Question about LG 42PX5D 42 in. Plasma HDTV
Lg 42px5d how do I test the main board for operation
Turns on green light 5sec later clicks and goes back into standby mode all caps look fine
  • Stephen Scott
    Stephen Scott Feb 21, 2014
    how do I test the y dustain board and which board is it I presume the main bord is the one with the av hdmi ect then you have a board above that and then there is a board on each side if them two boards could you tell me which one it is
  • 56 Answers
Probably not main board but a short on the y- sustain board or a bad power supply
Posted on Feb 18, 2014
  • Stephen Scott
    how do I test the y dustain board and which board is it I presume the main bord is the one with the av hdmi ect then you have a board above that and then there is a board on each side if them two boards could you tell me which one it isFeb 21, 2014
  • larry lease Feb 21, 2014
    Hi Stephen, Y Sus is big board on the left side. you have to remove it and check for shorted components with a DVM (digital volt meter) If you have no electronic experience this is probably over your head, but you can pull the board and have someone check it for you.
4 Suggested Answers
freetek
  • 5568 Answers
SOURCE: TV will not power on.
The clicking you hear is a relay that connects, then disconnects the AC to prevent fire or further damage.
If it just fails to turn on, the main power supply is probably at fault and without some technical background and a couple of test instruments, you will not be able to do the repair yourself.
What you can do though is; unplug the set, let it stand overnight or at least several hours, remove the back panel and look for a separate board with mostly larger components on it; it will have a ferrite core transformer on it and several larger capacitors which are cylindrical and mounted vertically to the board.
Before touching anything inside, especially on that board, allow several hours to be safe since the larger capacitors can hold a painful voltage charge for some hours.
There are likely two power supplies, a main (larger) and possibly a separate supply for the plasma display.
Without inspecting your set it is difficult to determine which may have failed since the high voltage supply may use an output from the main supply.
If you see signs of overheating such as discoloration of the board material, it may not be repairable but if you can find a part number on the board, you might be able to buy the power supply and install it yourself.
If there are no signs of heat damage to the board, there may be companies offering to repair it as a subassembly instead of repairing the whole set which could be much more expensive.
If you choose to replace it or have it done, the power supply still may not be at fault since most are capable of switching on and off if a downstream problem is causing an overload.
Not easy to diagnose without having made a few measurements first.
Posted on Sep 29, 2009
Testimonial: "Thank you for the insight, I will follow your suggestions and see where the path leads!"
  • 380 Answers
SOURCE: LG 42 Plasma try's to turn on but just goes back into "stanby" ?
Check to see if you get Va and Vs voltages from the power supply. There should be some wires running to the y-sus. A couple of those wires will be labeled va and vs. Are they present? There will be a sticker stuck to the panel somewhere telling you what they should be.
Posted on Mar 26, 2010
itvrepair
  • 28 Answers
SOURCE: my lg plasma tv stays on standby
is you already change the power board,is possible
your y board is out...is a big board on the left side of the tv
Posted on May 19, 2010
When i switc on my hitachi 42pd5200 tv the standby light turns green but the tv does not start up, any ideas of how to resolve the problem?
if the LED turns green and remains green that means the TV is likely starting up just fine.
if you can shut it off (i.e. turn it back red) and then back green, i.e. if you get it to respond to your command that means the TV is actually operational.
What is NOT operational is part of it , that is not central to the main board's functionality, e.g. the circuits that have to do with the display itself.
In your hitachi that is most commonly the buffer boards and the Y-Sustain board, which sometimes fails and sometimes does not when the buffers fail.
Sep 25, 2012 | Hitachi Televison & Video
No Picture
since how long are you facing the problem
Oct 29, 2008 | Vizio P42HD Television
Hello. My Nec LT35 projector will not turn on. From standby mode, I hit the power button, the power LED turns green, the fan starts, but after two seconds it switches back to standby. The...
i have the exact same error with same projector. did you manage to solve this?
my status led blinked red 6 times indicating a "lamp error" which wasn't helpful. i also tried removing and replacing lamp but didn't work.
Dec 01, 2010 | NEC LT35 Multimedia Projector
Mar 26, 2010 | LG 42PC3D 42 in. Plasma Television
Sep 29, 2009 | LG 42PX5D 42 in. Plasma HDTV
Mine has the same problem, orange LED with humming sound coming from the speakers etc.
Someone brought one to me to look at..same problem. Checked power supply (easy to check, take off bottom cover and measure voltages on connector. standard 5, 3.3, and 12v outputs going to maine board.) Power supply was fine. took out main board and noticed several 100uf,16v caps that seemed to be bloated. replaced them and the unit turns on. Only thing i'm not sure about is the time it takes to initially turn on. when you first turn on main switch in back, the front led flashes green for about a minute then the LCD comes on and says "loading" which takes about 2-3 minutes, then the unit goes into standby mode (red Led) the unit will turn right on and off again quickly as long as the main switch in the back is not turned off and on again. Is it normal for it to intially take so long to boot? I do not know the normal operation as this is the first i attempted to repair.
Jul 03, 2009 | IceBox IBFS1 LCD Television
Planar PDP42BK Plasma TV
It is the power supply. Replace the C97, C19, and C16 Capacitors with 2.2 uF ones.
Jul 10, 2007 | Planar PDP-42BK 42 in. Plasma HDTV
LG 42PX5D 42 in. Plasma HDTV Logo
117 people viewed this question
Computer Repairing
Computer Repairing
