF
Feb 18, 2011 | Ingersoll Rand - Rand Type - 30...
Need wiring diagram for 'Low Oil Level Switch, part # 32276313.
trying to find diagram for you. LOLS will be wired in series with pressure switch.
Jan 26, 2011 | Ingersoll Rand - Rand Type - 30...
Too change rotation of a 5hp 230 volt
HAVE A LOOK INSIDE THE MOTOR CONNECTION BOX. SOMETIMES ON THE LID ARE INSTRUCTIONS OF HOW TO DO THIS. YOU DID NOT SAY IF THIS WAS A CAPACITOR START UNIT OR NOT. IF THERE IS A CAPACITOR ON THERE IT COULD BE NO GOOD WHICH WILL MAKE THE MOTOR GO WHERE IT WANTS. A GOOD CAPACITOR KICKS IT IN THE RIGHT DIRECTION ON SWITCH ON.
Jul 25, 2010 | Air Tools & Compressors
Air Tools & Compressors Logo
1,025 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
