Question about HP PL4272N 42 in. HDTV Plasma Television
Hp PL4272N Plasma TV with an image problem.
When I connect the power cord to the TV it automatically turns on and goes directly into a green testing screen that assures me there is no problem and then tells me to power down the TV and check the connects. The remote is not responsive and neither are any of the buttons on the TV itself. Please help.
  • Erin
    Erin Jul 30, 2015
    I am having the same problem with my tv. Did you ever get an answer?? Thanks!!
SOURCE: hp 42 plasma tv cptoh 0602 I get sound but no picture
I had the same problem today, Hp wanted $629+tax to fix. With a little mechanical ablity anyone can fix this.
1. remove back covers
2. left-hand side is the video board
3. two white fuses
4. replace
this fixed mine and they only cost $1.50 each
Posted on Nov 26, 2008
professor_sc
  • 180 Answers
SOURCE: HP Officejet 5610 Fax Failure
You can try resetting the printer.
Step 1. Unplug the power cord at the back of the printer while the printer is still on
Step 2. Press and hold the # and 6 button on the printer while the power cord is disconnected. And keep holdig the two buttons until you plug in the power back again.
Note : do not release the # and 6 when you plug the power cord back in. keep holding the two buttons until the printer would turn on then turn off or the printer would say anything about "reset"
Step 3. Try sending a fax after the successful reset of the printer
Posted on Nov 29, 2008
SOURCE: MY HP PL4260N WILL NOT POWER UP ON LIGHT GOES FROM GREEN TO RED
According to HP there is a 1-year warranty extension on this tv for this specific problem. Read more at this link: http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01270780&lc=en&dlc=en&cc=us&product=1832457
Posted on Dec 01, 2008
SOURCE: HP 42' Plasma Won't power on, does not power up..Won't turn on
Hi i have a 42" sylvania plasma tv model 6842 pf m and have a blinking light on but it does not power on.Can you help me?
Posted on Mar 09, 2009
Geekman
  • 32281 Answers
SOURCE: HP DV1000/screen turns on then turns off.
You could have a defective screen - a defective inverter or a CCFL lamp or simply the video cable needs reseating. After reseating the video cable and the problem is still there then :-
To determine if you have a LCD screen or video card problem, read this and follow the instructions.
Defective CCFL backlight, it may have the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display or appear black.
  • Picture flickering on and off.
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
Posted on May 17, 2009
Need assistance with TV problem
Main board fault. Shorted component/s at it. Contact any service technician; or the authorized service center.If you wish to get some details; check the site linked here.Surf the site with patience.Pull up older posts.http://electronicshelponline.blogspot.com/
Aug 04, 2014 | HP PL4200N 42 in. Plasma HDTV
No volume on tv after purposely tripping circuit breaker
Try returning to the initial setup procedure in case some setting changed as a result of the power interruption.
Dec 09, 2013 | HP PL4272N 42 in. HDTV Plasma Television
Cannot attach tv mount to tv to hang on wall
Measure the back of tv where the bolts go. then look for Bracket to Fit.
Dec 04, 2013 | HP PL4272N 42 in. HDTV Plasma Television
Wd-62525 tv timer light still flashing green even after turning set off and hitting reset button
If the TV goes in standby, then it is in protection mode.
Ensure also that the fault is not coming from a faulty receiver box sending
bad signal, check if you get same problem on DVD with no receiver box
connected.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible causes.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the TV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
If you want to DIY you find parts here,
All: Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
LCD/Plasma Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
On LCD Pay particular attention at inverter and power board, power board can be inspected looking for bulged or leaking capacitors, then tested with a multimeter. The inverter is more difficult to test , there is need to read voltages, should be done by a tech. Also the LCD controller board can cause same problem
On Plasma, test Sustain (Ysus/Zsus) / Buffer boards , cables to plasma, digital board and power board.
On Rear Projection : check lamp, lamp ballast, power board, and convergence.
On CRT TVs, check ballast , flyback transformer, CRT, Tuner, Convergence.
Feb 22, 2009 | Mitsubishi WD-62526 Projection TV
My 37" LCD maganavox tv won't turn on - it blinks green and then eventually will turn solid green and then the tv will come on. This has been happening for a few weeks.
connected.
Jan 12, 2009 | Philips Magnavox 27MS343S 27" TV
Standby Indicator flashing SONY KD-32NX100UWhen I turn the TV on the TV goes straight into standby red light, I press the on button on the remote and the TV comes on for about twenty seconds then it...
connected.
1Theinternal circuits are jammed because of electrostaticcharges accumulating on capacitors, or because of a wrong voltage readby the main chip on your monitor controller board. this started theprotection circuit.
2 The protection circuit detected a wrongvoltage or abroken contact, identified an internal fault and kicked in, starting the flashing light.
On LCD Payparticular attention at inverter and power board, power board can beinspected looking for bulged or leaking capacitors, then tested with amultimeter. The inverter is more difficult to test , there is need toread voltages, should be done by a tech. Also the LCD controller board can cause same problem
Nov 19, 2008 | Sony KV-35S42 35" TV
TV Turned itself off and on with flashing green power button
connected.
Sep 03, 2007 | RCA F27718 27" TV
My plasma TV turns itself off and there's nothing I can do to get it come back on...
Firmware is avialable for download on the philips web site. The latest one that is the bundle of mutiple patches may not patch all the problems. Looks like it has to be applied indivdually.. -anil
Jul 11, 2007 | Philips 50PF9630A 50 in. Plasma Television
Open Questions:
HP PL4272N 42 in. HDTV Plasma Television Logo
48 people viewed this question
Top HP Televison & Video Experts
Tony
Computer Links
Are you a HP Televison and Video Expert? Answer questions, earn points and help others
