Question about Insignia 42" Flat-Panel Plasma HDTV
Buttons on TV suddenly not responsive
Buttons on the TV worked earlier today. I unplugged power, media connections, and carefully removed TV from wall. I set it face up on couch. When I placed it back on wall, and plugged media connections and power plug in, the buttons on the TV no longer work. Remote controls the TV fine. Any suggestions?
    Top Expert:
  • Insignia Master
  • 44,161 Answers
Placing the TV face up on the couch probably compressed the rear panel sufficiently to misalign the buttons. You may have to loosen the rear panel hardware or even remove it to realign the buttons for proper operation.
Posted on Feb 11, 2014
    Problem Solver:
  • 18 Answers
If they are actual buttons check to see if one is stuck. Listen for a click on each button while it is turned off so you can hear it and feel it. Another possibility could be when you moved it around somehow the internal cable that connects the buttons to a connector has slipped out or just has a bad connection. Would require you to take the bezel off to see if the internal connections are ok. Not sure what else to suggest. At least the remote works.
SOURCE: Insignia TV ... big RED X on Screen!
This just happened to me this evening and I have an Insignia as well.
With your TV on, try unplugging and repluggning in your HDMI cable. Hold your reboot button for at least 15 seconds. Should reboot and work.
Posted on Feb 08, 2009
ginko
  • 19396 Answers
SOURCE: insignia tv will not turn on, {power up}
That is usually a faulty power adapter.
Sometimes a faulty inverter board can do the same, but in that case you often get sound with no picture for a while before the the inverter comes up.
In your case it is probably a blown capacitor on power supply board.
Posted on Apr 17, 2009
  • 814 Answers
SOURCE: My Insignia NS-LCD32 TV won't power on. The remote has good batteries, the outlet has power etc. Insignia says to unplug it it for a few seconds and then plug it back in. I tried that multiple times w
The power surges have probably blown the fuse in the power supply board. This may not be the only problem.If you are still under warranty, you will need to have it serviced at a service center. If not You will need to find a repair person or center to open the unit and test it for you. This television and all your electronic equipment should be protected with surge protectors. The reason is your power company has problem with power outages and this will damage your equipment. There is no built in self defense for this equipment due to the huge variants involved with power companies. You should call Insignia and ask them where you can find a authorized service center. You can call the Insignia customer support at this telephone number 1-877-467-4289. Tell them the model number of your television and the problem you have had with its failure to turn on.They will be able to help you find a service center to test and repair your television. I hope this information helps you with your problem.
Posted on Jun 03, 2009
John-INSG
  • 312 Answers
SOURCE: Insignia TV model NS-LCD19. TV shuts off
Unfortunately your TV will need to be serviced. You may take the unit back to the retailer of purchase to arrange for repairs.
Posted on Sep 25, 2009
  • 8457 Answers
SOURCE: Insignia NS-PDP50 Plasma TV - Remote Sensor failure
Change batteries.Reboot everythings.Tv unplug,replug couple mins later.Ur Directv box,push off/on for new update software.After that sould work.Rate me after u done this.
Posted on Jan 02, 2010
Olevia television won't turn on unless you unplug the power cord from the back and plug is back in
One of the buttons has flattened out try the remote first and see if it will pop up, if so replace remote. Then try the one on the TV itself which is more likely...that one will require a new PC board with the buttons on it.
Jul 23, 2014 | Olevia LT42HVi 42 in. LCD Television
Palsonic TFTV8157DT won't respond.
Could have an open internal fuse
Nov 17, 2017 | Televison & Video
I've owned for approx 3 yrs. Today I was watching a show on my Panasonic TH-50PZ80U and all the sudden the sound went away. From the lowest volume setting to the highest, no noise at all...Please...
Hello!
First move: unplug your broadcast provider's box, wait for a minute, then plug it back into power source. I mean: leave all the connections intact, just unplug from power source. It might be just power cord or power adapter. If that's not the case, please do the same with TV. Unplug it from wall outlet, wait a minute, plug it back in. It's a next step, if your "box" won't take care of the problem. If that won't take care of the issue, refer to owner's manual for "reset" procedure. Worst case scenario: you might need to replace main board inside or your TV.
good luck,
Thanks,
Alex.
Oct 09, 2011 | Panasonic Viera TH-50PZ80U Plasma TV
Burners Work, but Oven Won't - Display Dead
The oven elements may be burned out or the switch. Usually if you have an electrical outlet, it gets power from the oven circuit. See if the outlets are working, replace the fuse (sometimes you can't tell it is burned out. Depending on age, you may have to replace elements. Not likely both are gone. does it work on Broil or Bake? You could also, unplug the stove and carefully remove the back cover and look for wires that are dicoloured...or burned.
Mar 02, 2010 | Frigidaire FEF336BC Electric Kitchen Range
Mitsubishi TS-50611 projection tv has no video
You can do quite a bit to narrow things down....
First thing, unplug the set and wait 10 minutes. Then plug it in and watch the green power LED. If it does nothing push the power button and watch the power LED. If the set doesn't respond hold down the MENU and INPUT buttons on the front of the set until the LED starts blinking. If it blinks at this time count the blinks and then repost.
May 26, 2009 | Mitsubishi TS-50611 50" Rear Projection...
Brand new LG plasma stuck on test screens
Resetting the TV
If the buttons on the remote AND the buttons on the TV case do not work (channels do not change and you cannot open or navigate the menu), the TV has stopped responding. Reset the TV as follows:
NOTE:
Some TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can save time.
1. Unplug the TV power cord from the power outlet.
2. Unplug any connected devices (DVD, Set-top boxes, etc...)
3. Press and hold the TV power button for five seconds.
4. Plug the TV power cord back into the power outlet and turn on the TV.
5. Open the on-screen menu to confirm that the TV is responding again.
6. Turn off the TV and reconnect the devices.
7. Turn on the TV.
Hope it may help you;
Regards;
VOTIT
Jan 29, 2009 | Televison & Video
My Sharp Remote Control Is Suddenly Stop Working
Ok I just dealt with the Sharp customer support for this problem.
1) You need to unplug the TV for 1 full minute and remove the batteries from your remote aswell (this will reset the system)
2) Hold the power button on the remote for 30 seconds with the batteries still out of the remote and the TV still unplugged
3) After the 30 seconds replace batteries then press every button on the remote beginning with the power button in order from left to right and top to bottom (same way you read)
4) Then plug your tv back in and try the remote again.... and the remote and TV should be back in sync.
Aug 03, 2008 | Televison & Video
Sound problems
Power down the media center for 20 seconds then power it back up. This will clear the problem.
Dec 23, 2007 | Bose Lifestyle 38 System
ILO-26HD
take your tv back to the supplier you bought it from let them rectify the problem.i suppose that your tv is still under warranty.good luck.
Apr 19, 2007 | iLO 2600 Television
Insignia 42" Flat-Panel Plasma HDTV Logo
74 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
