Question about Acer Aspire All-in-One Desktop PC - Silver (AZ3100-U3072) (2771498)
Display not working after sleep
Formatted not a problem restarted several times after updates. Tried sleep button now blank screen
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 75 Answers
Try starting the pc in safe mode and do system restore
Posted on Mar 15, 2014
When I try to bring my LCD monitor out of sleep it just comes up a dim lighted screen and cannot see desk top. I put my PC in sleep mode then wake it back up and monitor is perfectly fine? how can I
I suspect the monitor. For the sake of troubleshooting: Try another monitor for a few days. If you have the same issue, we will know it is the video card.
Sep 16, 2014 | Computers & Internet
My ipad is frozen
  1. If the iPad is frozen or stuck, hold down both the Sleep/Wake button and the Home button. This will force the iPad to power down.
  2. The iPad screen will display the circle of dashes which indicates it is busy. Once the iPad has finished shutting down completely, the screen will go completely black.
  3. Once the iPad's screen is completely black, hold down the Sleep/Wake button for several seconds. This will allow you to restart the iPad.
  4. When the Apple logo appears in the middle of the screen, you can release the Sleep/Wake button. The iPad will restart shortly after the logo appears.
Aug 31, 2013 | Cell Phones
Black screen when turned onno display
There are several reasons that your Toshiba laptop screen may not come on, even if the laptop appears to be running, and several options you may try to get your screen back up and running without an expensive service call.
Common causes for a blank screen include a backlight that is turned off, a display toggled to an external monitor and improper shutdown errors.
To avoid blank screen errors after your current error is fixed, make sure to follow all instructions in your user's guide to care for your Toshiba computer.
Shine a flashlight directly at your screen and look for an image.
If you see one, this means the backlight on your laptop is off but the screen is still working. This backlight normally turns off only when your screen is closed.
Look for a small metal or plastic pin near one of the screen hinges.
The screen pushes this pin in when it is closed, so if the pin is stuck in the screen closed position, the backlight will remain off.
Tap the pin several times to release it.
You may need to use a small object, such as a pencil tip or straightened paper clip, to reach it on some models.
Monitor Toggle
Press and hold down the "Fn" key if you do not see an image when you use the flashlight.
Tap the "F5" key several times while the "Fn" key is pressed.
This will cycle your screen through the various options that toggle the display to an external monitor.
Attach an external monitor, restart the computer and try this method again if no image appears on the laptop screen.
Click "Start," "Control panel," "Hardware and sound," then "Device manager "using the external monitor if you get an image there but cannot toggle the image back to your LCD.
Select the "Monitor" option to expand your selection and select your LCD monitor from the device list.
Click the "Driver" tab and select "Update" to update the driver, as this error is likely caused by a software driver error.
Force Restart
Press and hold the power button until the computer shuts down completely.
Check the indicator lights at the edge of your laptop to see if the computer is truly off or if it has simply gone into hibernation mode.
If it is off, all lights will be off except the battery-related lights if you have a charger plugged in. In hibernation mode, the power light will blink slowly.
Press the power button to restart the computer again after leaving it off for 15 to 20 seconds. This may fix the problem.
If the blank screen returns or you get a flash of images and then a blank screen, move on to the next step.
Force Power Down
Unplug your laptop from the power source.
Remove the battery by pressing outward on the battery latch and pulling the battery unit completely out of the computer.
Press the power button several times to completely discharge the computer.
Replace the battery and plug the computer back in after about 30 seconds.
Press the power button to turn on the computer.
If you get an error screen upon startup, choose to restart Windows normally.
This error is caused by improper shutdown procedures.
Hope this helps
Nov 14, 2012 | Toshiba Computers & Internet
My toshiba l355d black screen all fans and lights are working
Monitor Toggle
Click "Start," "Control panel," "Hardware and sound," then "Device manager" using the external monitor if you get an image there but cannot toggle the image back to your LCD.
Force Restart
Force Power Down
Hope this helps
Nov 03, 2012 | Toshiba Satellite L355D-S7901 Series...
Laptop is run and start but no display
Monitor Toggle
Force Restart
Force Power Down
Hope this helps
Oct 22, 2012 | Toshiba Satellite A500-ST5608 Laptop DC...
ITouch crashed and wont restart
try this
  1. Press and hold the Home button while reconnecting the USB cable to iPod. When you reconnect the USB to iPod, the device should then power on.
  2. Continue holding the Home button while iPod starts up. While starting up, you will see the Apple logo.
  3. When you see "Connect to iTunes" on the screen, you can release the Home button and iTunes will display the recovery mode message:
  4. Restore and it'll download ~240mb firmware and you're done
If step 1 shows no reaction on your screen,the screen may have got damaged.
Sep 02, 2009 | Apple iPod touch
Tryed reseting iphone now phone stop working seeing USB and itune
Try blowing at the bottom of the phone and plugging it in an out several times.
If recovery mode is not working, make sure it is plugged in.
Hold down the Power and Home buttons for roughly 7 seconds until you see the screen go out.
Wait several seconds to make sure that it doesn't power back on.
Once you have the phone off, hold down the home and power button for 10 seconds before letting go of the power button.
There should be nothing on the screen and it should appear as though it is off.
It may take several tries to do this correctly.
Does itunes recognize it now?
Jun 09, 2009 | Apple iPhone Smartphone
Sleep mode
If you reformatted the hard drive, you have erased everything. If you have restore or backup disks use them now.
Oct 21, 2008 | Dell Dimension 3100 PC Desktop
Dell Inspiron 2200 laptop Display Problem
just open your laptop battry and give its power by addepture and on it.if the problem is not solved check the addepture,after that change your laptop motherboard.layes69@yahoo.com
Apr 22, 2008 | Dell Inspiron 2200 PC Notebook
Garmin Etrex display problem
Have you updated your Garmin unit software recently?
Mar 21, 2008 | Garmin eTrex GPS Receiver
Acer Aspire All-in-One Desktop PC - Silver (AZ3100-U3072) (2771498) Logo
50 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
